Author Topic: [IC] Dyad TKL & Pad  (Read 54278 times)
Offline SumJoy
[IC] Dyad TKL & Pad
« on: Thu, 26 March 2026, 12:15:25 »
Hello everyone/你好
It’s been a while, dumboy here.
Fulfillment for the first chapter, Début: Diversity, was completed last year. Thanks to your incredible support, everything went according to plan. And the keeb gained a lot of compliments. Nearly a year has passed since the Diversity IC:re. It is finally time to move forward and unveil what’s behind the next curtain.
Here it is, scene 1: Dyad.
316401-0
Exploded view
316405-1
Specifications
Layout: F12 TKL
Mounting: Plate oring
Size: 359.61 mm * 136.01 mm (TKL) / 88.15 mm * 136.01 mm (Pad)
Weight(Unbuilt): 2.52kg (TKL) / 0.55kg (Pad)
Front height: 18.90mm (TKL&Pad)
EKH: 23.76mm (TKL&Pad)
Typing angle: 7°
Manufacturer: STR
Color options
Black and silver are confirmed, other three colors will be voted in keyspensory dc channel.
Black
316407-2
Match with GMK Tokyo Nights
Silver
316409-3
Match with GMK Müt
PC
316411-4
Match with GMK Finer Things
Cyan
316413-5
Match with GMK Analog Dreams R2
Sand
316415-6
Match with my friend's design Jazz
Pink
316417-7
Match with GMK Hooty
Blue
316420-8
Match with GMK Gorp
Purple
316422-9
Match with GMK Lavender
Layouts
Soldering: F12/F13, split backspace, stepped capslock, ansi/iso enter, split left shift, split right shift, 6.25u/7u
Hotswap: Split backspace, Stepped capslock
316424-10
Plates
Default plate is black alu, black PP/black CF/yellow PEI is optional
316426-11
The rendering is 7u ansi only, the plate in GB will be more compatible.
PCBs
Default is 1.6mm soldering PCB, 1.6mm howswap/0.8mm soldering is optional.
Soldering
316429-12
Hotswap
316431-13
What's inside?
TKL:
1.Delivery box * 1
2.Carrying bag * 1
3.Keyboard cloth * 1
4.Case * 1
5.Plate * 1
6.PCB * 1
7.Oring * 2
8.Foams * 1
9.Daughter board * 1
10. Bumpon * 6
11. Screws * n
12. Manual * 1
Pad:
1.Delivery box * 1
2.Keyboard cloth * 1
3.Case * 1
4.Plate * 1
5.PCB * 1
6.Oring * 2
7.Foams * 1
8.Daughter board * 1
9. Bumpon * 6
10. Screws * n
11. Manual * 1
Typing test
This is a simple proto from JLC, and more photos and videos of protos from dds will be updated here.
【Dyad proto typing test】
Estimate price
Around $390(TKL)
Extra PCB/plate price will be listed on GB
MOQ: 100
Delivery time: within 5 months once GB ends (depends on the orders)
Estimate GB time
2026.7.18-2026.8.10
International: keyspensory
SEA: ktechs
AU&NZ: Keebz N Cables
Links
Discord
« Last Edit: Sun, 19 July 2026, 09:33:16 by SumJoy »
Offline Panez
Re: [IC] Dyad TKL
« Reply #1 on: Thu, 26 March 2026, 16:34:52 »
Let's go mah man! Diversity was fire.
Offline KeyMaze
    • KeyMaze
Re: [IC] Dyad TKL
« Reply #2 on: Thu, 26 March 2026, 22:35:05 »
Cyan one is so beautiful!
Offline schizobovine
Re: [IC] Dyad TKL
« Reply #3 on: Fri, 27 March 2026, 08:18:10 »
Love my Diversity and totally in for one of these! :D
Offline F.Helmet
Re: [IC] Dyad TKL
« Reply #4 on: Fri, 27 March 2026, 23:56:54 »
Diversity TKL was the banger for me last year, I'm in for the new design  :thumb:
Offline SumJoy
Re: [IC] Dyad TKL
« Reply #5 on: Thu, 02 April 2026, 22:54:23 »
Update:
change the manu to str, and the price will fall to around $390(TKL) since we'll make a good deal with str.
and all the colors above will be made
hoping start the GB in mid May.
Offline EdgeOfInfinity
Re: [IC] Dyad TKL
« Reply #6 on: Thu, 09 April 2026, 16:35:27 »
liking the design, minus the bottom text (plz remove ;)).
will the additional color options be ano or e-coat? glwic!
Offline xyzzy42
Re: [IC] Dyad TKL
« Reply #7 on: Thu, 09 April 2026, 22:08:55 »
Will it run QMK?  I didn't see anything about firmware.
Offline SumJoy
Re: [IC] Dyad TKL
« Reply #8 on: Fri, 10 April 2026, 07:19:05 »
oh, plan to do ano, hoping the mane will make the colors correct
Offline SumJoy
Re: [IC] Dyad TKL
« Reply #9 on: Fri, 10 April 2026, 07:20:22 »
yeah, QMK powered and vial supported
Offline blondie
Re: [IC] Dyad TKL
« Reply #10 on: Fri, 10 April 2026, 12:13:20 »
Why is this called TKL when I see ten keys in all of the photos?
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline xyzzy42
Re: [IC] Dyad TKL
« Reply #11 on: Fri, 10 April 2026, 13:02:38 »
Will source code be made available, as is required for QMK license?
I ask because I can not find anything for Diversity TKL, your previous project.  I don't see anything named Diversity in QMK repo.  There is nothing in VIAL repo for diversity.  It's not in the VIA supported keyboards list.  I can't find even find firmware binary or via json file online.
Offline SumJoy
Re: [IC] Dyad TKL
« Reply #12 on: Sat, 11 April 2026, 09:08:55 »
Okay, got u. Modified the title just now.
Offline SumJoy
Re: [IC] Dyad TKL
« Reply #13 on: Sat, 11 April 2026, 09:12:31 »
Okay, I'll make the firmware open-sourced in keyspensory's dc channel first once the GB is over. As for Diversity, I made it open-sourced in the dc channel already.
Offline kenny_25
Re: [IC] Dyad TKL & Pad
« Reply #14 on: Sat, 25 April 2026, 01:06:30 »
the goat Sumjoy, lets go! Lovely design
Offline Han_Solo2k
« Reply #15 on: Tue, 19 May 2026, 08:43:25 »
The cyan one got me, look so fireeee!!!!  :cool:
Offline Fede_Feo
« Reply #16 on: Sat, 18 July 2026, 04:56:59 »
Love the TKL + Numpad configs.
