Author Topic: [IC] GMK CYL Purple. | GB is Live!  (Read 247936 times)
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« on: Thu, 09 April 2026, 11:54:20 »
GMK CYL Purple.
The set is based on Pantone Medium Purple-C base color and metallic grey legends (inherited from Hi!Viz) with inverted colors on extra Esc/Enters.
For a better reference, this is the same purple from GMK Nerve and Nervewrecker.
GB Thread is now live
Kits:
Base
Extension
GB Date:
October 10 - November 10 2026
Pricing:
Base Kit: $130
Extensions: $43
Vendors:
 UK - Prototypist (lead)
 EU - Coffeekeys
 CA - Deskhero
 US - Bowl
 SEA - Ktechs
 KR - Swagkeys
 CN - KBDFans
 OCE - KeebzNCables
 TR - RationalKeys
Renders:
IRL photos (more to come):
TOFU60 3.0 RAW, GMK Retrowave, bunch of Purple. and reverse keys and a DY Key from GMK tester
Collaborations:
TBA
IC FORM
DISCORD INSTAGRAM
« Last Edit: Sun, 11 October 2026, 13:39:09 by MoltenKhor »
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple.
« Reply #1 on: Thu, 09 April 2026, 11:55:05 »
Reserved.
Offline EdgeOfInfinity
« Reply #2 on: Thu, 09 April 2026, 16:53:18 »
certified purple lover
Offline bb_iamkiller
  • life is copper
« Reply #3 on: Fri, 10 April 2026, 00:52:22 »
Man i really thought this relate to glarses or st
« Last Edit: Fri, 10 April 2026, 00:54:30 by bb_iamkiller »
copper addict
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #4 on: Fri, 10 April 2026, 03:07:58 »
Confirmed :thumb:
I have his blessing  ;D
Offline Raie_de_Boule
« Reply #5 on: Fri, 10 April 2026, 03:42:11 »
Ok I'm in.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #6 on: Fri, 10 April 2026, 08:27:51 »
Purple? Sure I'm in...
316633-0
A Ghost From The Past
Offline mr_foggy
  • neue = nope
« Reply #7 on: Fri, 10 April 2026, 16:39:58 »
finally some 2026 gmk worth buying
simple cw, giga basekit, no neue bs, it's a simple recipe really.
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #8 on: Sat, 11 April 2026, 03:52:09 »
Nice collection!
Ok I'm in.
Oui!
what one man has to do to finally end with the hobby  ;D
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #9 on: Mon, 13 April 2026, 04:49:40 »
Updated base kit and extension:
Base kit update:
  • Added R3 Stepped Control
  • Added R1 Esc
Extension:
  • Macro keys
  • 4x Relegendables
  • 2x 3U + 1U Split Space bars
  • Windowed standard/stepped Caps Lock
  • BAE
  • Windowed R1 Scroll lock with inverted color as well
  • Novelty ANSI Enter (might remove, not convincing 100%)
About International kits, still studying the IC Form to get % of each lang, as for now is DE and IT, all other languages sit just under 10%
I will remake keyboard renders to fix the icon+text instead of icon-only modifiers and also show windowed keys. (thank you for noting  :) )
Offline Manukbs_
« Reply #10 on: Mon, 13 April 2026, 11:39:02 »
Based
Offline nadhole69
« Reply #11 on: Tue, 14 April 2026, 05:30:25 »
Nice purple!
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #12 on: Fri, 29 May 2026, 06:24:52 »
Updated renders, fixed keyboard ones having wrong legends. Extension kit updated according to what came out from the IC form.
KBDFans added to vendor list  :D
International kits have not been made yet, statistically speaking there's no MoQ even combining NORDEUK + ESFRIT in a single child kit (unnecessarily expensive)
« Last Edit: Fri, 29 May 2026, 06:27:18 by MoltenKhor »
Offline Faraday
  • a toofpick changes everythang
« Reply #13 on: Fri, 29 May 2026, 21:50:55 »
welcome back mito
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #14 on: Sat, 30 May 2026, 02:02:33 »
I want my IT child kit.
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #15 on: Sat, 30 May 2026, 03:48:30 »
Wee need 45 more ppl and IT child kit is on board  :D
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | final kitting
« Reply #16 on: Tue, 30 June 2026, 01:52:45 »
Kitting updated with all fixes proposed in the IC Form.
