Author Topic: [GB] Xteeeeeeeeeeeeeeeeeeeeeeeee! Rebel Edition (8K dongle moved for later)  (Read 84923 times)
Offline Thebloodyez
  • Just a random keyboard builder.
"Xteeeeeeeeeeeeeeeeeeeeeeeee!"
Update logs:
- To do:
  (Prototype V2)
- 04/01/2025: Nothing to see here for now...
- 10/14/2025: Xteee Brass Edition.
- 10/19/2025: Xteee Brass "Rebel" Edition IC Form(Xteee Brass "Rebel" Edition IC Form)
- 11/06/2025: Xteee Brass "Rebel" Edition will be run through (Blackdrop) rather than using google form.
- 12/08/2025: Preparing for Xteee 8K Brass "Rebel" Edition GB.
- 12/23/2025: Added Blackdrop website link for Xteeeeeeeeeeeeeeeeeeeeeeeee, checkout the vendorez section.
- 04/26/2026: Prototype V2 case order have been placed. I am considering to include aluminum version to the GB and close this project.
- 07/31/2026: Prototype V2 aluminum reached and tested :thumb: I will move forward with simple kit no more 8k to keep the price low BUT I will offer it as a kit later. the pledge will be opened again at blackdrop.net soon...
MyDiscord | [IC] Xteeeeeeeeeeeeeeeeeeeeeeeee! | MyInstgram
The Lorez
Checkout the IC on the top link if you are interested... But Xteeeeeeeeeeeeeeeeeeeeeeeee comes now with 8K meme for a future project.
Coming soon...
8K Specez
7.5 degree typing angle.
7 degree on top tent (R1\R0).
Brass 8K Rebel Edition
Xteeeeeeeeeeeeeeeeeeeeeeeee! Dual Hotswap PCB for top and bottom.
CuDB + JST or UDB + JST.
Firmware: QMK & Vial.
PCB support: Macro XT.
Weight: Brass Rebel Edition ~1KG.
Renders
PCBez
Xteee Dual MX Hotswap PCB
CuDB for 8K memez
So what's included:
Brass top & bottom case.
Aluminum or FR4 Plate.
Dual MX Hotswap PCB.
CuDB + JST cable.
Screws (extra included).
Geon rubber feets.
Might consider carrying bag.
Vendorez
Blackdrop
Pricez
Check out Blackdrop link above!
« Last Edit: Fri, 31 July 2026, 10:49:04 by Thebloodyez »
Offline DirtyGingy
Re: [GB] Xteeeeeeeeeeeeeeeeeeeeeeeee! 8K Rebel Edition
« Reply #1 on: Mon, 08 December 2025, 16:40:01 »
I can't believe it took this long and this silly of a project for someone, anyone, to think "what if we put the wireless switch facing outward"
I hope the project goes well!
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #2 on: Mon, 08 December 2025, 18:24:43 »
Mr. EZ, can you tell us what is this so-called blackdrop?  :-*
« Reply #3 on: Mon, 08 December 2025, 19:33:50 »
Is the aluminum (silver ano) tier gonna happen after Brass?
Offline FatefulStranger
« Reply #4 on: Mon, 08 December 2025, 22:40:29 »
Go off homie and take my money!!!!!!  :p
GLWGB! So happy to finally see this go into GB since Day 1 hahaha
Offline Thebloodyez
« Reply #5 on: Tue, 09 December 2025, 12:28:30 »
Thanks! Well its all aero dynamics testing it take so much time :giggle:
Offline Thebloodyez
« Reply #6 on: Tue, 09 December 2025, 12:32:38 »
Yo yo yo! Sure!
We asked blackdrop creator and he said:
"Its a nice store to sell nice things" :p
"something something people buy something something price DROPS"
Offline Thebloodyez
« Reply #7 on: Tue, 09 December 2025, 12:33:49 »
Hello! Yez it will come later in another GB the all good Silver and Black colors.
Offline Thebloodyez
« Reply #8 on: Tue, 09 December 2025, 12:34:53 »
Thank kind sir!
Offline Thebloodyez
« Reply #9 on: Mon, 05 January 2026, 06:47:06 »
Pladge Phase is up! xteeeeeeeeeeeeeeeeeeeeeeeee
I will post updates in the main thread
Pledge Period - Jan 5, 2026
Pledge Period Ends - Expected: Feb 5, 2026
Group Buy Opens - Expected: Mar 10, 2026
Group Buy Ends - Expected: Apr 10, 2026
Offline Thebloodyez
« Reply #10 on: Sat, 25 April 2026, 16:10:59 »
Prototype V2 ordered also check out the update section about the aluminum version and the GB.
Offline kenny_25
« Reply #11 on: Sun, 26 April 2026, 12:22:02 »
This is hilarious lmao. Is that antenna on the PCB? Curious how did you manage to make qmk/vial work in bt. Did you do custom firmware?
Offline Thebloodyez
« Reply #12 on: Fri, 31 July 2026, 10:48:12 »
The xteee will connect directly via USB to the system while the UDB will have its dedicated 8K dongle to work for a future project.
