Author Topic: [GB] NP-R - Numpad Retro. Update on production.  (Read 152486 times)
Offline Bagri
« on: Sun, 22 February 2026, 07:54:35 »
NP-R
Numpad Retro - Bagri x Flatbrains!
Group Buy
5th March to the 1st April 2026.
Old GH IC THREAD
Vendors lists
🇪🇺 Europe - Delta Key Co (Lead vendor)
🇺🇸 US - Bowl Keyboards
🇰🇷 Korea - Swagkeys
🇲🇾 Singapore, Malaysia & SEA - Ktechs.store
🇬🇧 UK - Prototypist
🇨🇳 China - ZFrontier
🇦🇺 Australia - KeebzNCables
🇨🇦 Canada - Minokeys
🇦🇷 South America - LatamKeys
Pricing € £ $
~$215 with aluminium weight // ~$240 with polished stainless steel weight
Might vary depending on your local vendor.
SPECIFICATIONS
  • Aluminium top and bottom cases
  • Polished stainless steel (premium edition) or Raw aluminium (standard edition) weight
  • Typing angle: 7°
  • Front height:
  • Top mount
  • Screws: M3 torx only (except for the solenoid as the electrical component comes with pre-tooled holes)
  • PCB designed by louckousse at Flatbrains! with help from ILWrites - 1.6mm - Compat ZMK
  • Aluminium plate (Color dependant on CW)
  • 3 layers accessible with fixed position knob (you can also rebind so that it switches from one bluetooth device to another)
  • 3 LED showing active layer (configurable)
  • Numlock LED
  • Solenoid switch on/off
  • Wired or Wireless mode (bluetooth only - no dongle)
  • Weight: 1,13kg fully built with alu weight
  • Dimensions: 20,9 x 9,3 cm and 6,5cm in height
  • Layout support (Solder = regular/southpaw/full 1u - Hotswap = regular only):
    Plate compatibility is achieve by being flipped upside down.
PROTOTYPE PICTURES
COLLABORATIONS
If you are interested in collaborating on this product, please reach out on discord @.bagri !
  • Deskmat by Biip
    ~$30 depending on your local vendor.
RENDERS AND COLOR WAYS
Colorways (and theoretical RAL for custom colors):
#1 - Beige (e-coated, RAL-1013)
#2 - Green (anodized, RAL-6011)
#3 - Orange (anodized) RAL-2001)
#4 - Warm Grey (anodized to match 21XX)
#5 - Baby blue (anodized to match 21XX)
#6 - Black (anodized)
#7 - Silver (anodized) - Check prototype pictures above
Color samples:
Top left = Lime (only used for button and plate in certain color ways)
Top right & Bottom left = orange / Green / Bottom right = E-Beige.
#1 - Beige (e-coating)
#2 - Green (anodized)
#4 - Warm Grey (anodized)
#4 - Baby Blue (anodized)
#4 - Black (anodized)
FILES, BUILD GUIDE AND MANUAL
FAQ
1. What is included in the box?
    - NP-R top case, bottom case, weight and Plate
    - All needed screws, standoffs, washers etc.
    - Layer Knob
    - Solenoid Switch
    - PCBs, daughterboard, JSTs and other electrical components
    - Battery
    - Rubber feets
    - LED diffusers
    Please note the following are NOT included:
    - Keycaps
    - Stabs
    - Switches
2. How many units will there be?
    This is a group buy. No further GB round is planned yet.
3. Do you have a discord? How to contact you?
    You can discuss about the NP-R on Flatbrains! discord. You can also contact me directly (.bagri) on discord, or on my instagram.
4. Have you designed other things?
    My first project was the GMK Alt grrrrr kit.
    Flatbrains! have designed many other projects including the Plaket XL.
Based on IC form questions:
- About adding PC option: This won't be implemented at this stage for cost reasons.
- About the button and knob: To clarify: the button is a toggle on/off for the solenoid. The knob has 3 fixed positions to change between 3 layers. That doesn't prevent you from mapping additionnal layers on the keys like a regular keyboard.
- Regarding Mac/Windows compat: Yes, it is, like any other ZMK board.
- Regarding Southpaw and bluetooth: Yes, both included. Refer to the specs :)
- Regarding bluetooth vs wired only: The NP-R still be usable if you physically disconnect the battery and decide to use it only wired. It also works in wire mode with the battery connected.
- Regarding hotswap PCB: Unfortunately no. There are other electrical components to be soldered to the build besides the switches, so in my view there is little point in providing a hotswap PCB.
- Regarding extra parts: The below parts will be available to purchase as extras:
  • plate (orange and lime color),
  • button cap (orange and lime color),
  • PCB (including spare numlock LED, solenoid and all JST - but no battery),
  • weight (raw alu and STS),
  • Feets
MEDIAS AND BUILD STREAMS
- Typing test by Zyrophr
- Build stream by Zyrophr
https://www.twitch.tv/videos/2704708658?t=0h0m1s
- Build stream by Jae at Prototypist
https://www.twitch.tv/videos/2717377288?t=0h0m1s
- Build stream by Bowl later this month...
