Author Topic: [GB] DCS 9009 Fix Kit (December 10th 25-Jan 11th 26)  (Read 5998 times)
Offline cartersrush
    • Discord
« on: Sun, 14 December 2025, 04:14:08 »
Hello GH and fellow DCS 9009 cucks enjoyers , this is a fix kit for DCS 9009 for those who were not happy with some of the decisions made during the GB and never got replacements for the thick quote key from vendors.
Originally this was going to be a private run but I figured I'd make it open to the everyone.
GB Period- 10th December 2025 to 11th January 2026.
Starting @ 50 sets $10.28 per set, this is running like a traditional GB if we reach higher MOQ's then the price will decrease
ETA end of Feb if no delays take place
Proxies-
NA- Blacksimon
UK & EU- Prototypist
Asia & RoW- Geon.works (will be sold instock)
Oceania- KeebznCables
Quotes-
10 sets $23.57 per set
15 sets  $18.03 per set
20 sets  $15.26 per set
25 sets $13.60 per set
75 sets  $9.17 per set
100 sets   $8.62 per set
IC Form
This kit requires you to already own the Gorton Base Kit and Extensions Kit NOT Intro Beige.
It will include-
1x R1 1u Backspace (just the icon)
1x R1 1u Numpad Equals Key (wasn't part of the base/extensions kit)
1x R1 1u Scroll Lock LED  Key (wasn't part of the extensions kit)
1x R1 1u Num Lock LED Key (wasn't part of the extensions kit)
1x R3 1u Thin quote Key (to replace the ugly thick quote key that some vendors never replaced)
1x R3 1u Dimple/Nub Numpad 5 key (its just better)
4x R4 1u Left aligned arrow keys (centered arrow keys shouldn't exist)
1x R4 Numpad "00" Key
Board Renders
Dino 104
If you want caps lock leds for Intro join the DCS LED Keys GB.
If you want Small convex bars,10u spacebar and BAE purchase them from sneakbox.com
My accent kits with a lot more colour options that match DCS Beige,WOB,Dolch and BOW are now instock at SP
No other keys will be added since this is A FIX KIT and I would like to keep it as cheap as possible
Thanks to all the vendors for running this project.Ultimately this is a community project and nobody is making a profit out of this, aside from covering costs ofc.
Contact - @ cartersrush
Join my Discord if you want to
« Last Edit: Fri, 19 December 2025, 01:18:20 by cartersrush »
Offline cartersrush
    • Discord
Re: [GB] DCS 9009 Fix Kit (December 10th 25-Jan 11th 26)
« Reply #1 on: Fri, 19 December 2025, 01:24:50 »
reserved
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #2 on: Wed, 24 December 2025, 16:57:20 »
« Last Edit: Sat, 10 January 2026, 15:34:01 by dvorcol »
Offline dvorcol
« Reply #3 on: Sat, 10 January 2026, 15:32:28 »
Edit: corrected 75 date
« Last Edit: Mon, 12 January 2026, 14:43:38 by dvorcol »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #4 on: Sun, 11 January 2026, 10:49:37 »
Joined, ty
« Last Edit: Sun, 11 January 2026, 11:10:54 by LightningXI »
Offline dvorcol
« Reply #5 on: Mon, 02 February 2026, 15:33:03 »
Edit: KeebzNcables & proto[Typist] now end Feb 4
« Last Edit: Tue, 03 February 2026, 18:32:09 by dvorcol »
Offline dvorcol
« Reply #6 on: Mon, 02 February 2026, 16:29:00 »
FYI, a matching DCS 9009 Caps Lock Kit GB is running from 19 Jan thru 4 Feb 2026
NA: BLACKdrop
UK & EU: proto[Typist] - Fix Kit also available
Oceania: KeebzNcables - Fix Kit also available
« Last Edit: Tue, 03 February 2026, 18:40:32 by dvorcol »
