Author Topic: [GB] GMK CYL Gurokawa  (Read 17175 times)
Offline vheissu
  • Pragmatic Geometrist
« on: Tue, 05 August 2025, 16:48:43 »
Gurokawa is GMK’s first fully thematic set, whether you want soft and cute, a little unsettling, or something in between. Pastel tones, offbeat characters, and GMK’s first-ever UV-printed gradients.
Runs from August 8th to August 29th.
VENDORS
Estimated Arrival: Q1 2026
KITS
Bleghkit - $140.00 USD
Custom Hiragana mods from GMK Inukuma
Normie (Alt Basekit) - $140.00 USD
Anomalies - $70.00 USD
Alt Grrr and uwu molds designed by Bagri and qarmaa.kb
  • All multi-color novelties will be UV printed
  • All single color novelties will be doubleshot (Kaomojis, Alt Grrrs, Heart Arrows, and uwu).
Sticks - $20.00 USD
RENDERS
W1-AT by @geonworks
Nyawice by @Hali
Piggy by @jacky__kbd
DESKMATS
Jigokuraku - $25.00 USD
Art by @dannyrecordings
Amayume - $25.00 USD
Characters by @stellaidoscope
Keyboard Collabs
There are two keyboard collabs planned for this project:
Tofu 3.0 TKL Gurokawa Edition and Ramune60 Gurokawa Edition.
Renders are still in development, but each collaboration will feature its own custom anodized color and unique engraving.
Collabs
THANKS TO:
  • To everyone hanging out in 181, The Mexican Keyboard Community, and The Beetles Discords.
  • To my girlfriend, for always backing me up with support and sharp feedback.
  • To Lightning and Hali for helping fine-tune the kitting.
  • To Pensa for the incredible renders.
  • To Kight for sharing the alpha color from GMK Purple-ish.
  • To DannyRecords and stellaidoscope for their illustration skills.
  • To Qaarma and Bagri for lending me their Alt Grrr and uwu molds.
  • And ofc to me, for being the GOAT.
Come and say hi to my discord: Room 181, or follow me on Instagram for more updates.
If you want to support this project, consider adding the signature below to your profile:
Code: [Select]
[url=https://geekhack.org/index.php?topic=125323.0][img width=400 height=120]https://i.imgur.com/DROrI9Z.jpeg[/img][/url]
« Last Edit: Wed, 06 August 2025, 20:21:32 by vheissu »
Re: [GB] GMK CYL Gurokawa
« Reply #1 on: Tue, 05 August 2025, 17:47:26 »
Approved :thumb:
Offline Beatento76
« Reply #2 on: Fri, 08 August 2025, 02:48:29 »
Gurokawa’s first fully thematic GMK set really stands out
Offline IOVERCALLHISTIOCYTES
« Reply #3 on: Fri, 08 August 2025, 11:33:41 »
Word was there was a wrist rest collab?
Offline keepoto
  • HHKB top for TKL pls
« Reply #4 on: Sun, 10 August 2025, 10:32:50 »
GLWGB (a bit late i know)
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #5 on: Sat, 16 August 2025, 11:18:45 »
Waiting for my payday but first GB I'm joining in a very, very long time! Absolutely gorgeous!
Offline AMZ
« Reply #6 on: Sat, 16 August 2025, 11:43:20 »
What's the difference between Microfiber and Rough? Wanna get both deskmats but im kinda confused
Offline reidweb
« Reply #7 on: Mon, 18 August 2025, 05:43:36 »
Cosmos had "rough" deskmats; it's hard to describe - but very similar to very fine grit sandpaper, not as smooth as most deskmats would be. Find them a bit more abrasive for that reason, have a load of dead skin staining my cosmos deskmat
Offline AMZ
« Reply #8 on: Mon, 18 August 2025, 06:29:04 »
So what do you prefer? Microfiber or Rough
Offline Adelscott
« Reply #9 on: Mon, 18 August 2025, 11:28:53 »
I have one rough deskmat, used it for 2 hours only, I can't stand the texture on my forearms or the inside of my hand.
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline reidweb
« Reply #10 on: Tue, 19 August 2025, 01:21:58 »
Microfibre, but do use the rough deskmat when it's design best matches what I'm using for my board. Probably won't pick up anymore rough deskmats though