INSPIRATIONS, CONCEPT AND STORY
HISTORY
28.02.24 - Idea and initial drawings
10.03.24 - Discord private chat created with Flatbrains! (initial idea pitch)
19.05.24 - Discord public channel created
23.05.24 - Public project annoucement - 3D printed prototyping
19.10.24 - PCB proto 1 order
25.04.25 - PCB proto 2 order
27.05.25 - Public IC
19.06.25 - CNC prototype order
January 26 - CNC prototyping, pcb prototyping and firmware design completed
05.03.26 - GB launch
Thanks,
to my friends at flatbrains!,
    louckousse for pushing all the limits and never giving up on any aspect of the PCB,
    and Plaketdebeur, for his experience and advice,
to Druz, for the firmware and his help with everything,
to kustom3 for the *KAAS* and his constant, thoughtful advice - all the time, on everything,
to LucasAlt for guiding me through my first steps on Fusion more than two years ago (don’t look at the timeline, please),
to ILWrites for his crucial help on the PCB,
to Puree, for his sharp suggestions,
to Guillaume, for his help and support,
to all our vendors for their commitment to this project,
to Zyrophr and Blivion, who were the first to see a ****ty sketch and still believed in the idea,
to everyone who contributed - directly or indirectly - and to all the hobbyists supporting this project.
It wouldn’t have been possible without all of you <3
Contact: .bagri on discord
https://www.instagram.com/bagri_shoot
Bagri - 2026
« Last Edit: Mon, 01 June 2026, 03:24:21 by Bagri »
Keyboard photos - https://www.instagram.com/bagri_shoot
Working on the NP-R -  https://bit.ly/NP-R
Designer of the Alt grrrrr kit - https://bit.ly/altgrrrrr
Offline Bagri
Re: NP-R - Numpad Retro. GB 5th march
« Reply #1 on: Sun, 22 February 2026, 07:55:18 »
UPDATES
04.03.26
- Added a hotswap PCB option: Layout support (Solder = regular/southpaw/full 1u - Hotswap = regular only):
- We have also planned for a PCB assembly service so that electrical components that needed solder previously will be factory soldered instead. This means no soldering iron is needed at all for the build if you're taking a hotswap pcb and the build with a solder pcb just got easier. Only the numlock led remains to solder in all scenarios as this is optional.
- Plate, firmware and pcb files will be open source at the end of the GB.
25.03.26
MOQ has been met ! 100+ units sold ! Thank you for your support !
One week left to join, don't miss out  :thumb:
01.06.2026
Hello everyone !
We've been quiet since the end of the GB so  here is an update for you on how things are progressing.
TLDR: all is good, production is starting :)
The below is a "journal" of the backstage if you're interested to know the process in detail:
- Following the GB end, it took a few days/weeks for vendors to input all their numbers to a google sheet
- Once we got the final numbers for everything, we had to go back to each supplier and manufacturer to lock their prices. Some suppliers are updating their pricing daily/weekly based on the market so we couldn't do that until ready to pay.
To give you an idea, we are talking about 4 manufacturers (CNC machining and anodization / rubber feet, silicon insert and foam pads / packaging boxes / and PCBs fab) and 4 suppliers (batteries, electrical components, solenoid, hotswap sockets)
- Hongtu agreed to pay upfront for most suppliers that had regular updates on their prices otherwise it would have been impossible to know how much to charge vendors back as by the time a vendor would pay his invoice, the price would have changed.
At the same time there was then a big accounting to do to charge back the correct amount to each vendors. Basically, 4 manu + 4 suppliers to be charged on 9 vendors with different quantities... That was a hell of a job.
- Once this was sorted invoices for pre-payment were sent to vendors and most of them have now been paid - the remaining are in the process of being taken care of.
- Hongtu has advised the raw material have been ordered and production will start as soon as it's been received.
- Production of batteries is completed and these have been shipped to Hongtu this morning.
- All packaging boxes have been produced but waiting for the EVA foam cutting to be completed before final assembly of those. All stickers have been made.
- Production of rubber feets / foam pads / silicon insert is nearly completed.
That's all for now  :thumb:
23.07.2026
Hello everyone !
- CNC Machining has begun.
   There was a slight delay as the raw material received from the supplier wasn't good enough for the manufacturer's quality expectation initially so they re-ordered it - all for the best. New batch has been received and is now being machined.
   Manufacturer is expecting to do the surface treatment and finishes (anodizing and coating) around mid august.
- Pre prod unit of the packaging has been received and validated - packaging is being printed now.
- Batteries, solenoid, feet, force break foam and silicon insert have all been completed and delivered to the manufacturer.
- Pre prod units of the solder and hotswap PCB have been received today - small issue on the solenoid function which we are currently addressing - everything else is perfect and works as intended
- Deskmat sample has been approved and production is starting.
