Author Topic: [GB] Keykobo Dolch Cadet Keycap – Designed by KEI, Manufactured by Keykobo  (Read 11972 times)
Offline DashanYYY
    • Unikeys
Keykobo Dolch Cadet ABS Triple Shot Keycap Set
Keykobo's Discord: https://discord.gg/NQekTFgrrW
Unikeys' Discord: https://discord.gg/9PjWsc3Dxb
Hi!We’re excited to share a fresh take on a legend.
✍️ Designed by KEI, Crafted by Keykobo
Keykobo Dolch Cadet is a collaborative project between designer KEI and manufacturer Keykobo.
It reimagines the classic Dolch palette with a subtle twist—adding modern contrast, sharper legends, and advanced manufacturing techniques while keeping the soul of Dolch intact.
🎯 Concept Highlights
- Tripleshot injection molding,Our most advanced manufacturing method yet
  - Includes 10U spacebar and BAE for maximum compatibility,10U spacebar with 7U stabilizer mount compatibility
  - We’ve worked closely with designer KEI to ensure this set supports as many layouts as possible
  - Material: High-quality ABS, developed and tooled in-house at Keykobo
 This isn't a re-run. It's a reinterpretation.
## 🧰 Kits
Base Kit
313958-0
Alpha Kit
313960-1
Dark Alpha Kit
313962-2
Extensions Kit
313964-3
40S Kit
313966-4
Bae&10U Kit
313968-5
Relegendables Kit
313970-6
Spacebars Kit
313972-7
Numpad Kit
313974-8
Deskmat
-To match the keyset, we’re introducing three beautifully designed deskmats.
Each measures 900Χ400mm with a comfortable 4.5mm thickness – perfect for long sessions and showcasing your setup.
-A
313976-9
-B
313978-10
-C
313980-11
Pricing
Base Kit: 89 USD
Alpha Kit:39 USD
Dark Alpha Kit: 39 USD
Extensions Kit: 39 USD
40S Kit: 17 USD
Bae&10U Kit: 25 USD
Relegendables Kit: 13 USD
Spacebars Kit: 13 USD
Numpad Kit: 20 USD
Deskmat: 19 USD
🧪 Production
- **Manufacturer**: Keykobo
- **Legend process**: Tripleshot ABS、 Doubleshot ABS、UV Print
Timeline:
GB: August 8th – September 8th
Fulfillment Date: October 8th (On the way to the vendors)
Vendors:
Canada:unikeyboardsofficial https://unikeyboards.com/products/keykobo-dolch-abs-triple-shot-keycap-set?srsltid=AfmBOopLxsq-ndKRCYWbABvAta6gPMprbml3F5Lz5cK1D2YD0TPXOKty
SEA: Ktechs https://ktechs.store/products/keykobo-dolch-cadet-deskmats?srsltid=AfmBOop7bqgTxFe3lJAdP_EjOb4-HsXcrhEOUUIW9SWLxeFGDTdHZR2O
Oceania:TBD
USA:Divinikey https://divinikey.com/products/keykobo-dolch-keycaps?srsltid=AfmBOoqi9VAGhymgpLOitm-yuXnzMCOPn2IX-NO9WA5hmCJC5pj7_oRX
EU:
Germany:TBD
UK: TBD
China:TBD
🧵 About the Team
**KEI** – Designer of Dolch Cadet. Known for clean lines, thoughtful contrast, and classic layouts.
**Keykobo** – Manufacturer focused on high-end tripleshot ABS keycaps with full in-house tooling and production control.
Previous releases: Keykobo COL, Keykobo Cherries, more to come.
## We welcome you to join our official Discord server for updates, discussions, and support: https://discord.gg/MsWdNd6kHW
Drop your comments below 👇
Thanks for reading,
— KEI Χ Keykobo
« Last Edit: Mon, 18 August 2025, 11:33:28 by DashanYYY »
Offline dvorcol
  • Discord: dvorcol_5071
Offline dvorcol
Links to more vendors can be found in KeycapLendar
Offline Trackpoint
The "IC" from last week sure wasn't an IC. But images on some vendor sites do show that deskmat A's errors like the typo are fixed, at least (the pics on the GB post here still show the old version).
Offline Sophian
Re: [GB] Keykobo Dolch Cadet Keycap – Designed by KEI, Manufactured by Keykobo
« Reply #4 on: Thu, 25 September 2025, 05:24:19 »
Thank you
Offline dvorcol
FYI this is now available in-stock from Keebz N Cables - https://www.keebzncables.com/products/keykobo-dolch-cadet-keycaps-au-stock
Perhaps other vendors too.
