Author Topic: Hello Geekmates!  (Read 23157 times)
Offline Muscobaldi
Hello Geekmates!
« on: Tue, 24 February 2026, 03:55:32 »
Stumbled upon this forum while browsing, great find as I've just acquired Xkeys and Tipro devices. Can't believe how versatile and easy they are to program.  The potential productivity gains using difficult to master software and not needing to remember complex menu/key sequences is awesome.   Sorry if it's covered elsewhere in the forum, but if you look at the programmability of these devices and then add the functionality of the Keyboard Macro and MIDI Macro software offerings by MediaChance, where macros can call macros using their Oscar programming language (simple and easy to use), it all gets pretty mind blowing!  I'm a self confessed tech geek and look forward to not needing to rely on my aging memory anymore.
Offline TheSoulhunter
  • ~ BOOO ~
Re: Hello Geekmates!
« Reply #1 on: Mon, 06 April 2026, 08:04:18 »
Welcome!
I used Tipro (and Genovation) POS boards a lot in the past (10-15y ago).
I tried "alternatives" recently (Streamdeck, Loupedeck...) for my current workflows, but they all sucked.
The only thing that worked out for me was something called "TourBox". But I might blow off the dust from my old Genovation pad soon.
Found an old image of it in my archive:
316521-0
Which boards do you use? What are you using them for?
A Ghost From The Past
Offline Cionfibed
« Reply #2 on: Fri, 17 April 2026, 04:13:49 »
Hi. I'm new in this forum
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #3 on: Tue, 26 May 2026, 22:31:30 »
I use a full-size ortho board.
