Author Topic: [IC] PCP 「DYNOX」Mechanical structure PAD  (Read 2420 times)
Offline Project:P
« on: Thu, 16 October 2025, 11:52:11 »
IC FROM:https://forms.gle/sRJucLSHiM3RMoJs5
【Project:P】DYNOX-PAD
"The charm of machinery"
: P brings a new range of machinery, starting with DYNOX-PAD
Aimed at achieving this through multiple mechanical structures and highly customizable gameplay,
Perfect your desktop space and make everything more interesting.
MX switches, micro switches, knobs, push rod...
Rich customizable functions,
Multi-angle ratchet hover for you to choose from.
Replaceable expansion modules are being updated.
Information
Material: Anodized aluminum, copper, PC/ acrylic, stainless steel, silicone, POM
GB Date: TBD
Vendors:TBD
Color|Material
Design丨Gameplay
[Design elements]
This DYNOX is designed around the mechanical structure.
Incorporating elements of science fiction weapons,
You can adjust the pad angle according to your own desktop habits.
The upper PCB is designed with a sub-board, which can replace different modules (knobs, push rods, etc.).
[Mechanical shock absorption]
DYNOX uses a purely mechanical shock-absorbing structure.
Four sets of mechanical shock absorbers convert the downward force into lateral direction.
This allows the use of larger and longer springs for better results.
*We are testing whether springs of different specifications can be replaced to obtain different hand feel
[Angle Adjustment]
Through a mechanical ratchet structure between the upper and lower layers,
DYNOX can achieve multi-angle adjustment,
Adjust the angle that suits you best.
[Mod Replacement]
By replacing the individual PCB in the upper area,
DYNOX can achieve different functions,
At the same time, the left and right micro buttons set the tritium tube slots.
*At present, it can be confirmed that there are ordinary switches, knobs, push rods, and other functions are still looking for PCB solutions, and more more information is updated here.
Others丨Progress
PAD is carrying out a full set of proofing,
IC stage hopes to get more feedback from everyone,
The group purchase futures of ROTOR-EDC have started to be shipped in the past few days,
Thank you for your support.
There are also several new things that are also proofing, I believe that it won’t be long before some interesting new things are introduced to you.
Project:P
Product
Perception
Perceive
Personal
Promise
:P will start from design and aim to complete each project through a sophisticated design language.
The mechanical structure of this series was originally made in the 60 and 75.
However, during the design process, we felt that the ability to control the structural design and supply chain at that time may not be enough to properly implement it.
After working with the factory through the ROTOR-EDC project, I feel that I can raise this series again.
*There is a mechanical series, of course, there will be another corresponding series, you can guess what.
« Last Edit: Sat, 15 November 2025, 08:44:20 by Project:P »
Offline Project:P
Re: [IC] PCP 「DYNOX」 PAD
« Reply #1 on: Fri, 14 November 2025, 12:15:09 »
Timeline update
1.10/16/2025 Publish interest checks;
2.10/20/2025, sample production for version v1.1;
3.10/30/2025, the mechanical spring structure was tested but failed to achieve satisfactory results. The production of the mechanical spring structure for version v1.2 was carried out.
4.11/15/2025, the bottom shell and upper shell have been completed, and other components are currently being manufactured.
