Author Topic: LARD keycaps: A breakthrough in DIY lettering  (Read 35713 times)
Offline Hak Foo
  • Make America Clicky Again!
« on: Sun, 22 February 2026, 18:58:23 »
We've had various experiments with "using laser engravers to make custom keycaps" for over a decade.  But in general, this either meant one of two things:  You milled into the keycap so you got a sunken texture but no real contrasting lettering, or you fused toner or ink into the surface of the keycap so you got a darker lettering.
But you could hardly do light figures on dark caps.  Until now.
The other missing piece of the puzzle was the old experiments in using off-the-shelf fabric dye to recolour off-the-shelf caps.
This tends to sink into the PBT material only at a very superficial level, so if you use the laser to vapourize the the top tenths of a millimetre of plastic, you cut through the dyed surface back to the original light keycap.
Hence the term:  Laser Ablated Reverse Dyesub (LARD).
This is also reminiscent of some of the early "shinethrough" keycaps (Deck/TG3) where there was a thin coloured layer that was cut through to create the transparent glyph.
I've tried it with some cheap white PBT caps (apparently a Massdrop offering for some old Preonic group-buy).  I selected it because I wanted different row keys, and it was cheaper than buying a full 108 setup.  Unfortunately, it has way more bottom-row caps than I need but a shortage of top-row so I'll probably have to get more caps to finish the top row.
Used the common Rit DyeMore they sell at Walmart, with some salt (not sure if necessary), then heated up in a disposable aluminium pan.  The first few caps went in before it got to temperature and took like 15 minutes to darken, the rest took far less time.
316163-0
316165-1
I then used my little NEJE DK-8 engraver with a 1500mW head.  This is one of those toy-engravers made from the mechanisms of DVD-ROM drives, so you only get limited control (raster image, and a "burn time" control instead of a power level.  I tried with 80ms/dot, 90ms/dot and 100ms/dot withiut significant difference in outcomes.  I'd suspect the sweet spot is "enough to burn through the dyed material that absorbs the laser well, without too much darkening of the underlying white PBT once you break through" and "not so long that it starts to blur the overall image".  There may be better tricks with more sophisticated lasers.
When it comes off, there's often a dust halo, probably some portion of the dyed PBT vapourising and precipating back to surface.  Use hazard precautions.
316167-2
The overall look is probably "as good as the keycaps on my original Ducky 1008XM, at least" (Its lasered caps started as a weird bronze colour and aged poorly).  I'm not sure how they'll fail-- the dye might rub through on other areas of the cap, or it might accumulate filth in the engraving.  The characters can be felt because of the depth of engraving, it reminds me of the old Chicony rubber-dome my parents used for like 15 years where they had worn the filling out of some of the engraved legends.
316169-3
Possible directions for future research:
* I'm assuming black dye is the best case scenario for this-- most likely to soak up the laser and burn through.  How well do other colours fare?  What about using other colours "underneath" the dye?
* Tuning the dying and lasering process for maximum contrast or preferred and repeatability.
* Followup cleaning or treatment processes to try to clean out the engravings and maximize contrast.
* Combining the engraved characters with paint or other filler to enhance contrast or change wear patterns.    I've drilled fairly deep with the laser before, but I've never been able to get results I liked from filling processes.  Maybe "bootstrapping" it with the bleed-through base colour will help.
Overton130, Box Pale Blues.
Re: LARD keycaps: A breakthrough in DIY lettering
« Reply #1 on: Sun, 22 February 2026, 20:08:42 »
Nice!
I haven't tried dyeing keycaps in a long time but when I did the "Black" dye I used only made the keycaps brown. It apparently contained multiple pigments and only the brown was potent enough to dye plastic. Good to see that there is a dye that works!
Did you use some kind of double-sided tape to stick the keycaps to the bed when engraving?
Offline Hak Foo
« Reply #2 on: Sun, 22 February 2026, 20:14:02 »
I have an old Gateron Green switch I permanently mounted to the engraver bed, so I just mount the cap to that for consistency.
Offline Hak Foo
« Reply #3 on: Mon, 16 March 2026, 01:29:13 »
Some followup with additional experimentation:
It seems like there are several factors that impact the quality of the result:
* Burn time/setting.  There's a bit of a less-is-more factor there.  Longer burn times seem to lead to blurrier, more ragged results.  I was getting decent results with one or two runs at 30ms or 40ms.  (see onwards)  Going up to much higher amounts didn't materially increase contrast.  In some cases it might have overcharred the material underneath.
* Dye choice.  I tried a mix of "frost grey" and "graphite", and it produced (on different keys) either grey or brown.  This seemed to be more receptive to lasering than the pure black (or mostly) "graphite" dye, on one type of keycaps.  I suspect this is a very analogue process-- how deep the dye sinks in could be impacted by exactly how long it soaked and what concentration is used.
