Author Topic: [IC] GMK Arcade - August 3rd 2026  (Read 98220 times)
Offline Rassles
« on: Thu, 19 March 2026, 02:45:47 »
Arcade
A hit of nostalgia
Introduction
Kia ora and a warm welcome to the interest check for GMK Arcade!
When I got the green light from GMK to run this set, I was beyond excited. Having grown up playing video games and spending time in arcades, this project gave me the perfect chance to reimagine those classics in a fresh way. GMK Arcade is a nod off to a classic theme, revamped with vibrant colours and filled with references to iconic games, all aimed at capturing that nostalgic arcade atmosphere.
A huge thank you to Stellaidoscope, Nonumbers, and MikeyDigit for their incredible hard work and support. This project wouldn’t have been possible without them ❤️
Inspiration
Time-Frame and Pricing
GB: August 3rd 2026
Pricing is TBA.
Colours
Please note that these pantone sheets are just for reference and will display differently depending on how your screen is calibrated. If you want the best reference go to a pantone/paint/print store or buy a pantone sheet of the colours to be certain.
Base: CR
Legends: Pantone 7466C
Mods: Pantone 213C
Accents: Pantone 2592C
Vendors
Oceania - Switchkeys
United States - Divinikey
Canada - Unikeys
Europe - Deltakey.co
United Kingdom - Prototypist
Southeast Asia - Qwertyqop
China - KBDFans
South Korea - Geon
Kits
Base
Novelties
Extensions
Bars and Accents
Numpad
Deskmat
Renders
Please note that these renders are just for reference, please go to a pantone/paint/print store in person to get a real life view of what the colours look like.
Updates
For more consistent updates join my discord
Fixed some of the dixie mods and also added in r4 1u alt in extensions, removed accidental dupe 00.
Updated to a tkl base kit, created numpad kitting, removed double 00 from extensions and blue accents from accents kit to merge into numpad. This is to make the base more affordable and based off the feedback received across various channels interest checks.
Colourmatching update: GMK have received the pantone chips needed to start colourmatching. Once complete they will send through to me to approve. This means that we may see groupbuy end of May/June timeline if all is well.
Colourmatching update 2: Have gone through 2 rounds of colourmatching and unfortunately only the blue has been approved. Currently waiting for a third match of colourmatching for the pink and purple. We are likely seeing an August groupbuy.
Colourmatching update 3: We are going to continue colourmatching whilst the groupbuy is ongoing so that we don't delay this groupbuy any longer.
Collaborations
Namong
If you are interested in collaborating with me or being a vendor, please message me at @rassles on discord or reach out via email at rassleskbd@gmail.com!
« Last Edit: Sun, 02 August 2026, 20:01:46 by Rassles »
Offline incrediblejr
Re: [IC] GMK Arcade - Q2 2026 GB
« Reply #1 on: Thu, 19 March 2026, 03:40:35 »
Yes or yes?
Offline zionsped
    • Simbusped
« Reply #2 on: Thu, 19 March 2026, 06:23:42 »
yes
Offline meowoofun
  • Design Critic
« Reply #3 on: Thu, 19 March 2026, 06:50:23 »
3+ Yes the fact that you included a DDR Novelty makes this an insta buy.
Offline Poesjuh
« Reply #4 on: Thu, 19 March 2026, 13:41:24 »
This looks very familiar. Must have been when I walked through the dark in Miami.
Offline Trackpoint
« Reply #5 on: Thu, 19 March 2026, 18:03:20 »
Similarities to another set aside, would much prefer to have the super keys in base.
Offline Rassles
« Reply #6 on: Thu, 19 March 2026, 19:25:47 »
Haha i’m glad you like it!!!  :thumb:
Offline Rassles
« Reply #7 on: Thu, 19 March 2026, 19:39:39 »
I understand where you’re coming from. Unfortunately Nights is off the table and won’t run again through gmk as the designer is out of the hobby. Although saying this, Arcade was not directly and only inspired by Miami nights (I do love that set though), I went and chose the most vibrant colours at the arcades locally and I went through a few drafts before sticking to this format. I hope that gives some insight! Thanks for commenting!
Offline Rassles
« Reply #8 on: Thu, 19 March 2026, 19:45:04 »
Thanks for your  feedback, currently I’m just seeing how the community responds and based off their feedback I’ll swap to whatever keys are most wanted in the base kit.
Offline Poesjuh
« Reply #9 on: Fri, 20 March 2026, 02:58:00 »
I understand and personally like the set (I do have a set of Miami Nights myself). I also know that Oco was very, VERY adament on Miami Nights not being allowed to rerun back in the days. Hope they won't go "sniping" this set. Having said that, Imo the base kit is solid and the extension kit makes sense. I personally like a proper base kit instead of kut down tkl stuff, so if I were to buy this set I wouldn't want anything changed.
