Author Topic: [IC] GMK CYL Melon Cream - added desk mats, new renders  (Read 9357 times)
Offline Shark
    • bord design
« on: Wed, 14 January 2026, 17:09:24 »
Important Links
Interest Check Form
Designer Discord
Description
Melon Cream is a soft, refreshing keycap set inspired by delicious melon milk drinks and all delicious melon flavored goodies.
With the additional Gradient Kit, you can enjoy the subtle transition of colors representing the gradient of the inside of a melon.
Kitting
Base Kit
Hangul Alphas
Gradient Kit
An added gradient kit, featuring a subtle shift in colors representing the gradient of the inside of a melon.
Novelties
Photo of the color samples
Some renders:
Featuring the gradient kit:
« Last Edit: Sun, 01 February 2026, 15:28:48 by Shark »
Offline Shark
    • bord design
Re: GMK CYL Melon Cream
« Reply #1 on: Wed, 14 January 2026, 19:12:48 »
Updates:
  • 1/20:2025: Better photo of the color chips to represent the colors.
« Last Edit: Tue, 20 January 2026, 09:42:03 by Shark »
Offline xjack312
« Reply #2 on: Thu, 15 January 2026, 15:34:31 »
If you're including split bars, I would also include second B for alices
Alice enjoyer
Offline madmax13
« Reply #3 on: Thu, 15 January 2026, 16:26:23 »
GLWIC!
Designer- MTNU Welles, GMK City Pop Neue, DSS Distortion 40s, GMK Distortion, and SA Motorsport Selectric.
Offline Shark
    • bord design
« Reply #4 on: Thu, 15 January 2026, 17:07:54 »
Hi! Yes you are correct, will update. Thank you.
Thank you @madmax13!
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #5 on: Thu, 15 January 2026, 17:41:56 »
GLWIC!
Offline johnkeyboard
Re: [IC] GMK CYL Melon Cream
« Reply #6 on: Fri, 16 January 2026, 03:17:32 »
We will be seated.
Offline P.P
« Reply #7 on: Sat, 17 January 2026, 08:42:29 »
If there are some red ones for watermelon, it would be more interesting. Anyway, really dreamy one!
Offline Shark
    • bord design
« Reply #8 on: Sat, 17 January 2026, 12:29:17 »
Thank you for the comment & feedback, glad the dreamy vibe is coming through!
We will be seated.
Appreciate it!  :thumb:
Offline Shark
    • bord design
« Reply #9 on: Tue, 20 January 2026, 09:13:12 »
My calibrated grey cards arrived, so here is an updated photo that better represents the colors:
A bunch of people requested a melon themed deskmat in the form, so will start looking into it!
« Last Edit: Tue, 20 January 2026, 09:41:05 by Shark »
Offline GMK_Andy
    • GMK
« Reply #10 on: Tue, 20 January 2026, 15:34:27 »
Good luck with your design! If you need any help just reach out  :thumb:
Offline Shark
    • bord design
« Reply #11 on: Tue, 20 January 2026, 17:52:35 »
Thank you! I will definitely take you up on that offer  ;)
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #12 on: Tue, 20 January 2026, 18:43:58 »
Thank you for sharing! Those are Alpha and Mod base colors, right? Is Alpha legend same as Mod base? And what is Mod legend color?
Offline Shark
    • bord design
« Reply #13 on: Tue, 20 January 2026, 19:42:18 »
Of course! Yes these are the alpha and mod base colors. The legend color for the Alphas is 7493 C, a touch darker compared to the Mod base color (2274 C) to help with legibility. I don't have the chip for the mod legends with me at the moment, but that is 4197 C.
Edit: I will take a new photo of all the chips I have tomorrow and share, so it's easier to visualize the set.
« Last Edit: Tue, 20 January 2026, 20:15:01 by Shark »
Offline Shark
    • bord design
« Reply #14 on: Mon, 26 January 2026, 13:27:25 »
Photo with all the color chips. Taken inside, indirect natural/sun light.
I don't have the chip for mods legends nor the first two rows of the gradient from the mods. 2274 C is such a tricky color to photograph, a lot more green to the eye vs this white balanced photo.
Making some progress on the dark mat, currently evaluating standard rectangle and a melon slice shaped (think crescent shape) mat . If you had opinions on either, I'd love to hear!
Offline Shark
    • bord design
Re: [IC] GMK CYL Melon Cream - now with desk mats!
« Reply #15 on: Thu, 29 January 2026, 22:42:57 »
As mentioned above, got a lot of requests for a matching desk mat to go with the set. Wanted to share the three I love:
Fractured
A more abstract representation of a melon slice.
Subtle Inside
Slightly more subtle, a nice gradient from dark to light green matching the keycaps.
Treats
Matching the novelty kit, a fun pattern of all the tasty melon flavored / inspired treats.
Offline GMK_Andy
    • GMK
Re: [IC] GMK CYL Melon Cream - added desk mats
« Reply #16 on: Fri, 30 January 2026, 10:49:14 »
The mats and set are looking great together  :thumb:
Offline Shark
    • bord design
« Reply #17 on: Sat, 31 January 2026, 21:52:19 »
Thank you! Agreed, they go so well together.
Small update from me: Added better renders.
Offline Shark
    • bord design
Re: [IC] GMK CYL Melon Cream - added desk mats, new renders
« Reply #18 on: Sat, 21 February 2026, 00:29:34 »
Wanted to quickly share some data from the IC.
100% of those that filled out the IC loved/wants the base, with 2nd most liked being the gradient kit.
Hangul being the lowest most likely means it'll get the cutting floor.
Novelties is up there, got some feedback in IC, so will work on an iteration of it based on that.
As for the desk mats, from conversations I've seen in Discord, the Treats is the winner so far.