* Keycap stock material.  I had two sets I mixed, which could be identified due to how their mould info was labelled and slight artifacts of the cast.  One was very prone to ablation-- you could see the dust kicked off on a single 30ms run-- and it produces much higher contrast results, which could be mistaken for doubleshot or commercial lasering from distances of over 5km.  The other seems way less prone to kicking up dust, and produced a lower-contrast result.
* Content choices:  It seems to favour bolder content-- delicate hanzi or fine line are may not render as well as bold glyphs.
* I had a few blanks in different colours I threw into the machine, and the results ranged from terrible to vaguely detectable.  I suspect part of the issue is that many of these might be the "low ablation" material, so
* Texture.  The one with worse contrast performance has a rough-grained texture that makes it a bit more "sparkly" when dyed.  This seems to make for worse contrast and it *might* be improved by sanding it down a bit with a melamine "eraser" sponge.
Offline Hak Foo
« Reply #4 on: Wed, 29 April 2026, 01:15:00 »
I've done a few more rounds, and some further insight:
* Perfect focus may be suboptimal-- at least with this 'raster' laser-- you can see the lines between rows with some burns, but if you slightly defocus the laser, it disappears.  Ramping up the burn time might help too, as that likely provides enough heat to expand the area ablated.  Someone with a more professional laser might have some interesting research options.
* The dye reproducibility is poor.  Dump 20 identical caps into the same batch, and some will come out notably lighter.  It seems to be very prone to "dark touch surface, lighter sides" effects too, making the caps look sort of like cheap no-name "five side dyesub" sets.  Maybe a longer dye soak or a more precise dying process could help to "fill out" the colour, but I worry there might be a point where the dye "overpowers" and you end up shooting past the expected colour, or just seeps in deep enough that it can no longer be reliably ablated.
* The level of laser output required for a good burn through varies *hugely* depending on the keycap stock and dyes.  Some require just 10-12ms (and seemingly, they're really prone to smelling awful as it engraves) while others require 40-60ms.  Overburning sometimes results in worse results-- probably charring the underlying material, or grunging up the texture  It seemed like for some caps, you'd even see different performance from top-row versus other rows, or modifiers (maybe they were manufactured differently even if they came in the same bag).  After some sacrificial effort, I've ended up putting the extras in bags marked with notes to improve reproducibly.
* Front legends are an option here, if you can find a good jig to mount the cap.  Since I have a regular keyswitch mounted to my engraver, I mount a sacrificial cap to that, and use masking tape to attach the one I want facing front to one side.
* Beyond a certain point, running two burns of shorter duration-- like two burns at 20ms-- may produce cleaner results than one longer shot.  This seems to produce a less ragged edge.  Again, part of the experimental cycle.
* The melamine sponge does help to an extent in that it adds a matte factor to the overall cap surface that reduces "competition" for the contrast of the engraved characters.  Some caps have a prominent grain that "sparkles" and reduces contrast.
* Dying over a non-white stock cap works to an extent, but you have to expect even lower contrast.  It's never as good as doubleshot and that's even worse.
* The engraver mechanism may have resonance vulnerabilities.  I found I had a lot of issues with an uppercase "M" getting distorted even after several runs-- I suspect that it was jerking the engraver head in just the right way it keep it out of alignment when the next pixel was due.  This smells like a part working loose, and the whole thing is held together with the one size of Allen bolt that I don't have a driver for. :P
I suspect this mostly fits in a narrow economic niche.
For a full set, a proper dyesub offering like Yuzu is probably better.  Yes, if you've got the process down, you could buy a $20 set of PBT blanks and a $10 worth of Rit and produce a more-or-less workable output, but the results will be B-tier and it requires a lot of handholding and tweaking.
But if you need a specific mix of rows and profiles that's widely off from what's available in vendor catalogs-- like the 25 nonstandard caps in my 130% design-- ordering from a custom service may be uneconomical-- you might have to either overbuy to get the desired coverage or buy a bunch of individual caps at $3-5 each.  Similarly, it might be interesting for things like meetup souvenirs where you could bring the engraver and make caps on demand.  If you had a solid supply chain and a good way to vent the fumes :)
Offline Serpenth
« Reply #5 on: Wed, 05 August 2026, 04:33:30 »
* Texture.  The one with worse contrast performance has a rough-grained texture that makes it a bit more "sparkly" when dyed.  This seems to make for worse contrast and it *might* be improved by sanding it down a bit with a melamine "eraser" sponge. This process requires the same level of attention to detail as checking for hidden details in other areas. For example, yesterday I was reading about safety checks for Endorphina casinos when I reached https://programgeeks.net/how-to-verify-the-safety-of-endorphina-casinos/. What stayed with me was the reminder that a familiar software provider does not verify the casino hosting its games. Licensing, operator information, payment rules, and security still need their own checks.
...the laser simply cannot effectively vaporize or alter the surface structure without damaging the substrate itself. As a result, the dye either penetrates too deeply or is washed away along with the unannealed layer, leaving no clear mark.
