Author Topic: [GB]NAMA: Now Officially Live  (Read 3707 times)
Offline Ckeeb
  • Meet ZOOM64 Keyboard!
    • MELETRIX
« on: Wed, 10 December 2025, 20:22:34 »
Hi Friends,
NAMA is Now Officially Live!
Thanks for following this project for so long. Back in 2021, we ran a GB for Mammoth75 . It might be the first custom keyboard that has a whole piece of Mirror PVD bottom case, and the first custom keyboard with a big volume knob design. It was a very bold design, and we didn't expect there would be so much interest in it and keep asking for Mammoth75 V2 after delivery. Some friends asked us to recolor Mammoth75 and run an R2, but we think it should be a once-in-a-lifetime design for our community, and we didn't do this. However, we keep getting requirements asking, and seriously, we knew we must give another trial. There were design ideas we couldn't achieve from Mammoth due to manufacturing limitations at that time, and there were new ideas we gained gradually from our community.
From Mammoth to Nama
We pick the name "Nama" from "Paleoloxodon namadicus", it's the largest fossil elephant and one of the largest land mammals. By size, it's bigger and stronger than the Mammoth. But Nama is not designed with the idea for a "V2" by size; it is created to embrace our custom keyboard's manufacturing skills progress during the past years and rekindle the spark in a hardcore keyboard enthusiast's heart. It's heavy, stable, and reliable.
Ticking and Typing
Like mechanical keyboards, watches possess a distinct beauty of their own, and we integrated that beauty into Nama. With the prototype, we discovered that winding the watch spring was the most enjoyable moment. The ticking of the watch conveyed the flow of time, while our fingertips typed out the rhythm of each precious second.
But then we asked ourselves: why were the clock hands necessary? We chose to remove them before finalizing the design, and we knew we were right. The continuously rotating gears remind us that the present moment is the best. Just enjoy the movement.
NAMA Purchase Guide
GB Time
GB Time: December 9th, 9:30 AM Beijing Time - December 23rd or earlier when reach limit.
Estimated Shipping Time: March 2026
GB Limit
300 Units globally
Due to the manufacturing difficulties, in order to deliver on time, we need to slow down every process and must limit the QTY very strictly. We will set an initial limit with every partner and check real-time sales every day. Once we are closer to the limit, we will inform all partners to stop GB.
Enter NAMA:https://shop.wuquestudio.com/collections/nama-1
If you‘re interested, you can watch the NAMA review here: [Link] / [Link]
Colors
We provide ten top case colors, matching different bottom case colors made from either aluminum or brass.
Midnight Blue
Crimson Royale
Nova Frost
Titanium Shadow
Rose Quartz
Emerald Dusk
Amethyst Night
Lunar Silver
Violet Whisper
Noir Eclipse
Structure
Warming: No quick-assembly ball catch system on Nama!
In order to give the most stable and secure structure, we decided to use a traditional screw-in system to make the board as seamless as possible. We do not give a quick assembly ball-catch system for this reason. Please check the Nama structure below:
Note:
Given the consideration to minimize the work when we don't have a quick release system, Nama will be prebuilt with lubed stabilizers; all you need to do is install switches and keycaps!
Product Specifications:
Keyboard Layout: 80%
Finish Treatment: Anodized/PVD
Typing Angle: 7.6°
Front Height: 19.3mm
Gross Weight: Around 10kg
Dimensions: 375.9*172.1*46.6mm
Case Material: 6063Aluminum
Mounting Style: Top Mounting/Silica Gel Particle Mounting
Default PCB: 1.6mm Tri-mode non-flex cut PCB
Default Plate: Alu Plate
Supported Layouts: ANSI, ISO
RGB Support: Yes
VIA Support: Yes
Hotswap Support: Yes
Battery Capacity: 4000mAh*2
Connection Methods: USB/BLE/2.4G
Bluetooth PCB Polling Rate: 133Hz
2.4GHz Polling Rate: 1k
Wired Polling Rate: 1k
OS Compatibility: Win/Mac/Linux/Android
Standard Edition and Bespoke Edition
Difference between the NAMA Standard Edition and the Bespoke Edition
Avaible for Public GB
- The NAMA Standard Edition comes in a fixed configuration for the top and bottom cases, though the movement edition is selectable. It does not include switches and keycaps.
