Author Topic: [IC] PBS WoB  (Read 7227 times)
Offline upas
[IC] PBS WoB
« on: Wed, 06 August 2025, 17:31:32 »
[IC] PBS WoB + Accents
This is a simple Interest Check for PBS WoB + Accents keycaps.
Thank you for your feedback during the initial phase of the IC. Here are the changes implemented
-- Added an RGBY Kit
-- Added Fn Key in a different color to accent kits
-- Removed ~# key from Base Kit
-- Added German Base Kit
-- Changed labeling of "Code" key to "System"
-- Changed labeling of "Scr" key to "Scrl"
-- Changed labeling of "AltGr" key to "Alt"
-- Swapped labeling of arrow keys to symbols
-- Added an extra 1.5u Shift key to 40s kit
-- Added an extra B to Base Kit
Colors
GMK CR - Base Color
GMK WS1 - Alpha Legends Colors
GMK TU2 - Accent Color 1
GMK MG1 - Accent Color 2
GMK CV - Accent Color 3
GMK DY - Accent Color 4
GMK V2 - Accent Color 5
GMK P3 - Accent Color 6
GMK N7 - Accent Color 7
GMK V4 - Accent Color 8
GMK N6 - Accent Color 9
Vendors
United States: CannonKeys
Singapore: Ktechs
EU: MonacoKeys
Others: TBD
*If you are interested in being a vendor, please contact anaolivetree on discord
Pricing
Base Kit - $70 [USD]
German Base Kit - $70 [USD]
40's kit - $65 [USD]
CMYW Accents Kit - $15 [USD]
RGBY Accents Kit - $15 [USD]
Mac Kit - $15 [USD]
** Tentative pricing **
Kits
Base Kit
40s Kit
German Base Kit
CMYW Accents Kit
RGBY Accents Kit
Mac Kit
Fill the IC Form here
Keycap Samples
Photos taken under natural light and without editing
Keyboard Renders
A special thanks to:
Chippy and Ana for the feedback
Liv for the renders
« Last Edit: Thu, 06 November 2025, 14:51:14 by upas »
Offline dinobx
Re: [IC] PBS WoB
« Reply #1 on: Wed, 06 August 2025, 19:25:22 »
This looks nice! Will this be an instock product? I'm guessing the IC responses will decide that but instock would be amazing for this
Offline Hugo_mungus
Re: [IC] PBS WoB
« Reply #2 on: Wed, 06 August 2025, 19:45:26 »
I am a fan of PBS, but is that the best black they can do? Looks more like PBS White on Very Dark Navy
Offline IOVERCALLHISTIOCYTES
Re: [IC] PBS WoB
« Reply #3 on: Wed, 06 August 2025, 19:47:50 »
CR in the comparison pic is a GMK CYL sample cap and thus ABS?
Offline PhoenixUNI
Re: [IC] PBS WoB
« Reply #4 on: Wed, 06 August 2025, 20:13:08 »
My kingdom for PBS kits to offer HUNT homing keys either as part of base kits too, or as a standalone kit. Having to buy Base + 40s just for 4 keys stinks.
Offline Damage
Re: [IC] PBS WoB
« Reply #5 on: Wed, 06 August 2025, 22:39:00 »
Happy to see this happening! Would like to see a second B for Alice/split boards. Thanks!
Offline DirtyGingy
Re: [IC] PBS WoB
« Reply #6 on: Thu, 07 August 2025, 00:07:39 »
Dammit, I don't need more caps. Someone post a pepehands for me.
Offline upas
Re: [IC] PBS WoB
« Reply #7 on: Thu, 07 August 2025, 08:44:10 »
We'll definitely take this into consideration! Usually there is a pretty big intersection between 40s/ortho and alternate layouts (Colemak, Dvorak, etc.) - so we usually put the alternate homing there.
We have to be careful on this one since all the keys are reverse dyesub, adding 4 homing keys requires us to add a non-homing F and J as well - so we'd have to add 6 more keys to the base, and since it's reverse dyesub, that'll add more cost than on a normal dyesub kit.
I wonder if some sort of middle ground option like 4 blanks (2 homing, 2 non-homing) could also work?
This will likely be a group buy. Since the keyset is entirely reverse dyesub, we think offering it at a lower GB price first is the way to go.
That's why we included the sample cap. I think it's pretty black, but it's not going to match a doubleshot ABS black cap.
Yep, this is correct.
This will definitely make it into the base kit - just an oversight on the IC! It has the split bars for Alice already!
Re: [IC] PBS WoB
« Reply #8 on: Thu, 07 August 2025, 09:14:06 »
Thought looked pretty good for pbs black. Thanks for confirming.
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] PBS WoB
« Reply #9 on: Thu, 07 August 2025, 20:06:33 »
My kingdom for PBS kits to offer HUNT homing keys either as part of base kits too, (4) or as a standalone kit. Having to buy Base + 40s just for 4 keys stinks.
(1) We'll definitely take this into consideration! Usually there is a pretty big intersection between 40s/ortho and alternate layouts (Colemak, Dvorak, etc.) - so we usually put the alternate homing there.
(2) We have to be careful on this one since all the keys are reverse dyesub, adding 4 homing keys requires us to add a non-homing F and J as well - so we'd have to add 6 more keys to the base, and since it's reverse dyesub, that'll add more cost than on a normal dyesub kit.
(3) I wonder if some sort of middle ground option like 4 blanks (2 homing, 2 non-homing) could also work?
(1) Dvorak was patented in 1936 and remains one of the most popular alt layouts. Since alt layout usage pre-dates the birth of the Ergo/Ortho/40s community and sales of TKL Base kits are still at least on par with those of 40s/Ortho Base kits, it makes sense for Full Base to have alt layout support.
(2) Yes, non-homing F & J are critical for uniform-profile sets. (Sculpted-profile Colevrak+, however, doesn't need them because none of its supported layouts have F or J on the home row.)
(3) 4-key support is infinitely better than no support at all. But I recommend F & J legends on the non-homing keys because a blank home key will always replace one of those two letters.
(4) You might be able to increase interest in a stand-alone homing kit by adding super-homing coverage for all layouts including QWERTY:
Offline dvorcol
Re: [IC] PBS WoB
« Reply #10 on: Fri, 08 August 2025, 01:55:20 »
Why are the H U N T home keys scooped rather than barred? Asking because the kit pictures make barred F & J come across as the favorite because they sit in the main section with alphas. Scooped are off to the side, so they look like the less-popular alternative.
Offline rrdaud
Re: [IC] PBS WoB
« Reply #11 on: Fri, 22 August 2025, 10:04:55 »
Just saw PBS Granite is about to launch, and it's kitting looks great too. Should we assume this one will follow its lead?
Offline GG-Bond
    • github
Re: [IC] PBS WoB
« Reply #12 on: Sun, 31 August 2025, 16:15:23 »
I bought a PBS BoW set before, but the WoB one also looks great. The quality of PBS keycaps is really good.
Offline dvorcol
Re: [IC] PBS WoB
« Reply #13 on: Fri, 07 November 2025, 20:57:07 »
Did you decide it's too expensive to have 4-key alt layout support (2 blank homing, F & J non-homing) to the Base kits?
