Author Topic: [IC]KKB-Cross Impact | GB now live!| 2026/08/13 Update  (Read 103873 times)
Offline York Chan
« on: Wed, 22 April 2026, 06:59:14 »
KKB-Cross Impact
IC form|Discord|Discord-KeyKoBo
- Please help me to fill out this form and provide any feedback that you have, super thank you :thumb:
- If you are interested in being a vendor, please contact me on Discord.
Inspiration
Inspired by the cold, divine moon of Neon Genesis Evangelion, this design merges its quiet apocalyptic tension with Y3K’s sharp, futuristic style. The chrome finish echoes the lunar surface, while low-saturation blue reflections capture moonlight’s serene glow. Stripped of excess, four-point stars reimagine the moon as if wrapped in the Cross Impact—reinterpreting EVA’s iconic imagery with cyber-futuristic impact.
Info
Manufacturer: KeyKoBo
Material: ABS
Production Method: Triple shot + double shot + uv
Profile: Cherry profile
Sample
Renders
Kitting&Deskmat
Updates
2026/08/13:Accent colors have been added to Latin base kits, and the 1.25u Shift is integrated into both base kits.
The ISO kit has been replaced with the UK kit as the ISO enter key is removed.
 :thumb:
2026/06/16:The novelty keycaps have been updated with craft labels.
2026/05/23: Sample has been update~
  2026/05/20:Add Base-latin, Norde, Red moon, Clear Alert;
Some kit has been adjusted;
  2026/04/30:Nov kit & deskmat has been adjusted;
Added the clear alert kit;
  2026/04/24: The layout has been adjusted
Vendors
CA-Unikeys
US-Divinikeys
SG-ktechs
UK-Prototypist
EU-MonocoKeys
KR-Geonwork
JP-Yushakobo
AU-KeebzNCables
TH-AiglatsonStudio
Global-KbdFans
CH-KbdFans
Contact
Material Lab:
E-mail: 15813785718@qq.com
QQ group: 325624355
Instagram: https://www.instagram.com/yorkchan3/
Discord: https://discord.gg/mhKpbphf
Web: https://yorkc.github.io/mtltimeline/
Key Kobo:
Discord: https://discord.gg/CTAq7ZW5ph
Instagram: https://www.instagram.com/keykobo/
If you are interested in this setting , you can copy this code into your signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=126623.0][img width=302 height=120]https://i.imgur.com/fqVQtsu.jpeg[/img][/url]
« Last Edit: Fri, 14 August 2026, 02:50:48 by York Chan »
Offline York Chan
Re: [IC]KKB-Cross Impact| Add IC form
« Reply #1 on: Wed, 22 April 2026, 23:00:51 »
To be updated
Offline dgg
« Reply #2 on: Thu, 23 April 2026, 03:40:13 »
Please speed i need thisss
Offline raijba
« Reply #3 on: Thu, 23 April 2026, 08:24:21 »
The alpha white color looks like the plastic is "soft" or has a different texture. Or possibly like they are just the slightest bit transparent, as if their opacity is set to 97%. Is this an issue with the render? Or is there some sort of non-standard ABS formulation? I see the mods have a slightly wavy "chrome finish." Is there a finish on the alphas as well?
Nice set and nice inspiration.
Offline York Chan
« Reply #4 on: Mon, 27 April 2026, 00:40:09 »
White presents a semi-transparent texture, similar to the finish of white glass lampshades. The grey adopts a metallic tone. The two hues blend together, embodying the harmony of yin and yang. :thumb:
Online Randomlosername
  • Gacha Done Got Me
    • IG
Re: [IC]KKB-Cross Impact | The layout has been adjusted
« Reply #5 on: Mon, 27 April 2026, 01:16:22 »
Def one of more interesting sets I’ve seen lately. Count me in.
Offline nyxloom
« Reply #6 on: Wed, 29 April 2026, 15:26:22 »
This looks dope! Love the moon, love Eva, love this set. Gimme gimme gimme
Offline örange_stone
  • No fancy life But fancy keyboard
Re: [IC]KKB-Cross Impact | Nov kit & deskmat has been adjusted
« Reply #7 on: Wed, 29 April 2026, 21:39:26 »
Love the design of the novelties! :p The semi-transparent alpha looks interesting as well.
Right now, the overall color theme feels peaceful to me, and maybe just a few red add-ons (referencing EVA's bloodyness) would further highlight the theme? (just personal opinions)
Offline nyxloom
« Reply #8 on: Thu, 30 April 2026, 13:20:56 »
Agree with this! I also would be interested in what some Red, perhaps in the novelties, would do for this set.
Offline York Chan
« Reply #9 on: Sat, 02 May 2026, 07:55:26 »
In fact, the inspiration for Eva's moon image was only confirmed after the keycap design was completed. The true source of inspiration was merely my understanding of the y3k style of apocalyptic and sexually repressed aesthetics, which led to its creation. :thumb:
If you like the sub-legend in red, I would recommend another set of my designs.You can click on my signature, MW-Philosopher's Stone.
Thank you for your support. :thumb:
Offline York Chan
« Reply #10 on: Tue, 05 May 2026, 22:44:03 »
The form has added a red extra alpha option :thumb:
Offline York Chan
Big Big Big updated
2026/04/30:Add Base-latin, Norde, Red moon, Clear Alert;
Some kit has been adjusted; :thumb:
Offline Teizoku
Appreciate the Norde kit!
Offline York Chan
The number of EU of ic form reported is still quite high, So I joined Norde :thumb:
Offline mr_foggy
  • neue = nope
Re: [IC]KKB-Cross Impact | Sample Update
« Reply #14 on: Sat, 23 May 2026, 09:59:30 »
how haven't I noticed this one? very nice!
Offline York Chan
« Reply #15 on: Sun, 24 May 2026, 21:41:45 »
Thank you so much for your support.
Don't miss it when GB comes around. :thumb:
Offline keybo_hobo
« Reply #16 on: Sun, 31 May 2026, 17:24:03 »
Please consider adding R1 pipe to the alert kit in order to support tsangan layout. Thank you!
Offline York Chan
« Reply #17 on: Mon, 01 June 2026, 19:31:27 »
Which key is the pipe?
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #18 on: Tue, 02 June 2026, 00:48:55 »
On a standard ANSI layout, it’s the 1.25u \| above Return.
Offline York Chan
« Reply #19 on: Sun, 14 June 2026, 21:13:47 »
I have done it~ :thumb:
Offline m202307
Re: [IC]KKB-Cross Impact | Vendors list Update
« Reply #20 on: Tue, 16 June 2026, 17:56:11 »
The Latin base kit shows mod-colored esc and enter instead of accent-colored as in the "main" base kit.  Intentional?
Offline York Chan
« Reply #21 on: Tue, 16 June 2026, 22:16:13 »
This was an intentional design choice. If you’d like extra accent colors, I’d recommend adding the novelty kit to your order. :thumb:
Offline York Chan
Re: [IC]KKB-Cross Impact | Vendors list Update | GB launching August 12th.
« Reply #22 on: Mon, 13 July 2026, 02:51:35 »
GB launching August 12th. :thumb:
Offline York Chan
« Last Edit: Fri, 14 August 2026, 02:51:08 by York Chan »
Offline York Chan
Re: [IC]KKB-Cross Impact | GB now live!| 2026/08/13 Update
« Reply #24 on: Fri, 14 August 2026, 02:52:20 »
All vendors are now live :thumb:
