![[IC] Snowball44 - the gasket mount case for Keyball44 316667-0](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316667;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316683-1](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316683;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316669-2](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316669;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316671-3](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316671;image)
back view and brass weight ( You can see this individual seem to have some scratch, since we already have used this one around one year. In production GB version, those scratch will be decreased. )
![[IC] Snowball44 - the gasket mount case for Keyball44 316673-4](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316673;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316675-5](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316675;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316677-6](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316677;image)
Those images are not render, real photo. shot by
@kepeo![[IC] Snowball44 - the gasket mount case for Keyball44 316679-7](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316679;image)
![[IC] Snowball44 - the gasket mount case for Keyball44 316681-8](https://geekhack.org/index.php?PHPSESSID=d08p2uhsk4ih3s28bkgvpts2ugjtrqml&action=dlattach;topic=126600.0;attach=316681;image)
Those 2 images are rendered.
Snowball44 - CNC Aluminum Gasket Mount Case for Keyball44
IC Form:
hereDiscord:
https://discord.gg/tuykB7h5d9
What is Snowball44?Snowball44 is a CNC aluminum gasket mount case designed specifically for the
Keyball44 - the popular split keyboard with an integrated trackball, designed by
@Yowkees.
This project builds on the experience and lessons learned from
Corchim, my previous CNC gasket mount case for the crkbd.
Specifications- Mount: Gasket mount (Poron foam)
- Case: 6061 Aluminum
- Switch plate: Polycarbonate
- Trackball case: CNC machined aluminum
- Still we are wondering which track ball case should be enclosed 34mm or 25mm. For now we might be going to enclose 34mm. If you have any opinion, please tell us in IC form[url].
- Weight: Brass
- Tent: 4°
- Tilt: 3°
- Color: White + Brass
- Compatibility: Keyball44
- Pricing: Around 400 USD (subject to change after final quotation)
