Author Topic: [IC] GMK CYL Cleopatra : The Last Pharaoh!  (Read 24641 times)
Offline SxM Designs
  • https://sxmdesigns.com
    • Website
« on: Mon, 22 September 2025, 14:50:33 »
A set inspired by Egypt’s last pharaoh - Cleopatra, a queen of wit, beauty, and power, whose legacy has outlived empires.
Manufacturer   : GMK
Profile        : Cherry CYL
Material       : ABS, Metallic
Thickness      : 1.5mm
Specs          : Metallic gold legends & accents
Novelties      : Double Shot
Cleopatra was Egypt’s last pharaoh, remembered as much for her spirit as for her crown. She grew up in the Ptolemaic dynasty, surrounded by conflict and power struggles, but stood apart with her intelligence and her ability to truly connect with her people. She spoke their language, carried herself with the charm of Hathor, and ruled with the sharpness of Thoth.
Her life was tied to Rome through Julius Caesar and later Mark Antony, where love and politics became impossible to untangle. But when Egypt fell and her kingdom was slipping away, Cleopatra chose her own end. The story says she welcomed death through the bite of an asp, passing into the afterlife under the watch of Anubis. To some she was a temptress, to others a queen betrayed.
Kits are subject to change. More kits can be added if necessary. Feel free to suggest changes in the IC form.
Base Kit
Novelties
Latin Alpha Kit
Gold Extension Kit
Addon & Spacebar Kit
Currently in the works. Will be revealed later!
Nemui by Bachoo
F1-8X by Geon
Glare TKL by Geon
  TBD
If you want to support this project please add this signature and spread the word. Thanks  :thumb:
To add a signature go to Profile -> Modify Profile -> Forum Profile -> Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=125747.0][img width=300 height=60]https://i.imgur.com/4ssIbUq.png[/img][/url]
« Last Edit: Tue, 23 September 2025, 13:53:21 by SxM Designs »
Offline SxM Designs
    • Website
Re: GMK CYL Cleopatra : The Last Pharaoh!
« Reply #1 on: Mon, 22 September 2025, 14:51:07 »
Reserved for something?
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #2 on: Mon, 22 September 2025, 23:21:49 »
You can only take so much of my money before it’s considered robbery you know.
Offline Shangzhijun
« Reply #3 on: Tue, 23 September 2025, 01:43:37 »
Please add 1U tongue to R4, please。
Offline SxM Designs
    • Website
« Reply #4 on: Tue, 23 September 2025, 02:27:19 »
I will take that as a compliment :)
Whats a 1u tongue?
Offline SxM Designs
    • Website
« Reply #5 on: Tue, 23 September 2025, 02:27:49 »
Initial IC responses wanted an clean alpha kit. Added it as an option now!
Offline xGarrisoNx
« Reply #6 on: Tue, 23 September 2025, 03:02:29 »
Will the gold mods be made with the same technique/, colour as GMK Black and Gold?
Offline SxM Designs
    • Website
« Reply #7 on: Tue, 23 September 2025, 03:06:31 »
Same technique yes.
Color I am not sure. I think we are using a different shade of gold. I will post pictures of the color samples once I get them from GMK ( samples already ordered )
Offline LostInTyping
« Reply #8 on: Tue, 23 September 2025, 07:32:15 »
Looks great count me in!!
Offline Shangzhijun
« Reply #9 on: Tue, 23 September 2025, 08:06:12 »
Hope there is a 40Kit,Add 1U Cobra to R4
Offline SxM Designs
    • Website
« Reply #10 on: Tue, 23 September 2025, 08:35:40 »
Hi,
Sadly, there wont be a 40s standalone kit because of MOQ. But you have 4 key 40s support in the kits
1U Cobra to R4 ---> The artwork for 1.25u/1.5u cannot be transfered to the 1u key because there isnt just enough space!
« Last Edit: Tue, 23 September 2025, 08:37:32 by SxM Designs »
Offline BeesKeys
  • Formerly Beesley
    • BeesKeys
« Reply #11 on: Tue, 23 September 2025, 08:58:43 »
LOVE IT
Offline SxM Designs
    • Website
« Reply #12 on: Tue, 23 September 2025, 13:53:08 »
Offline schizobovine
Re: [IC] GMK CYL Cleopatra : The Last Pharaoh!
« Reply #13 on: Tue, 23 September 2025, 16:59:39 »
Yesssssss moar gold-looking plastic!!! (serious, not sarcasm)
I'm definitely in for this set!
Offline SxM Designs
    • Website
« Reply #14 on: Wed, 24 September 2025, 00:23:41 »
Appreciate it!!
Offline Sieglinde
« Reply #15 on: Wed, 24 September 2025, 18:00:50 »
Looks great, anything related to Egypt and I'm in  :thumb:
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #16 on: Thu, 25 September 2025, 06:24:44 »
[40s talk]
Consider changing the non-accent 1.5u r3 Enter in Addon & Spacebar to a 1.75u r3 Enter (accented or otherwise). That way you open up for a whole slew of boards other than minivan to be kitted legend-correctly.
