Author Topic: Hall effect switches vs standard ones  (Read 5794 times)
Offline phinix
« on: Tue, 05 August 2025, 17:20:24 »
Apart from that variable actuation levels, what else is different in Hall effect switches?
Are they better cause they dont have leafs? I like heavy linears, like oil kings with 85g springs.
Could I mod he switches to have heavy springs as well as regular ones?
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
Offline YALE70
    • Hackjob
Re: Hall effect switches vs standard ones
« Reply #1 on: Tue, 05 August 2025, 18:34:47 »
You'd think that, but honestly I don't find they're dramatically smoother compared to a competently designed lubed linear - if at all.
Apparently you should be able to - I haven't tried it - but I would test the new springs in a switch or two just to be sure. I don't think interference is much of a problem with standard MX springs but specifically non-magnetic ones for HE switches are readily available. Worst case, you might just have to recalibrate each switch.
Raiding your local thrift store.
Alienware Area 51 R2 | ASUS Prime X670-P WiFi | EVGA RTX 3090 KINGPIN Hybrid (2100 MHz @ 1000 mV) | AMD Ryzen 9 7950X (5.7 GHz) | Thermaltake Toughliquid 360 | G.Skill Ripjaws S5 32GB DDR5 (6000 MHz) | Dell D1500EF (1500W)
Model F Labs Classic F104 | Northgate OmniKey Ultra-T | HHKB Professional Hybrid Type-S | IBM Model F AT | Unicomp Classic Model M | Datacomp DFK515
Mad Catz R.A.T. 8+ ADV | Sanwa Gravi Wireless | Microsoft Trackball Explorer | Logitech Trackman Marble FX | Logitech Cordless Optical Trackman | Elecom Huge Wireless
Offline phinix
« Reply #2 on: Wed, 06 August 2025, 06:48:09 »
Thanks for confirming that.
Meeeeh, sounds like it would not be a huge upgrade for me, I dont need that actuation level customisation.
Offline edbods
« Reply #3 on: Wed, 06 August 2025, 09:06:35 »
They're good for durability but unless you're a professional gamer needing absolute maximum and precise response they're not really worth getting
Offline phinix
« Reply #4 on: Fri, 08 August 2025, 20:21:59 »
Anyone know where I could find heavier springs fro HE switches?
Like 70g at least.
« Reply #6 on: Sat, 09 August 2025, 07:34:27 »
I think that would need to be answered for each switch brand.
In the past, there have been mechanical switch types where the spring wasn't interchangeable with Cherry MX. Kailh BOX comes to mind.
BTW, I have seen that there now are keyboards with NMR technology and sockets, that can fit both magnetic and mechanical switches.
« Reply #7 on: Sun, 10 August 2025, 13:08:34 »
Standardization is probably impossible for now given the novelty of designs.
The 1 drawback from induction / hall effect will be clicky switches, because it would introduce wobble in the detection.
