Author Topic: [IC] Two40  (Read 2109 times)
Offline hare works
[IC] Two40
« on: Mon, 29 September 2025, 04:38:46 »
Introduction
This cute thing was originally named "Lagomorpha 40%," but the goal here is to make it stick, we decided to change name to "TWO40." "TWO" sounds like "rabbit" ("兔", tů) in mandarin.
The fusion of the waistline and the bottom of TWO40 is the result of insights gathered over a decade as a consumer. We nailed that smooth, graceful curve and cut out all the extra fluff to keeping it sharp.
Meanwhile, our focus to perfecting the keyboard's internal architecture. The internal cavity is meticulously designed to ensure a smooth and satisfying typing experience.
In the TWO40, we using silicone gasket mounts to provide bounce, similar to an O-ring effect. The design also supports a plateless even using the hotswap PCB. Furthermore, the relatively compact internal cavity contributes to a crisper and cleaner typing sound.
Status
We actually kicked off this project at the start of the year. After tweaking and testing it through a bunch of versions, we finally ran a Round zero. We sold a few units in China and also sent out to streamers for building vedio.
I'm sure you knows that the market for 40 is relatively small. It's very difficult for a studio to cover the cost to make a 40.The first keyboard was made in a 40 mainly because of the designer's own preference. We seeking for local vendors. Currently, the only selling channels for this product have been confirmed is zFrontier and Keyspensory.
This year, we participated in the Meetup in Shenzhen and the Meetup organized by zFrontierin Tokyo.
In November, we will participate in the Meetup held in Shanghai. After that, we will also try to attend meetups around the world.
The GB in China will be launched within a month. Meanwhile, the international version of GB will be carried out shortly after that. However, the color for international version has not been determined yet. You can see that TWO40 has produced a wide range of color samples. We welcome you to participate in the DC  JOIN THE Hare Works DISCORD  voting to choose your favorite color and help us determine the color for the international version.
Product details:
Layout: 40%  corner blocker Alice
​Connectivity: Tri-mode (Bluetooth/2.4G/Wired)
​Structure: Oring-like and plateless support
​Typing angle: 11°
​Front height: 16.3–20.5mm (excluding feet)
​Weight: ≈1.0kg (aluminum case with aluminum weight)
​Materials: 6063 aluminum / PC / PEI
​Weight & backplate materials: Aluminum / Copper
You can check colors we tested and updateing in our instagram and Discord:
1.Light purple
2.carton blue and prussian
3. Anodized copper
4. Gold
5. Coffee
6. Warm silver
7. Black
8. olive
9. light green
10. rosewater
11. beige with micro-arc oxidation
12. oat with micro-arc oxidation
13. PC
14. PEI
15. Others[updating]
« Last Edit: Mon, 29 September 2025, 21:20:01 by hare works »
