Author Topic: [IC] GMK CYL Blanks  (Read 135546 times)
Offline mcmcmc
[IC] GMK CYL Blanks
« on: Thu, 16 April 2026, 13:07:14 »
GMK CYL Blanks
Hello guys :blank:
This set is pretty straightforward: no legends, no letters, no fonts. Just colored blank keycaps.
Vendors
US: Cannonkeys
CA: RNDKBD
EU:
UK: Proto[Typist]
KR: GEON
CN: TypistClub
SG: iLumkb
AU: KeebzNCables
Details
Material: ABS
Legends: TBC, I’ll check with GMK to see if they have blank molds for all the keys, and whether singleshot is doable.
Colors: CR, L9, U9, V1, N7, V4, CV, TU2, DY, MG1
Profile: R1 R1 R2 R3 R4 R4
Kits - Please keep in mind that this is an IC, kitting may be cut or added depending on the response.
Renders
Amano by h40
Vero by AKB
Petrichor by AKB
Frog TKL by GEON
Socials
Discord
Instagram
Thanks
You for reading :-*
« Last Edit: Sun, 20 September 2026, 07:22:33 by mcmcmc »
Offline DirtyGingy
Re: [IC] GMK CYL Blanks
« Reply #1 on: Thu, 16 April 2026, 13:18:35 »
I'm almost surprised to not see dolch blanks. Cool though
Offline icedwatr
« Reply #2 on: Thu, 16 April 2026, 13:28:41 »
I need it  :p
Offline Faceman76
« Reply #3 on: Thu, 16 April 2026, 13:41:20 »
MTNU too?
1800s and heavy springs
Offline iamtragic
« Reply #4 on: Thu, 16 April 2026, 13:56:34 »
Finally.
Can you confirm that bottom row is r4?
Offline CoolPenguin1
« Reply #5 on: Thu, 16 April 2026, 14:30:04 »
Offline white_rabbit
« Reply #6 on: Thu, 16 April 2026, 14:32:18 »
Most of your images are not working
You're hoping to do singleshot? I'm assuming that would reduce the price significantly
Offline mcmcmc
« Reply #7 on: Thu, 16 April 2026, 14:34:08 »
Can u explain pls. It looks fine to me
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #8 on: Thu, 16 April 2026, 18:43:31 »
The desire for single shot is mentioned in the OP:
Details
Material: ABS
« Last Edit: Thu, 16 April 2026, 14:10:36 by mcmcmc »
« Last Edit: Thu, 16 April 2026, 18:48:47 by dvorcol »
Offline Gondolindrim
    • My GitHub
« Reply #9 on: Thu, 16 April 2026, 21:59:04 »
This is so sexy I am considering getting a beige keyset
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline mcmcmc
« Reply #10 on: Fri, 17 April 2026, 00:02:58 »
Details
Material: ABS
I mean "Most of your images are not working". It seems to be working fine to me.
Offline mcmcmc
« Reply #11 on: Fri, 17 April 2026, 00:05:24 »
Finally.
Yep, the bottom row is R4. This is the profile from top -> bottom: R1 R1 R2 R3 R4 R4
Offline VXQN
« Reply #12 on: Fri, 17 April 2026, 02:10:46 »
I would love to see some smaller kits, for example some XT macro keys, R1 only, Alpha only, etc. etc.
« Reply #13 on: Fri, 17 April 2026, 09:31:04 »
Details
Material: ABS
Yea looks fine now. The image host was giving some trouble when you first posted.
Offline mcmcmc
« Reply #14 on: Sat, 18 April 2026, 06:34:51 »
That would be cool, but I don't think that it's possible during the current climate of this hobby. We're not in COVID era anymore i'm afraid. Many keysets are already not reaching MOQ naturally and adding more kits to and complexity is not a good idea.
Offline enomooshiki
« Reply #15 on: Sun, 19 April 2026, 14:50:14 »
i told myself i wouldn't join another GMK gb ... damn it
Offline mcmcmc
« Reply #16 on: Mon, 20 April 2026, 10:17:57 »
 :p
Offline extrapriusplease
    • All my links
« Reply #17 on: Tue, 21 April 2026, 16:53:02 »
where alert row :confused:
jk but maybe a shout for dolch to complete the trinity? :p
Offline mcmcmc
« Reply #18 on: Sun, 26 April 2026, 00:19:02 »
maybeee  :D
Offline Styllar
« Reply #19 on: Fri, 22 May 2026, 02:30:47 »
Finally a set I can get behind. I've been wanting good CMY blanks for such a long time but I'm pretty sure they've just straight up never existed.
Hope this makes it past the IC phase.
Offline baucts
« Reply #20 on: Tue, 26 May 2026, 15:05:47 »
thank goodness this isnt a late april fools
Offline mcmcmc
« Reply #21 on: Sun, 07 June 2026, 01:18:59 »
couple of vendors added :thumb:
Offline villagepillage
« Reply #22 on: Thu, 11 June 2026, 14:52:55 »
replied on discord. but interested
TGR 910
Offline mcmcmc
« Reply #23 on: Thu, 25 June 2026, 05:09:23 »
AU and KR vendors added.
Offline Fede_Feo
« Reply #24 on: Fri, 26 June 2026, 07:12:42 »
Offline mr_foggy
  • neue = nope
« Reply #25 on: Wed, 01 July 2026, 05:01:26 »
yes please in for all kits and considering running dolch as well
Offline EdgeOfInfinity
« Reply #26 on: Wed, 01 July 2026, 19:13:17 »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #27 on: Thu, 23 July 2026, 08:53:43 »
ne EU vendor avail  :-X
Offline Forvitni
« Reply #28 on: Tue, 18 August 2026, 03:58:58 »
is there any chance at all of getting a 1.5u r4 key in yellow in the accent kit?
Offline mcmcmc
« Reply #29 on: Wed, 19 August 2026, 02:53:27 »
TBC rn
what is that for?
Offline Forvitni
« Reply #30 on: Wed, 26 August 2026, 07:19:20 »
what is that for?
[/quote]
a very unlikely hope that it is close enough to the yellow used in GMK panels so I can use it as a 1.5u super haha