Vendors list updated
Offline cartersrush
    • Discord
« Reply #17 on: Tue, 30 June 2026, 13:21:25 »
Looks great! GLWIC
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #18 on: Wed, 01 July 2026, 02:26:53 »
Looks great! GLWIC
 :D
Also: I will be ordering a batch of single keycaps with my "K" logo as i did in the past with the reverse color scheme to test how reverse keys will come out. I'll try to have it by Clackyfest, MKIT and Mechanicon for those who will be at those meetups
Offline mr_foggy
  • neue = nope
« Reply #19 on: Wed, 01 July 2026, 04:51:19 »
glad to see this is moving ahead! most anticipated set this year for me
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #20 on: Wed, 01 July 2026, 06:47:31 »
Keebzncables also confirmed, just waiting for Geon.
GMK also sent me the invoice for reverse color keycaps so 100% going to have those for meetups to show off  ;D
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | Vendors list updated
« Reply #21 on: Wed, 08 July 2026, 03:18:02 »
All vendors confirmed as Swagkeys joined the project, GMK already sent me cost estimations, GB time window and final price will be announced soon.  :D
Offline konstantin
  • Formerly constexpr
« Reply #22 on: Wed, 08 July 2026, 13:29:08 »
Please consider replacing R3 1.75u stepped Control and/or R4 1.5u Caps Lock in base with R3 PgUp, R4 PgDn for 65%/75% support. There are already suitable replacements for those two obscure keys in the kit; whereas you can't really use R3 PgDn, R4 End if you're used to one of the other popular 65% layouts (see this old analysis of mine for more details).
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #23 on: Sat, 11 July 2026, 10:56:49 »
Thank you for the analysis!
The kitting has been changed and updated during previous months based on what emerged on the IC form suggestions/request. Despite the form only got barely 200 entries, i couldn't find any requiring those keys and, the obscure keys are the one appearing on at least 25% of the entries.
I see the data is from 2021 tho, could it be different now?
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | Samples arrived
« Reply #24 on: Sat, 11 July 2026, 10:59:31 »
As mentioned before, i ordered from GMK a batch of single 1U R1 keycaps with the reverse color. Those will be used as branded merch on my shop, meetups and events but they were an excuse to test how the contrast with Pantone Medium Purple-C makes the reverse keys readable enough.
I have updated the main post with new photos of both keys, compared to DY as someone asked how the Pantone matches with the standard GMK color.
Offline vishuhs
« Reply #25 on: Sat, 11 July 2026, 11:36:47 »
need
Offline CoolPenguin1
« Reply #26 on: Sat, 11 July 2026, 18:25:01 »
Consider adding a 1u backspace for us BAE users in the extension kit.
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #27 on: Mon, 13 July 2026, 08:30:08 »
Will check on that! Thank you for letting me notice it.
Offline jigumina
    • Personal site
« Reply #28 on: Fri, 17 July 2026, 07:41:47 »
Purple!!! GLWIC!
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | GB date confirmed
« Reply #29 on: Mon, 27 July 2026, 12:35:43 »
GB date has been decided, October 10 - November 10 2026  :D
Re: [IC] GMK CYL Purple. | GB October 10th 2026
« Reply #30 on: Sat, 22 August 2026, 23:26:05 »
I was gonna joke about the set needing to be name GMK Khor, then I saw that it really was Khor lmao
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #31 on: Sat, 29 August 2026, 04:32:06 »
I was quite predictable  ;D
Offline victoriarose101
« Reply #32 on: Sun, 30 August 2026, 09:18:59 »
holy purple!
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #33 on: Tue, 08 September 2026, 11:49:38 »
updated  :thumb:
Offline Nevrest
Re: [IC] GMK CYL Purple. | updated kitting
« Reply #34 on: Fri, 11 September 2026, 15:16:10 »
Chef's kiss  :thumb:
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | GB October 10 - November 10 2026
« Reply #35 on: Wed, 23 September 2026, 10:17:58 »
While i wait for GB thread approval, i have updated the pricing for all kits.
Offline Bert
« Reply #36 on: Wed, 23 September 2026, 12:56:01 »
Purple
Offline MoltenKhor
  • www.khor.store
    • Khor Store
Re: [IC] GMK CYL Purple. | GB is Live!
« Reply #37 on: Sun, 11 October 2026, 13:39:50 »
GB is live!, Vendor links updated on the GB thread