As a small side note: while I'm normally a massive supporter of mod colored pipe and tilde keys, when the base of the set is monocolored you may want to cut those to make room for other keys li ke for example the super keys mentioned above.
« Last Edit: Fri, 20 March 2026, 03:00:47 by Poesjuh »
Offline Rassles
« Reply #10 on: Fri, 20 March 2026, 04:50:32 »
For me i really like having both in base, however you definitely have a point for including supers in base! I’ll see what we can do :)
Offline Hade
« Reply #11 on: Fri, 20 March 2026, 04:56:13 »
Looks sick!
Offline mohit
    • projects
« Reply #12 on: Fri, 20 March 2026, 10:14:24 »
some peak ****, glwic
Offline rayy
  • aesthetics enthusiast.
« Reply #13 on: Fri, 20 March 2026, 17:32:29 »
I see purse caps, i'm invested.  :thumb:
Offline getupbuzz
« Reply #14 on: Sat, 21 March 2026, 01:10:23 »
It would be even better if the black 6u spacebar could be moved to the extension kit, so that the accent kit purely as a touch of color.
Offline Rassles
« Reply #15 on: Sat, 21 March 2026, 02:53:05 »
You make a great point! However I just worry about adding too many keys into extensions as it is already quite beefy. I also think that just having the 6u bar in extensions alone doesn't make too much sense. Thank you for your feedback!
Offline keekeen
« Reply #16 on: Sat, 21 March 2026, 05:17:32 »
looks sick and very well polished! glwic  :thumb:
Offline NotoriousBIGs67
« Reply #17 on: Mon, 23 March 2026, 07:52:43 »
Hmmm its a missed opportunity to me......especially as a die hard Japanese arcade enthusiast
not knocking anyones ideas and hard work , just stating my preference
two of the MOST iconic arcade machines are the Taito Egret 2 and Sega Astro City , and both have very distinct colour schemes...... it could have been a great opportunity for two totally different but great colour schemes. and even within those schemes you could have a player 1 and player 2 variation so lots of scope to play around.
This seems to be just a bright set that bastardises some of the bright colour cues without capturing some of the iconic feel of the retro arcade
any way just my 10cents worth as former home arcade owner.....
Offline tigerali
« Reply #18 on: Mon, 23 March 2026, 14:22:51 »
Less worried about the inspo than the colors; as Miami's not running again I'm likely on board for this set.
Offline Rassles
« Reply #19 on: Mon, 23 March 2026, 17:40:10 »
Sega Astro City is a classic for sure however I felt like Donkey Kong, Street fighters, Space invaders, Astriods, DDR, Pinball etc and the others I used are more well known in my opinion. I would've loved to include pacman/ms pacman but I couldn't think of any ideas that wouldn't lead into copyright lol. Thanks for your opinion anyways
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #20 on: Mon, 23 March 2026, 18:03:02 »
I second Rassles. Also Galaga.
Offline Rassles
« Reply #21 on: Mon, 23 March 2026, 18:24:12 »
How could I forget!
Offline stellaidoscope
    • Stellaidoscope
« Reply #22 on: Fri, 03 April 2026, 18:51:15 »
that key is my magnum opus
Offline Keyboard_Dad
« Reply #23 on: Fri, 03 April 2026, 19:13:53 »
great set! I'm in!
Offline SwitchKeys
    • SwitchKeys
« Reply #24 on: Sun, 05 April 2026, 18:41:49 »
Looks great! Hits all the feels too.  :thumb:
Offline Rassles
« Reply #25 on: Sun, 05 April 2026, 21:02:39 »
Thank you so much!
Offline Rassles
« Reply #26 on: Sun, 05 April 2026, 21:02:52 »
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #27 on: Mon, 06 April 2026, 02:44:15 »
[...] Although saying this, Arcade was not directly and only inspired by Miami nights[...]
Really?
316519-0
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline villagepillage
« Reply #28 on: Mon, 06 April 2026, 05:43:47 »
Looks good
TGR 910
Offline autobot
« Reply #29 on: Mon, 06 April 2026, 21:24:51 »
Very nice!
Offline nadhole69
« Reply #30 on: Tue, 14 April 2026, 05:34:26 »
love that color combo!
Offline Rassles
Re: [IC] GMK Arcade - August 3rd 2026
« Reply #31 on: Mon, 03 August 2026, 04:18:47 »
Prototypist has gone live!
Offline spikedsynapse
« Reply #32 on: Wed, 05 August 2026, 09:32:20 »
Miami Nots
