Author Topic: [GB] Osidian TKL V2 | Sept 15 - Oct 15  (Read 22248 times)
Offline Osidian
« on: Sun, 21 September 2025, 16:50:33 »
314621-0
Osidian TKL V2
Live September 15 - October 15
Fulfillment Q1 2026
Table of Contents
• V2 Changelog
• V1 Group Buy Link
• Alexotos V2 Review
• Specifications
• Photos
• Socials
• Website
V2 Changelog
Top Plate Redesign
• Introduced integrated finger lift-up tabs for easier removal of the magnetic top plate
• Reduced keycap cutout radii to improve compatibility across a wider range of keycap sets
Frame Enhancements
• Optimized Type-C port accessibility for seamless installation and removal of the daughterboard
• Fully redesigned N35 magnetic system delivering significantly stronger top plate adherence
Gasket Mount System
• Redesigned switch plate mount to removable silicone socks for enhanced performance and ease of use
Upgraded Kit Materials
• Transitioned from ABS to anodized aluminum components
2 Added Colorways
• Lemurian Blue Labradorite and Nero Marquina Black
Alexotos V2 Review
Specifications
Included in Kit
• Stone casing / magnetic frame x1
• Magnetic aluminum top plate x1
• 1.5mm Brushed aluminum switch plate (silicone gasket mount) x1
• 3.5mm Poron plate foam x1
• Molex Pico-EZmate cable x1
Color options/finish
• White Carrara
• Nero Marquina Black
PCB & Daughterboard
• Compatible with Cannonkeys Bastion TKL F12 Hotswap/Solder (F13 not included), and the F12/F13 Hotswap version.
• Unified S1 Daughterboard required
PCB & Daughterboard not included
Weight
• Fully assembled approx. 4.5 LBS / 2 KG
Dimensions
• Typing angle: 4 degrees
• Kit length & width: 375mm x 149mm
• Casing finished thickness: 18mm
• Total kit height: 23mm
Price
$449 USD
MOQ = 50 units
Photos
314623-1314625-2
314627-3314629-4
White Carrara
314631-5314633-6
314635-7314637-8
Nero Marquina Black
314639-9314641-10
314643-11314645-12
Socials
Website
Thank you for your time and interest!
Best regards,
Osidian
« Last Edit: Sun, 21 September 2025, 17:13:22 by Osidian »
Offline Osidian
Re: [GB] Osidian TKL V2 | Sept 15 - Oct 15
« Reply #1 on: Thu, 25 September 2025, 16:46:23 »
MOQ reached!
Offline Osidian
« Reply #2 on: Wed, 15 October 2025, 21:15:23 »
Group buy concluded. Production underway! :D
Offline Osidian
« Reply #3 on: Thu, 26 March 2026, 14:20:36 »
Orders have begun shipping.  :D
Fulfillment is being completed in phases, so tracking will be sent out on a rolling basis.
Offline Osidian
« Reply #4 on: Sat, 23 May 2026, 12:35:57 »
Fulfilled! Thank you to everyone who participated.