Priority given to our Precious Wuque old friends, who have supported us ever since 2020.
- The NAMA Bespoke Edition offers full customization, allowing you to choose the top case, bottom case, movement edition, plate, sound-dampening foam kit, and you can also choose or not to choose switches or keycaps available from the Wuque official website and have your NAMA prebuilt. If you choose available switches and Keycaps from the Wuque website, the added cost will be 80 USD more as a bundle.
We have to say that Nama is more of a design we create for our community, who comes along with us from Ikki68 (thanks again to Ikki68 OG guys!), Aurora, Mammoth, all the way till today. We will email you a Google form with colors, parts, and price for purchasing your Nama before GB time. Every order will have our special service team to follow your order before ordering, during the making process, during the wait for delivery, and after delivery. Check more details in the later part.
Here's what you need to know about ordering the Standard Edition
NAMA Standard Edition Parts and Color Information Sheet
NAMA Standard Edition Price
NAMA (Alu Bottom case+Standard Flywheel Edition)- 749 USD
NAMA (Brass Bottom case+Standard Flywheel Edition)-899 USD
NAMA (Alu Bottom case+Tourbillon Edition)-1149 USD
NAMA (Brass Bottom case+Tourbillon Edition)-1299 USD
NAMA Standard Edition Video
Midnight Blue
Crimson Royale
Nova Frost
Titanium Shadow
Rose Quartz
Emerald Dusk
Amethyst Night
Lunar Silver
Violet Whisper
Noir Eclipse
How to Order Your NAMA Bespoke Edition
NAMA Bespoke Edition Units
A limited run of bespoke NAMA keyboards comes with dedicated one-on-one service from Wuque Studio. Upon securing a unit, you will receive a personal configuration form and customize the components below.
A glance at what you can customize here
- Ten Top case colors
Midnight Blue, Crimson Royale, Nova Frost, Titanium Shadow, Rose Quartz, Emerald Dusk, Amethyst Night, Lunar Silver, Violet Whisper, Noir Eclipse
- Nine Bottom case color
Brass Material: Silver, Gold, Black
Aluminum Material: Gunmetal Gray, Anodized Black, E-White, Gold, Dark Gray, GT Silver
- Two Movement Edition
Tourbillon Edition and Standard Flywheel Edition
- Six Plate Options
PC, POM, FR4, Alu, Carbon Fiber, Brass
- Curated Switch & Keycap Options
NAMA Bespoke Edition Price
The Bespoke Edition carries an approximate $80 premium, with official switches and keycaps pre-installed. If you don't want to have the keycaps and switches, the cost will be the same as a standard edition's, just with more flexible customization.
Vendors
International & China:Wuque Studio
US: Cannonkeys
Canada: Mech. land, Deskhero
South Korea: Swagkeys
Singapore: iLumkb, RF Gaming
Japan: INNOTECH株式会社 (Prebuilt with WSPBT WOB only)
Taiwan: Inpad
DE: Keygem
Italy: Coffeekeys
AU: KeebzNCable
VN: SoiGear
UK: ProtoTypist
List will keep updating
NAMA Live Streams & Videos Launching Schedule
Streaming
12/5 xinxinwong - Rose Quartz [Standard Flywheel Edition]
12/8 LightningXI - Midnight Blue [Standard Flywheel Edition]
Videos (Schedule maybe updated)
Wabisabi - Titanium Shadow - Live at
[Tourbillon Edition]
12/9 Alexotos - Lunar Silver
12/3 markerchun - Lunar Silver
12/3 TyCottle - Emerald Dusk
12/5 strawberryjam1986 - Rose Quartz
12/6 Hiypo - Emerald Dusk
12/8 xinxinwong - Rose Quartz
12/9 Daihuku Keyboard -Titanium Shadow
12/9 gamebynight-Nova Frost
12/10 LewisToh - Crimson Royale
12/11 KeyboredScott - Crimson Royale
12/12 bigdeeer - Nova Frost
(TBD) Scooped Bar - Nova Frost
12/17 LettersEF - Violet Whisper
Questions
If you have any questions, please feel free to contact us:service@wuquestudio.com, or join Wuque Studio Discord.
Thank you!
« Last Edit: Wed, 10 December 2025, 20:33:19 by Ckeeb »
