Author Topic: [IC] Keykobo Dolch Cadet Keycap – Designed by KEI, Manufactured by Keykobo  (Read 12653 times)
Offline DashanYYY
    • Unikeys
Keykobo Dolch Cadet ABS Triple Shot Keycap Set
Keykobo's Discord: https://discord.gg/NQekTFgrrW
Unikeys' Discord: https://discord.gg/9PjWsc3Dxb
Hi!We’re excited to share a fresh take on a legend.
✍️ Designed by KEI, Crafted by Keykobo
Keykobo Dolch Cadet is a collaborative project between designer KEI and manufacturer Keykobo.
It reimagines the classic Dolch palette with a subtle twist—adding modern contrast, sharper legends, and advanced manufacturing techniques while keeping the soul of Dolch intact.
🎯 Concept Highlights
- Tripleshot injection molding,Our most advanced manufacturing method yet
  - Includes 10U spacebar and BAE for maximum compatibility,10U spacebar with 7U stabilizer mount compatibility
  - We’ve worked closely with designer KEI to ensure this set supports as many layouts as possible
  - Material: High-quality ABS, developed and tooled in-house at Keykobo
 This isn't a re-run. It's a reinterpretation.
## 🧰 Kits
Base Kit
313982-0
Alpha Kit
313984-1
Dark Alpha Kit
313986-2
Extensions Kit
313988-3
40S Kit
313990-4
Bae&10U Kit
313944-5
Relegendables Kit
313946-6
Spacebars Kit
313948-7
Numpad Kit
313950-8
Deskmat
-To match the keyset, we’re introducing three beautifully designed deskmats.
Each measures 900Χ400mm with a comfortable 4.5mm thickness – perfect for long sessions and showcasing your setup.
-A
313952-9
-B
313954-10
-C
313956-11
🧪 Production
- **Manufacturer**: Keykobo
- **Legend process**: Tripleshot ABS、 Doubleshot ABS、UV Print
Timeline:
GB: August 8th – September 8th
Fulfillment Date: October 8th (On the way to the vendors)
Vendors:
Canada:unikeyboardsofficial (https://unikeyboards.com/products/keykobo-dolch-abs-triple-shot-keycap-set)
SEA: Ktechs (https://ktechs.store/products/keykobo-dolch-cadet)
 Oceania:
 USA: Divinikey (https://divinikey.com/products/keykobo-dolch-keycaps)
 Germany:TBD
 UK: TBD
 China:TBD
🧵 About the Team
**KEI** – Designer of Dolch Cadet. Known for clean lines, thoughtful contrast, and classic layouts.
**Keykobo** – Manufacturer focused on high-end tripleshot ABS keycaps with full in-house tooling and production control.
Previous releases: Keykobo COL, Keykobo Cherries, more to come.
## We welcome you to join our official Discord server for updates, discussions, and support: https://discord.gg/MsWdNd6kHW
Drop your comments below 👇
Thanks for reading,
— KEI Χ Keykobo
« Last Edit: Sat, 16 August 2025, 18:54:05 by DashanYYY »
Offline DirtyGingy
Well, I'm in love. I don't need more caps, but I need this.
Offline Mikhail
You better add stepped R4 1.5 Caps Lock and LED Caps Lock instead of Windows logo!!
Also needs ICON TAB for AT layout
Numpad R4-R4 Plus, R3 Minus, R2 *
KKB finally offering 10u Spacebars
Offline bluntkrayon
Can you please add mod tilde and pipe.
Offline Rob27shred
  • Insane in the Membrane! 👻
This is wild, I want it all as an avid Dolch fan!
Offline firimp
I do admire your attempt to make more lite kits such as Alpha that could offer a cheaper option for 60% users, but having R2 1.5u BKSPs without R3 1.75 Control was kinda meaningless, it could be neither or both
Offline konstantin
  • Formerly constexpr
Base Kit
Numpad Kit
R1 End, PgDn can be moved from the base kit to the numpad kit, as those keys are only ever used in layouts with numpads, such as 1800/CP and 96-key. Also, double 1u Ctrl is not useful outside of 40% boards. Therefore, I suggest moving R1 End, PgDn to the numpad kit, and dropping the second 1u Ctrl from the base kit (or moving it to 40s).
In their place, I suggest including R3 PgUp, R4 PgDn for full 65%/75% support, as those keys aren't currently present in any kit. Also, I agree with the previous posters that mod tilde/backspace should be added too.
Alpha Kit
Dark Alpha Kit
I don't think this sort of support will be useful even for 60% users since it still lacks many important keys. It might work, but a more ordinary alpha kit would be cheaper.
Extensions Kit
It might be a good idea to add red arrow keys to the extensions kit since they're not present in base.
Conversely, I don't think you need that many Windows logo keys.
« Last Edit: Tue, 12 August 2025, 21:14:07 by konstantin »
Offline bluntkrayon
So based on the Discord thread, it’s already in production, and kitting is finalized. This is more of a GB post than an IC.
Such a shame.
Offline Trackpoint
Nice, and I like the deskmats, Dolch sets pretty much never include them. Hopefully still time for some changes: the computer on deskmat A ("Dolch Pac 486") should have a screen showing MS-DOS or Windows 3.1, not Windows 98. It even says MS-DOS/Windows 3.1x at the top. Also "computersince" should not be one word.
« Last Edit: Fri, 15 August 2025, 21:42:46 by Trackpoint »
Offline JQ27
Any UK-ISO Keys for this Keykobo set? Seems us users got shafted on the latest NK Version of GMK Dolch when they just said buy Oblo's set which doesn't cover us.
Offline SacredMundane
this looks awesome, please add a second 1.75u spacebar on the 40s kit! or, honestly, just move all the 40s bars to the spacebars kit. might save some money.
also, not sure if kkb has a mold for it, but if it exists I'd add an r2 1.25u backspace to the 40s kit
« Last Edit: Fri, 15 August 2025, 16:09:18 by SacredMundane »
Offline DirtyGingy
I hope that the typo in deskmat A gets fixed
Offline dvorcol
  • Discord: dvorcol_5071
Offline FOURRINGS
TRIPPLE SHOT! Very cool!
Offline IBMweMissU
Very nice, will get both tripleshot alphas, extensions for the stepped bottom row, 10u (!) and some mats, good stuff for Dolch fans
Offline dvorcol
