Author Topic: [GB] Shy60 by NBH x shy  (Read 23210 times)
Offline atkins
« on: Tue, 30 December 2025, 05:20:57 »
[GB]Shy60 - gasket strip mount
GB has started!
Price, Timeline  and Status
Price and Timeline
  • Price: 365€/400$
  • Extras: PCB’s, plates, weight customization if bought over NBH
  • Sales format: Group Buy
  • GB period: 15th December until 31st January
  • Fulfillment Q3-Q4 2026
Vendors:
North America: bowl keyboards
Singapore and SEA: ktechs
South Korea: Swagkeys
Europe and rest of the world: NBH
About Us
NBH - neighbourhood
We’re a small group of keyboard enthusiasts from Germany who care about every detail of this hobby but especially the social part and connecting with the community—because in the end, that’s what makes it special. Over the past few years, we’ve organized several smaller group buys of up to around 30 participants and now we’re ready to take the next step: connecting not only with our local scene, but with the international community as well.
Our designs are built with the community in mind: fully compatible with standard PCBs, with plate files made freely available, and absolutely no gatekeeping. We want everyone to be able to build, mod, and enjoy—without limits. At a fair and affordable price (considering the low quantities we operate at). That’s the way this hobby should be in our eyes.
That’s why we came together to form our growing community space, Neighborhood (NBH). It’s more than just a place to share our own projects—it’s also a platform for small designers to showcase their ideas, exchange feedback, and even get support in organizing group buys
About the keyboard
Some of you may already know Shy. He is a young and aspiring keyboard designer from Germany who has been active in the maker community for several years now. We have always admired his knowledge, dedication and especially his skills and design language.
The Shy60 is the culmination of various iterations with different mounting styles and variations in stylistic approaches. Shy has forged his design language through countless scrapped and prototyped designs.
We think that the Shy60 is worth sharing with the keyboard community.
Project Details
Keyboard
  • Layout: 60%, WKL, HHKB, WK
  • Typing Angle: 8 Degrees
  • Front height 18.5mm, adjusted front height 19.64mm, ekh 23.8mm
  • Weight unbuilt around 1950g
  • Gasket Strip Mount and Top Mount
  • Color options are black, silver, master chief (grey-green) and burgundy (dds-m)
  • Plate options: alu, polycarbonate, carbonfiber
  • Manufacturer: dds
Material
  • Top and bottom: aluminium
  • Plate: 1,5mm aluminium
  • Weight: brass
Kit
  • Keyboard
  • Plate (alu)
  • PCB (waffling60 JST position), unified db, custom JST cable
  • Custom Carry Case
  • Custom Cloth
Gasket strip Mount
  • The principle is derived from the Papilio tkl (Link)
  • The plate sits between 2 gasket strips.
  • Clean sound and nice feel, you can use different gasket strips to adjust sound and feel as you like.
  • Principle explained
  • Short video showing the mounted plate + pcb in the top (it holds very well)
Top Mount
  • We use a custom-made insert that makes up for the distance of the missing gasket to screw the plate to the top.
  • Typical top mount feel and sound
    Layout
  • Top: WKL, HHKB, WK
  • Solder PCB: 7u bottom row, ISO/ANSI, split bs, split right shift, split left shift, stepped caps lock
Pictures and Sound Test
Pictures taken by Ken
(www.instagram.com/kenguru_kbd / https://www.youtube.com/@kenguru_kbd)
Photos and renders
More pictures of prototype 2 on IMGUR
More rendered images on IMGUR
WK, HHKB and PC top renders
More Links
Album with more pictures of prototype 2
Album with pictures of prototype 1
Soundtest of prototype 2 - by Kenguru_KBD
Additional content and streams from Swagkeys and ktechs will follow in the upcoming weeks and will be announced in Discord, so make sure to join!
Stay Connected
« Last Edit: Tue, 30 December 2025, 05:47:57 by atkins »
Re: [GB] Shy60 by NBH x shy
« Reply #1 on: Fri, 02 January 2026, 11:28:46 »
Does this accept universal 60% PCBs?
Offline incrediblejr
« Reply #2 on: Fri, 02 January 2026, 11:36:58 »
PCB uses Waffling JST placement, so 4pplet's Waffling60.
Offline atkins
« Reply #3 on: Sat, 03 January 2026, 02:53:12 »
This is correct. Reasoning behind this decision: we are European based and waffling PCB is what is most readily available to most of us. If you use a PCB with molex or JST-Sur you can use PCB with different JST positions as well.
Offline momentoily
    • geometry dash meltdown
« Reply #4 on: Mon, 12 January 2026, 19:20:10 »
Really nice design—especially the dual mount option. Curious how different the gasket strip feels compared to top mount in daily use?
Offline atkins
« Reply #5 on: Sat, 17 January 2026, 10:54:51 »
Swagkeys is buying out MOQ and offer these units instock after GB at a lower price!
Gasket mount offers a softer typing experience. Our top mount implementation has the benefit of being better isolated from the case due to the adaptor which is made from a softer material.
« Last Edit: Sat, 17 January 2026, 10:57:19 by atkins »
Offline snifferz23
« Reply #6 on: Mon, 19 January 2026, 17:03:25 »
Hey there, really into the design of the project! Just wanted to ask if you could let me know what this keycap set is called from your proto 2 photos: https://imgur.com/a/shy60-proto2-GHwSN3J#qjXMeS5
To clarify its the pink on beige set in JP. Thanks in advance!
Offline Ceyx
« Reply #7 on: Fri, 20 February 2026, 04:06:36 »
Connectivity type?
Offline mir3
« Reply #8 on: Tue, 02 June 2026, 04:59:44 »
The shape and structure of this keyboard are much loved. It's a pity the group buy was missed. Hopefully, one can still be purchased. This design is truly nice.