Offline SxM Designs
    • Website
« Reply #17 on: Thu, 25 September 2025, 13:20:36 »
[40s talk]
Thats quite an idea. I believe a 1.25 R2 Tab will still be missing or?
Offline ggggggg
« Reply #18 on: Thu, 25 September 2025, 14:37:35 »
[40s talk]
(r3 but) no you've got that in base, keep that. A 1.75u enter would be on top of what support there is in base and require at least the tab, yeah.
Offline madmax13
« Reply #19 on: Thu, 25 September 2025, 15:04:35 »
GLWIC- Ramses in GMK is fun!
Designer- MTNU Welles, GMK City Pop Neue, DSS Distortion, and SA Motorsport Selectric.
Offline SxM Designs
    • Website
« Reply #20 on: Fri, 26 September 2025, 00:22:28 »
Offline SxM Designs
    • Website
« Reply #21 on: Fri, 26 September 2025, 00:24:08 »
[40s talk]
Got it! Great idea. I think it will benefit if I add this. Probably also a good idea to do this in GMK Medusa as well.
Offline SamirD
« Reply #22 on: Fri, 26 September 2025, 02:24:52 »
Wild--hieroglyphics on a keyboard!  Now I've seen everything.
Offline SxM Designs
    • Website
« Reply #23 on: Fri, 26 September 2025, 03:06:33 »
Actually this is the successor of my previous set GMK Pharaoh which was also the first set to use hieroglyphics :)
Offline KOBO ISSHI
« Reply #24 on: Fri, 26 September 2025, 08:00:03 »
Very cool. Anything egypt themed i'm in!
Offline SamirD
« Reply #25 on: Fri, 26 September 2025, 15:09:53 »
Nice!  Do the placement of the glyphs have any specific meanings?
Offline PerpetualCatLady
« Reply #26 on: Fri, 26 September 2025, 18:03:50 »
Um excuse me I need this right meow!!
Offline maxQST
« Reply #27 on: Sun, 28 September 2025, 23:42:33 »
I would really appreciate a full latin base kit instead of the latin alphas kit.
This set is an absolute winner, but I'm personally turned off by having to buy the latin alphas too. I do believe this set is still likely to hit MOQ with the two base sets, but I'm interested to hear other opinions.
Also those novelties are amazing!!
« Last Edit: Mon, 29 September 2025, 02:44:58 by maxQST »
Offline SxM Designs
    • Website
« Reply #28 on: Mon, 29 September 2025, 08:42:34 »
Really appreciate it! Thanks
Offline SxM Designs
    • Website
« Reply #29 on: Mon, 29 September 2025, 08:44:07 »
While there is no 1:1 mapping of latin alphabets, I used a official transcription from an Australian museum. That was detailed in the GMK Pharaoh IC as far as I remember
Offline SxM Designs
    • Website
« Reply #30 on: Mon, 29 September 2025, 08:45:27 »
Firstly, thanks for the feedback.
While having 2 bases is not out of question, it remains to be seen if there is enough interest and if the vendors want to run 2 bases.
Offline SwitchKeys
    • SwitchKeys
« Reply #31 on: Mon, 29 September 2025, 17:13:52 »
Looks great. Nice fleshed out concept and colours build on GMK Civ too. GLWIC
Offline Turnip487
« Reply #32 on: Tue, 30 September 2025, 12:28:18 »
apologies if this is a basic or redundant question: how are the sublegends on the base kit's alphas produced? are the UV/pad print?
Offline YoungManKim
« Reply #33 on: Tue, 30 September 2025, 13:08:12 »
The sublegends are doubleshot. The molds for these were already used on GMK Pharaoh, which was also a doubleshot set.
Offline SxM Designs
    • Website
« Reply #34 on: Wed, 01 October 2025, 02:45:10 »
Thanks a lot! Appreciate the kind words!
Yes they are doubleshot as YoungManKim explained.
Offline SxM Designs
    • Website
« Reply #35 on: Wed, 15 October 2025, 15:13:22 »
Sample ordered. It might take a while to get the gold sample since its apparently hard to get it! But lets wait and see!
Offline basilkeys
« Reply #36 on: Thu, 16 October 2025, 06:18:31 »
Absolutely gorgeous. I love it. Take my money
Offline SxM Designs
    • Website
« Reply #37 on: Sun, 19 October 2025, 15:09:04 »
Thanks!!
Offline Rel!c
« Reply #38 on: Wed, 19 November 2025, 10:03:08 »
This is undoubtedly fantastic! I am looking for a white and gold-themed set to match my keyboard. The ancient Egyptian theme is undoubtedly the most fitting. I’ve been deeply captivated by your design since the IC of GMK Medusa. You will surely become the brightest star in this field. Looking forward to the GB, please let me know as soon as it starts! :thumb:
Offline TangoTaker
« Reply #39 on: Tue, 02 December 2025, 10:54:04 »
Incredible work. I am just getting into custom keyboards/caps and this one is an absolute banger.
What is the status on the international (or at least german) kit? Sadly I work in a workspace where only ISO-DE works, as other co-workers will use the keyboard sometimes and therefore it must be ISO-DE. This set would definitely make my coworkers jealous.
Offline ber7
« Reply #40 on: Tue, 02 December 2025, 15:36:54 »
