Author Topic: [IC] KAP Deez Nuts  (Read 50498 times)
Offline roffelsaur
[IC] KAP Deez Nuts
« on: Wed, 01 April 2026, 11:10:13 »
KAP Deez Nuts
Inspired by my daily snacks, KAP Deez Nuts pays homage to these wonderful superfoods. Blending the colours of almond, macadamia, pistachio, and red peanut skin, this set uses earthy pastel tones to bring Deez Nuts to life. A crunchy addition to any build...it's time to type on Deez Nuts.
IC Form
Discord
IG
KeyAtlas Project Page
Introduction
Hello! I've been sitting on the design of Deez Nuts for quite some time now. It started off as a KKB project, then entered the GMK contest, and now it's finally going to find its home as a KAP set! KAP was chosen to allow for a larger base kit (no kerfuffling around with a gazillion child kits that end up getting abandoned anyway...) and also to take advantage of the dye sub + double shot method used for novelties. This ensures that we get novelties that contain much more detail, richer colour than simple double-shot, as well as never having the rubbing off/texture properties of UV-printed novelties. All this for <$100 for the base kit, provided there's enough resin left in the world to make these...
Specifications
Material: PBT
Production method (base kit): double shot
Production method (novelties): dye sub (art) + double shot (rest of keycap)
Manufacturer: Keyreative
Vendors
CN: zFrontier
UK: Thocc Exchange
ANZ: Keebz N Cables
Artisans/Collabs
If you're keen on Deez Nuts then I'm happy to have you make Deez Nuts
Thanks
Basil for always being a sweetheart and a real one
Nebulazy for the wealth of knowledge on small/odd boards kitting
Shark for the blender crash course
Madmax13 for rendering guidance
Kaptainmike for being a multi trillionaire
...and everyone else I interacted with along the journey of Deez Nuts
Gallery
(Pangea Full Size by bowl keyboards)
(minimi40 by keebibi)
(Capy60 by bowl keyboards)
(Seal80 by Sensy)
(Manta65 by bowl keyboards x Alexotos)
(F1-8X V2 Green/Brown by Geonworks)
Base Kit
Novelty Kit
Deez Chest Nuts Deskmat
Deez Sweaty Nuts Deskmat
(dye sub + double shot process)
« Last Edit: Thu, 13 August 2026, 04:17:24 by roffelsaur »
Offline roffelsaur
Re: [IC] KAP Deez Nuts
« Reply #1 on: Wed, 01 April 2026, 11:13:02 »
Please feel free to roast  ;D
Offline nebulazy
  • i heart keyborb
« Reply #2 on: Wed, 01 April 2026, 13:00:14 »
the novelties are the best part. glwic!
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #3 on: Wed, 01 April 2026, 13:03:31 »
no balls
Offline KeyMaze
    • KeyMaze
« Reply #4 on: Thu, 02 April 2026, 01:09:13 »
Yummy
Offline roffelsaur
« Reply #5 on: Thu, 02 April 2026, 13:31:58 »
no balls
There's a pair of bearded walnuts that would beg to differ, sir.
Thank you <3
Yummy
Note: keycaps may present a choking hazard  ;D
Offline basilkeys
« Reply #6 on: Fri, 03 April 2026, 11:52:47 »
Yummy yummy get in my tummy!!!
Offline Shell
    • https://www.youtube.com/@ShellHg
« Reply #7 on: Sun, 05 April 2026, 12:01:18 »
I genuinely really like the color scheme on this. Hopefully it sees it to group buy!
Separately, any chance for windowed lock keys in an alt kit? This could go really well with an orange LED underneath
Offline roffelsaur
« Reply #8 on: Tue, 07 April 2026, 06:56:19 »
Yeah just you wait until KAP Herbs :P
Thank you! I'm aiming for this to be a "came for the meme, stayed for the theme" set. I'll find out from Keyreative if they have windowed caps lock :)
« Last Edit: Sat, 11 April 2026, 00:19:42 by roffelsaur »
Offline roffelsaur
« Reply #9 on: Tue, 28 July 2026, 23:27:12 »
Updated with a couple of new renders!
Vendors also updated, will be reaching out to more soon :)
We're currently requesting colour matching and samples from Keyreative, ETA on those is within the next month or so.
(Seal80 by Sensy)
« Last Edit: Tue, 28 July 2026, 23:29:17 by roffelsaur »
