Author Topic: [GB] DCS Superweld | Jan 2nd - Jan 30th  (Read 15880 times)
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« on: Thu, 01 January 2026, 20:05:38 »
DCS SUPERWELD
INTRO | KITTING | RENDERS | AVAILABILITY | MISC
315686-0
Glad to finally be bringing this set to everyone!
Superweld is a keyset by me and Neely that puts an originative spin on a long lost project.
It features center stepped bottom row keys and sculpted relegendables, as well as a slightly familiar yet non-infringing colourway.
Group buy runs from Jan. 2nd 2026 through Jan. 30th 2026.
315688-1
315690-2
The Base kit has compatibility for 60, 65, TKL, 7u HHKB, terminal ISO, standard and Tsangan bottom rows, plus forced windowed keys for scroll lock and stepped caps lock.
315692-3
The Extension kit has a macro column’s worth of relegendables, plus options for accented and center stepped bottom row keys.
315694-4
The Numpad kit has extended compatibility for full size and 1800 keyboards.
315696-5
The Spaces kit has convex spacebars for Alice and 3-1-3 configurations. The 10u spacebar is compatible with any board that uses a 7u spacebar that has a 1.5u bottom row key on either side.
315698-6
315700-7
315702-8
Eerie by me (note: blue arrow/code keys not included in set)
315704-9
315706-10
throne by hali
315708-11
315710-12
21XX by Pontus
315712-13
Pricing
Base:
$115
Extension:
$35
Numpad:
$35
Spaces:
$35
Vendors
NA:
EU:
UK:
KR:
SEA:
MISC
Tech Specs
- Manufactured by Signature Plastics
- DIN Cylindrical Sculptured
- Doubleshot ABS with some pad printing
- Mix of custom Pantones and SP stock colours
- Please only refer to renders on vendor websites to gauge colours
Thanks
- “are we thanking bunnylake?”
- Melissa from SP
- neely
- hali
- beetles
- zdc
- oco
315714-14
« Last Edit: Thu, 01 January 2026, 20:10:23 by Laur »
Re: [GB] DCS Superweld | Jan 2nd - Jan 30th
« Reply #1 on: Thu, 01 January 2026, 21:08:03 »
Approved :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Thu, 01 January 2026, 21:16:21 »
it's finally back
Offline DirtyGingy
« Reply #3 on: Thu, 01 January 2026, 21:43:27 »
Still not the right colors. Sorry, I can't.
Offline ivanh98
« Reply #4 on: Thu, 01 January 2026, 22:04:05 »
take my wallet
« Reply #5 on: Thu, 01 January 2026, 22:04:26 »
Return of the King!
Offline DirtyGingy
« Reply #6 on: Thu, 01 January 2026, 22:31:46 »
Offline lakeboredom
« Reply #7 on: Thu, 01 January 2026, 23:44:16 »
Wowwww been waiting 3 years for this lol, so excited. I don't thing I've bought a new keyset in all that time.
Offline rayy
  • aesthetics enthusiast.
« Reply #8 on: Fri, 02 January 2026, 08:14:46 »
wow, ive been waiting 3 years and 1 day for this. :p
Offline oddz
« Reply #9 on: Fri, 02 January 2026, 12:12:50 »
Sorry I am not up to speed on the lore of this set and I have some neurotic questions about color. Just trying to get the most accurate sense of how it will look based on IRL reference points.
1. So this is inspired by GMK Hyperfuse but won't be exactly color matched to it?
2. I see SA Hyperfuse exists with specific SP color codes but this will not be using the same ones?
https://matrixzj.github.io/docs/sa-keycaps/HyperFuse/
VBV Blue, RDA Purple, GTL Alpha, GD Mod
3. On the IC this was stated: "Mix of custom Pantones and SP stock colours (GSM mod, alpha TBC with chips on the way)". Is this still true? GSM is darker than GD mod right? And I can't find any reference to a TBC color. How does it compare to GTL?
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #10 on: Fri, 02 January 2026, 12:39:32 »
I think the "TBC" means they're yet to be determined (a typo of "TBD"), depending on how the chips look when they receive them. In SP's color code system, a chip beginning with T means brown, which isn't the case here.
Offline marshmellohs
« Reply #11 on: Fri, 02 January 2026, 15:39:00 »
yay!!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #12 on: Fri, 02 January 2026, 19:02:10 »
TBC = To Be Confirmed
« Last Edit: Fri, 02 January 2026, 19:03:55 by dvorcol »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #13 on: Fri, 02 January 2026, 21:22:02 »
https://i.imgur.com/8LAuwk0.png
it's fine that you're not buying the keyset but you don't have to express it once in the ic and twice again in the gb. if you're that particular about oco's colours you could get a one off from sp or if you just consider originative/typemachina a better designer then you should probably just blow my head off
i got you
inspired by the hyperfuse colourway which came before the gmk run. the gmk colours are just approximations of the original sp colours from gmk's stock palette
no. originative/typemachina purchased the rights to the hyperfuse colourway from the original designer. practically neither party is involved in keyboards currently and oco won't run or allow a run of dcs hyperfuse. sp is being a good business and honouring oco's rights to the colourway, but has explicitly allowed for dcs superweld to be ran
i don't actually know this one but i'll edit this message when i get info
Offline five
« Reply #14 on: Fri, 02 January 2026, 23:05:41 »
Thank God, it finally comes.
I have ordered all the 3 kits from NK except Num.
Offline tacahiroy
« Reply #15 on: Sun, 04 January 2026, 06:06:47 »
Finally, a long wait is over. Thanks for rearranging the GB.
Offline Poesjuh
« Reply #16 on: Mon, 05 January 2026, 04:51:05 »
So if I understand correctly, these colors are neither the original hyperfuse, nor hyperfuse origins colors, nor oco sa hyperfuse colors, and the alpha color sample chip has not yet been recieved?
Don't mean to be blunt, just trying to understand if there are colorchips available, a comparison with any of the older sets and pictures of that as well or that we're buying blind on renders.
Offline VXQN
« Reply #17 on: Tue, 06 January 2026, 02:46:46 »
Is there an estimated delivery window?
Offline YoungManKim
« Reply #18 on: Tue, 06 January 2026, 09:27:23 »
https://novelkeys.com/collections/frontpage/products/dcs-superweld-keycaps
Per NovelKeys' website, estimated delivery is Q2.
Offline thunk
« Reply #19 on: Wed, 07 January 2026, 02:18:52 »
Theoretically in for all kits. ...but would also like to see some color samples so there are no "surprises"
*edited for wording
« Last Edit: Thu, 08 January 2026, 10:35:02 by thunk »
Offline Poesjuh
« Reply #20 on: Fri, 09 January 2026, 08:31:12 »
Tech Specs
Any chance you could answer this Laur?
Offline dvorcol
« Reply #21 on: Mon, 09 February 2026, 19:19:07 »
<-- orders only
