Author Topic: [IC] RAMUNE60 - TRUE HHKB  (Read 7427 times)
Offline geonworks
    • GEONWORKS
« on: Thu, 11 September 2025, 19:12:28 »
[IC] Ramune60
Introduction
The Ramune60 is a playful 60% gasket-mount keyboard.
Inspired by the Japanese soda Ramune, it combines a classic overall shape design with modern elements.
It offers three layouts (True HHKB, WKL, and WK) and comes in standard colors, a Kuro Edition, and a special collaborative colorway with GMK Gurokawa
—five case color options in total.
Ramune60 typing video
Renders
Ramune60’s inspiration
The design of this keyboard was inspired by Ramune, the iconic Japanese soda known for its playful charm and distinctive glass bottle.
With its clear lower half filled with fizzy soda, opaque top cap, and signature glass marble sealed inside,
the Ramune bottle serves as a direct motif for the keyboard’s form and color palette.
This keyboard captures the refreshing character of Ramune through both its aesthetics and sound.
The low-profile case enhances usability while perfectly matching the light and breezy concept.
Additionally, a carefully tested and tuned Poron gasket delivers a crisp and clear typing sound that complements the overall design.
Specifications
Layout Support:
True HHKB (Solder, Hotswap)
WKL (Solder, Hotswap, Venom60HE 7u)
WK (Solder, Hotswap, Venom60HE 6.25u / 7u, Venom60MX 6.25U)
Materials:
Top Case: A6063 aluminum
Bottom Case: PC, Acrylic, PEI
Weight: 304 SS with Bead Blasted
Typing Angle: 9 degrees
Front Height:
16.65 mm
Weight (Built): Approximately 1.1 kg
Case Colors:
Blue / Dyed PC
Pink / Dyed PC
Silver / Acrylic
Black / PEI, Kuro Edition
Gurokawa / Dyed PC, GMK Gurokawa Collab
Weight:
Bead Blasted SS (Base option)
Bead Blasted SS with Black Coated (Kuro Edition)
PCB:
Solder / Hotswap with RGB Underglow (QMK / VIA compatible)
VENOM60HE RGB (Hall Effect)
VENOM60MX Hotswap 8Khz (QMK / VIA compatible)
Plate:
PP (Base Option), Aluminium, PC, PEI
Gasket
Poron LE-20 Black, 2.5mm
GTC30 White, 3.0mm
Feet
3M SJ5302 Bumpon
Kit contents
Top Case x 1
Bottom Case x 1
Weight x 1
Acryl Panel x 1
PP Plate x 1
Solder PCB x 1
Poron Gasket x 1
3M Feet x 2
Carrying case x 1
Screws and Screw Driver
ID Card
Case colors
Ramune blue
Momo pink
Ice silver
Gurokawa edition (collarboration w/ GMK gurokawa)
Kuro edtion
Layout
Solderable, Hotswappable PCB
-2u Backspace, Split Backspace
-Normal CapsLock, Stepped CapsLock
-2.75 Right Shift, Split Right Shift
-7u Tsangan, 6u True HHKB
VENOM60MX Hotswap 8Khz PCB
-Poker Layout, 6.25u
VENOM60HE 6.25U RGB PCB
VENOM60HE 7U RGB PCB
-Normal CapsLock
-Split Right Shift
-7u Tsangan
Vendors
Lead Vendor, KR: Geonworks
US: Divinikeys
CA: Minokeys
EU: Delta Key Co
OCE: KeebznCables
SG: Ktechs
MY: MechaMY
CN: TypistClub
UK: Prototypist
TH: Aiglatson Studio
JP: Yushakobo
VN: MOKB
Deskmat
Render images
Collaboration with Tree13
Tree13 Instagram
Prototype pictures
Website
Hato's website
Thanks so much for your interest!
Best regards,
Hato
Online vinnie_ll
Re: [IC] RAMUNE60 - TRUE HHKB
« Reply #1 on: Thu, 11 September 2025, 19:42:15 »
looks great! hope to pick one up :)
« Reply #2 on: Fri, 12 September 2025, 02:23:43 »
Love the PCB support
Offline KOBO ISSHI
« Reply #3 on: Fri, 12 September 2025, 02:57:59 »
Very clean. Good job.
Offline Rassles
« Reply #4 on: Fri, 12 September 2025, 05:52:50 »
Can this be EC converted?  :cool:
Offline Livid
« Reply #5 on: Fri, 12 September 2025, 10:47:39 »
is the gurokawa case hhkb only? it reads that way on the product page
Offline Mr.RotKiv
« Reply #6 on: Fri, 12 September 2025, 11:45:22 »
That is correct based on conformation from Geon himself in his Discord server.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #7 on: Fri, 12 September 2025, 12:45:15 »
pink gud
Offline white_rabbit
« Reply #8 on: Fri, 12 September 2025, 12:53:00 »
Why no top housing available in any of the 3 plastic materials?
Offline Livid
« Reply #9 on: Fri, 12 September 2025, 15:16:31 »
bummer ): unfortunately guess I’ll have to pass but glwgb
Offline villagepillage
« Reply #10 on: Sun, 14 September 2025, 03:36:35 »
I love it. My first new hhkb in a few years
Offline Varbil
  • Danish 21 y/o that likes keebs :)
« Reply #11 on: Sun, 14 September 2025, 09:54:16 »
actually love this, so nice to include venom as an option for PCB's aswell for the gamers!