Have a wonderful summer everyone ! Will keep you updated as things progress but next update will probably be in September.
Cheers
04.09.2026
Hello everyone !
I hope everyone had a restful summer :slight_smile:
- CNC Machining is still ongoing. E-coating of the Beige units is almost completed. Anodization has also begun.
- Packaging is completed and ready to be shipped to the manufacturer. Due to stockage volume, it will only be sent last minute.
- Solenoid issue has been solved and impacted on all PCBs. All PCB are now completed although about 25% of the rotary encoder components came from a defective batch. Fab has ordered replacement components and is currently replacing them on the concerned PCB units.
All units are thoroughly QC to ensure all functions are working properly.
- All other bits and parts are delivered and ready for final assembly in the box.
- Shipping to customers is still estimated for Q4.
Have a good weekend !
Cheers  :thumb:
07.10.2026
Hello everyone ! It is now Q4! So I guess the main question is *WHEN ?* Well... here is the finish line ...:
- CNC Machining is completed. Beige, silver, green, orange, black and silver units are fully completed. Last warm grey and baby blue anodized units are being done now and expected to be completed sometimes next week.  :thumb:
- Plate, rotary cap, weight etc are all done as well, we are only missing the white enamel in the solenoid button cap small dot as this is a separate surface treatment. This should also be completed in the next week or two.
- Packaging boxes have been received and ready for final packing.
- Rotary encoder faulty components have been replaced on all PCB. Everything was re-tested and is fully working.
- All PCB have now been shipped to the manufacturer for final assembly and should be received by the end of the week.
- I will send the manufacturer packing instructions this weekend. Due to the amount of components, I have asked they send a video of one unit being packed to check how it's done.
- Final packing for all units should start the week of the 19.
Have a good day!
Cheers
« Last Edit: Wed, 07 October 2026, 03:34:24 by Bagri »
« Reply #2 on: Tue, 24 February 2026, 15:20:47 »
Approved :thumb:
Offline Raie_de_Boule
« Reply #3 on: Tue, 24 February 2026, 15:24:51 »
I'm in, oui.
Offline BlivionIaG
« Reply #4 on: Wed, 25 February 2026, 13:49:33 »
Imagine not having one more fancy paperweight on the desk :D
Se ruer, se ruer, se ruer
Offline Bagri
Re: [GB] NP-R - Numpad Retro. GB 5th march
« Reply #5 on: Fri, 27 February 2026, 05:35:21 »
Typing test by Zyrophr:
Twitch Build stream by Zyrophr:
Twitch Link
Offline FoxandFoundry
« Reply #6 on: Sun, 01 March 2026, 18:48:24 »
Any chance of offering a hotswap PCB? I swap out my switches all the time and having solder only is a huge letdown.
Offline Bagri
« Reply #7 on: Mon, 02 March 2026, 03:49:55 »
Unfortunately we decided not to offer hot swap pcb for this project. There are a few other electrical components so be soldered on top of the switches so you would need a solder iron anyway. Millmax can be an option if you'd like to change switch often and if you're in europe and buying from DKC I know they plan to offer a build service. I'll ask for the other vendors :)
Offline Bagri
« Reply #8 on: Wed, 04 March 2026, 09:57:27 »
Well.. in the end we added a hotswap pcb last minute  :thumb:
I didn't think we would have the time but here we go  :cool:
04.03.26 UPDATE
« Last Edit: Thu, 05 March 2026, 16:28:53 by Bagri »
« Reply #9 on: Wed, 04 March 2026, 21:02:13 »
04.03.26 UPDATE
That is fantastic news. Thank you!
Offline Bagri
Re: [GB] NP-R - Numpad Retro. GB LIVE - HOTSWAP ADDED
« Reply #10 on: Fri, 06 March 2026, 11:05:54 »
NP-R Colors - Which one will you get?
https://www.youtube.com/shorts/5BE352fzanw
Offline Bagri
« Reply #11 on: Sun, 08 March 2026, 18:04:55 »
Build stream by Jae at Prototypist:
Offline Bagri
« Reply #12 on: Wed, 25 March 2026, 04:45:56 »
25.03.26 UPDATE
Offline Bagri
Offline Bagri
Re: [GB] NP-R - Numpad Retro. MOQ MET, 100+ units sold, ONE WEEK LEFT !
« Reply #14 on: Mon, 01 June 2026, 03:23:54 »
01.06.2026 UPDATE
Hello everyone !
Offline Bagri
Re: [GB] NP-R - Numpad Retro. Update on production.
« Reply #15 on: Fri, 24 July 2026, 04:55:17 »
23.07.2026 UPDATE
Hello everyone !
Cheers
Offline Bagri
« Reply #16 on: Sun, 06 September 2026, 11:18:58 »
04.09.26 UPDATE
Hello everyone !
Cheers  :thumb:
Offline Bagri
« Reply #17 on: Wed, 07 October 2026, 03:33:48 »
07.10.26 UPDATE
Have a good day!
Cheers
