Author Topic: [GB] PBS Granite  (Read 6118 times)
Offline upas
[GB] PBS Granite
« on: Mon, 29 September 2025, 17:32:16 »
PBS Granite
A classic colorway in modern PBS
Group Buy Info
Live October 17th to November 16th!
ETA Late Q1 2026
Vendors
• USA - CannonKeys
• EU - MonacoKeys
• EU - Oblotzky
• UK - ProtoTypist
• CN - zFrontier
• KR - SwagKeys
• SEA - iLumkb
• OCE - KeebzNCables
What is PBS?
PBS, short for "Penguin Belly Slide", is a uniform keycap profile- every row has the same height. The profile is designed by Matt3o, and manufactured by Keyreative. PBS uses a combination of a cylindrical front and back with a spherical top scoop. The result is a wide scooped contact area at the top, which enables a comfy and ergonomic typing experience. To learn more about PBS, we recommend checking out our website.
PBS Specs
• PBT
• 1.5mm thick blanks
• Dyesub and reverse dyesub
• Concave and convex available
• Massive layout support
• Concave max height of 7.43mm
• Convex max height of 7.91mm
A brief history of the Granite colorway
In 2014, keyboard hobbyist Matt3o started an IC for a new dyesub keycap set asking the community to vote on what colorway they wanted to see next in a set- Gray, beige, or charcoal. Over 100 votes later, the community spoke, and the gray keyset colorway known as Granite was born.
Based on old SGI Granite keyboards, Matt3o took the inspiration and added some RGB accents and basic ergo support. 11 years, and several successful runs of Granite later, Matt3o has given us the blessing to bring his now classic Granite colorway to his new keycap profile- PBS.
Sample Photos
As a friendly reminder, the color codes are what the colors are based on. Please use the image to try and gauge how they will look.
Kitting
Regular Base - $70
40s/Ortho Base - $65
Accents - $20
UK Base
DE Base
Color Information
Granite has had several runs across many keycap manufacturers and profiles. While we aim to carry the spirit of Granite with this new PBS revision, colors needed to converted and will be rematched. Here are the RAL color codes we plan on using as guidelines for the set.
Base Kits
• ALPHA (Light Gray): 9018
• MODS (Medium Gray): 7045
• BLACK: 9005
• RED (#1): 3031
• BLUE: 5015
Accent Kit
• CYAN: 210 70 35
• MAGENTA: 4003
• YELLOW: 1018
• VIOLET: 300 50 40
• ORANGE: 1028
• RED (#2): 3020
• DARK GRAY: 000 20 00
• BLACK: 9005 (legends on colored caps)
• LIGHT GRAY 9018 (legends on dark gray caps)
Thank You
• Matt3o for designing the original Granite
• Liv for the great renders!
• The Original Supporters of Granite
Offline upas
Re: [GB] PBS Granite
« Reply #1 on: Mon, 29 September 2025, 17:32:35 »
Reserved
Offline MikeTheTiger
« Reply #2 on: Mon, 29 September 2025, 17:55:21 »
Great pricing. Might pick up a 40’s kit. Granite is such a classic.
"all the numbers or none of them cmon man" -Kokaloo
Offline ironsouls
« Reply #3 on: Tue, 30 September 2025, 21:30:21 »
love it
