Author Topic: [IC] Cherry G80-9009 Aluminum CNC Remake Version-Updates Applied  (Read 18226 times)
Offline cndisk6
« on: Fri, 05 December 2025, 01:01:02 »
Update 03/08 Temprary pause on the project as we focus on the new MK06 Version
150 keys, Hot-swappable, 14 satellite axes, Gasket + TOP structure
Default FR4 plate
Standard sound kit (solder mask foam, under-switch pad, switch socket foam)
Triple-screen linkage (all controllable via keyboard Fn combination keys)
Key Features:
Main Screen: Defaults as a secondary computer display (multi-point capacitive touch)
No custom multi-head cables (saves computer ports)
No HDMI cable-dragging design (ensures a neat desktop)
2.4×2 Dual Side Screens
Supports OTA updates via network
Displays time, calendar, weather (auto-detects location, no manual setup), static/dynamic images (customizable freely)
Vial-based Keyboard Management
Remappable locally or via web (no JSON required, plug-and-play recognition)
Dimensions: 500×230×(max. 60 + min. 20) mm
Space bar row height: 20 mm (prevents wrist suspension during typing)
Default Sleep Logic
Main screen auto-off when computer sleeps/shuts down (adjustable standby settings)
Dual side screens auto-off after 10 minutes of inactivity
Finish & Customization
cnc Sandblasted + electrostatic spraying (multiple color options)
Customizable serial number or logo on the back (CNC-machined, not silk-screened/laser-engraved)
The kit does not include switches, stabilizers, or keycaps.
Pre-order  price: USD ~699
Limited 50 units
« Last Edit: Sun, 08 March 2026, 01:48:46 by cndisk6 »
Offline jd
  • 60%
Re: [IC] Cherry G80-9009 Aluminum CNC Remake Version
« Reply #1 on: Fri, 05 December 2025, 19:26:38 »
This is the kind of maximalism I love. Definitely interested in this as a work keyboard.
Offline meowoofun
  • Design Critic
« Reply #2 on: Fri, 05 December 2025, 20:11:24 »
Is there any custom layout support? I'm extremely interested in this project.
Offline cndisk6
« Reply #3 on: Fri, 05 December 2025, 20:45:51 »
The keyboard PCB is based on QMK and supports key remapping via Vial.
Offline meowoofun
  • Design Critic
« Reply #4 on: Fri, 05 December 2025, 20:50:11 »
Is there any step caps, 7u, or 2.25u enter?
Offline cndisk6
« Reply #5 on: Fri, 05 December 2025, 21:02:41 »
Only supports the caps step layout. Considering that the G80-9009 has too many keys, splitting the spacebar would make it difficult to source matching keycaps—7u or 2.25u spacebar layouts are not supported. Additionally, we aim to retain the original authentic G80-9009 layout as much as possible.
Offline meowoofun
  • Design Critic
« Reply #6 on: Fri, 05 December 2025, 21:12:35 »
Wish it had more options, even with respect to your design goal.
Offline cndisk6
« Reply #7 on: Fri, 05 December 2025, 23:06:41 »
Okay, thank you for the suggestions. We will carefully consider them and make revisions accordingly.
Offline meowoofun
  • Design Critic
« Reply #8 on: Sat, 06 December 2025, 05:01:24 »
I appreciate the projects commitment.
I do have one more request, I'm not sure how much it would add to the cost but the top row 2u keys having split 1u keys options would help a lot to fit easily fullsize keysets.
Finding R1 2u keys is quite a hunt.
Offline cndisk6
« Reply #9 on: Sat, 06 December 2025, 08:38:37 »
The keycaps are not an issue—we provide a complete keycap solution, and our existing keycaps (sold separately) are fully compatible.
Offline LMarci
« Reply #10 on: Sat, 06 December 2025, 08:49:43 »
This is really cool, I'm considering getting one. Glwic!
Offline zlobin356
  • Hi! My name is zlobin!
« Reply #11 on: Sat, 06 December 2025, 15:16:09 »
Wouldnt be tsangan bottom row more OG ? Original 9009 Haves 1.5u x 1u x 1u x 8u x 1u x 1u x 1.5u. finding 8u spacebar indeed is a difficult task, but 7u right now presented in 99% of keycap kits and it would be much more authentic and proportionally right to have, than having small 6.25u spacebar and more 1.25u keys. While i understand ISO only, why no 1.25u shift like in og keyboard? Would be also cool to see plateless mount or atleast half plate for authenticity, if its indeed a remake version.
Collection state: OTD The Cheat, Tofu60 v1, Hal.6
Offline ItIsWritten
« Reply #12 on: Sun, 07 December 2025, 10:27:57 »
Very interested.
Verstuurd vanaf mijn SM-S908U1 met Tapatalk
Offline Unenlightenment
« Reply #13 on: Wed, 10 December 2025, 17:04:41 »
We'll watch your career with great interest
Offline JailIT
« Reply #14 on: Sat, 27 December 2025, 17:01:56 »
Damn looks good, is tempting me to try and get my original one working!
Offline Logi_
« Reply #15 on: Sat, 27 December 2025, 22:38:05 »
Awesome looking keyboard.
Will there be settings to adjust the Dual side screens being controllable instead of being auto-off after 10 minutes of inactivity? Additionally is the software browser based by any chance?
« Reply #16 on: Sun, 28 December 2025, 07:08:40 »
Do we have any group buy info?
Offline whomad1215
« Reply #17 on: Mon, 05 January 2026, 13:17:44 »
what kits would you need to complete a board this oversized
Offline NightFox99
« Reply #18 on: Fri, 30 January 2026, 10:37:55 »
Yes, please
Offline Cykablaster
« Reply #19 on: Sun, 01 March 2026, 14:23:32 »
Still interested.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
« Reply #20 on: Mon, 02 March 2026, 14:21:44 »
damn did i just miss this
https://mekibo.com/
Offline cndisk6
Re: [IC] Cherry G80-9009 Aluminum CNC Remake Version-Updates Applied
« Reply #21 on: Sat, 07 March 2026, 21:51:50 »
Updated with latest progress
Offline PiGGO_O
« Reply #22 on: Sat, 07 March 2026, 23:53:56 »
This is really crazy, :D
