Author Topic: [GB] Jahre - Grit | Porsche 911 Inspired  (Read 4845 times)
Offline kenny_25
« on: Tue, 28 April 2026, 09:16:43 »
Jahre - Grit
|Pricing|
MSRP listed below, vendors may adjust the price slightly
Base Config
Kit include an anodized alu full plate of your choice, you will have to pick between MX plate or HE plate, plate file will be released after GB
Case$350
MXSolderPCB$35
MXHotswapPCB$40
HE Venom 65% PCB$60
Extra Parts
Black Ano Alu Full Plate$15
MX Solder PCB$35
MX Hotswap PCB$40
HE Venom 65% PCB$60
Foam$6
DB&Cable$4
|Vendor List|
Region Locked & Unlimited GB
VendorCountry/Region
DeltakeysEU
GeonKR+INTL.
GritChina mainland
KeebzNCablesAU
KeybayCA
KeyspensoryUS+INTL.
PantheonKeysSG
protoTypistUK
*Note: For countries/regions dont have local vendor, you can order thru Geon or Keyspensory with international shipping
|GB runs from May 1st to June 6th|
|ETA: Q4 2026|
About the board
Inspired by the first three generations of the Porsche 911 (901, 930, 964), fusion the classic look into a modern typing machine. More details you can find in our previous IC.
|Structures and Specs|
Layout: 65%
Typing Angle: 9°
Front Height: 17mm
EKH: 21.73mm
Weigh: 1.6kg built, 1.3kg unbuilt
Top Case Material: 6063 Aluminum Alloy Anodized
Bottom Case Material: 6063 Aluminum Alloy Anodized
Weights: Stainless Steel, RAW w/ CNC Pattern / PVD Silver w/ Grille
Mounting Style: Leaf Spring Gasket
PCB Option: MX Solder / MX Hotswap / HE Venom
Manufacutre: STR
|What’s Included|
Keyboard Case
Carrying Bag
30A Silicon Socks (1 set of 10 pcs)
50A Silicon Socks (1 set of 10 pcs)
Plate of your choice (MX or HE)
DB and Cables (*Must use kit inlcuded DB and cables)
Spare Screws
Foams and ESD Protection Sheet
|Mounting, Plates and PCB Layouts|
Mouting System
Open cut facing up in sustain mode
Open cut facing down in flexible mode
HE Plate
MX Plate
MX Solder PCB
MX Hotswap PCB
HE Venom 65% PCB
Notable Mentions:
The ano badge from prototype has been changed to SS Badge
Prototypes
Production
|Color Options|
Please be aware that below are prototype images, under studio lighting. Your monitor may cause different image effect
Aloe Green
Champagne Gold
(GB unit will be slightly greyer)
Classic Blue
GT Silver
Gunmetal Grey
Ice Blue
Volcano Orange
|Link|
To stay up to date, feel free to join our discord
Thank you for your time!
Re: [GB] Jahre - Grit | Porsche 911 Inspired
« Reply #1 on: Tue, 12 May 2026, 13:34:58 »
Approved :thumb:
Offline kenny_25
« Reply #2 on: Wed, 13 May 2026, 08:59:14 »
The groupbuy has started on vendors.
Below list of streamer/reviewer will have a unit to show case
Alexotos - Twitch/Youtube/Instagram
Dbokey - Youtube
Geon - Stream
Scoopedbar - Youtube
Ninekeys - Youtube
