Author Topic: [IC] Infinite 70  (Read 15842 times)
Offline AIRPOTTER
  • Owner of Gray Studio
[IC] Infinite 70
« on: Thu, 26 March 2026, 23:54:44 »
Hello everyone! Long time no see! :)
This time, we're bringing another product from G·works series, which is the first model in this in-stock series: Infinite 70.
Exterior Design
At the front corners, we've tried a design treatment different from before this time:
At the intersection of the three three-dimensional surfaces and the edge chamfer, we've used right-angle chamfers to attempt a brand new visual style.
The beveled badge at the top of the arrow keys echoes the front corners, paired with light strips at the center and chamfered edges of the badge, enhancing recognizability when lit.
The weight extends from the overall form, creating a floating hollowed-out effect, and is accented with two small decorative light strips to enhance the visual layers.
On the bottom surface, decorative lines that extend the visual effect are added to the weight area, further enhancing the overall texture through enriched detail elements.
Structure Design
The internal uses a bridge-style gasket. During typing, pressure from the fingertips deforms the bridge-style gasket, enabling downward travel and rebound.
The INFINITE 70 has a firmer feel, but the tuning is softer than the Space82, with better consistency.
At the same time, to pursue a balanced, cohesive typing feel, after many scheme adjustments, we ultimately decided to adopt a 1.2mm non-flexcut PCB + leaf-spring mounting plate combination.
This solution, while maintaining sufficient support, achieves the consistency and solidity we expected, and the tactile performance meets expectations.
Layout
Typing Angle / Dimensions
Front height: 19.60mm
Typing Angle:7°
Colorways
Anodized: Quicksilver,Top gun,Darth Vader,Peach Pink,Burgundy,Tyraels
Electrophoresis: Storm,Khaki
Powder Coating: Concrete,Gravel,Tara,Skyline,Barley,Sunset Glow,Hibiscus,Rock ash,Meteorite,Raspberry Pink.
PCB
Wired 1.2mm (no flexcut), multi-layout hot-swap (ZH), split magnetic daughterboard
with ESD protection, supports VIAL (VIA-required files provided).
Plate
FR4 / PC / Aluminum / Carbon Fiber
Contents
* 1x Case (top case, badge, bottom case, weight frame, weight, back badge)
* 1x Plate
* 1x PCB(1.2mm thick PCB Motherboard with Magnetic Daughterboard)
* 1x Poron vibration reduction plate foam(3.5mm)
* 1x ixPE PCB foam(0.5mm)
* 1x Noise reduction case foam(2mm)
* 1x Electrostatics Insulation Foam(0.1mm)
* 1x Set of gaskets (12 Bridge gaskets)
* 1x Updated screwdriver (Graystudio brand) * 1x tweezer (always test the PCB before soldering!)
* Extra Screws, rubber feet
* Other Accessories
Partial prototype photos
Quick silver
Darth Vader
Peach Pink
Burgundy
Storm
Khaki
Tara
Sunset Glow
Concrete
Meteorite
« Last Edit: Fri, 27 March 2026, 00:44:52 by AIRPOTTER »
Offline Alva_Works
Re: [IC] Infinite 70
« Reply #1 on: Fri, 27 March 2026, 15:02:45 »
Pls go with a "normal" layout, avoid 6,25u, go for 7u WKL, split backspace and rightshift. Its 2026...
« Reply #2 on: Fri, 27 March 2026, 15:25:40 »
Yeah I think the overwhelming majority will do Tsangan Bottom Row with 7u Spacebar.
Offline CONIN
    • Instagram
« Reply #3 on: Mon, 30 March 2026, 16:52:44 »
PCB 1.2mm... hot-swap...
I don't want a Fisher Price keyboard. At least add an optional 1.6mm solder PCB with 7U Bottom Row, Split Right Shift, Split Backspace and Stepped CapsLock support.
Offline Navid
« Reply #4 on: Mon, 30 March 2026, 23:50:32 »
No 1.6mm = no buy
Offline Bokehhbob
« Reply #5 on: Wed, 01 April 2026, 12:08:03 »
No Mecha colorway, no 1.6mm pcb and no split bs???  😭
its 2026, come on!
« Last Edit: Wed, 15 April 2026, 12:14:05 by Bokehhbob »
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #6 on: Wed, 15 April 2026, 07:04:08 »
It is a shame that the layout for this one is so bad. If this was WKL 7u locked bottom row with options for Split BS/RS it would kill. Absolutely day 1 pickup for me if the layout was right as I love the design, but forcing layout options feels really bad in 2026. Especially since the western market doesn't really use 6.25u bottom row. It really is such a shame that a lot of these really cool designs with really solid price points end up favoring a specific market.
Offline phinix
« Reply #7 on: Fri, 17 April 2026, 05:58:23 »
What will be the price?
Would there be UK vendor?
« Last Edit: Fri, 17 April 2026, 06:34:50 by phinix »
Offline zlorfik
« Reply #8 on: Sun, 03 May 2026, 14:33:56 »
Is the design final or still considering tweaks? +1 to WKL and stepped capslock. Those would make me instantly commited regardless of price.
