Author Topic: Keymouse "blue slider"  (Read 3772 times)
Offline grilkip
« on: Thu, 11 November 2010, 02:01:55 »
For a board about which I have no idea how exclusive it is, the price is a bit steep, so... convince me to buy this I guess :rolleyes:.
Filco tenkeyless (browns) - IBM Model M - Cherry G80-3000LSCEU (blues) Das Prof. S (blues)
ANSI FTW
Offline 8_INCH_FLOPPY
« Reply #1 on: Sun, 14 November 2010, 21:51:18 »
3 days and no replies.
Translation: Do not buy
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline didjamatic
« Reply #2 on: Sun, 14 November 2010, 21:58:22 »
What's that small key under Enter?
Offline TexasFlood
« Reply #3 on: Sun, 14 November 2010, 22:00:38 »
Quote from: 8_INCH_FLOPPY;246871
Seems a bit on the high side to be although perhaps not outrageously so considering what these type often go for.  Guessing it has blue ALPS.  Probably comparable to my Northgate Ultra and one similar one to mine just sold for about total $30.
Offline TexasFlood
« Reply #4 on: Sun, 14 November 2010, 22:03:14 »
Seems a bit on the high side to me, although perhaps not outrageously so considering what these type often go for.  Guessing it has blue ALPS.  Probably comparable to my Northgate Ultra and one similar one to mine just sold for about total $30.
Offline didjamatic
« Reply #5 on: Sun, 14 November 2010, 22:14:23 »
My guess is it's a Chicony rebranded and has Blue Montereys.  The seller is ScarryGarcia and would say Blue ALPS if it had them, at least I think he would.  But even if it is a Chicony, it could have ANY switch in it except buckling springs.
« Last Edit: Sun, 14 November 2010, 22:17:20 by didjamatic »
Offline Daniel Beaver
« Reply #6 on: Sun, 14 November 2010, 22:23:18 »
Blue ALPS are really nice, for what it's worth.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline TexasFlood
« Reply #7 on: Sun, 14 November 2010, 22:25:06 »
Quote from: didjamatic;246878
Maybe, but the only boards I could find with a FCC ID of HQK2VHKEYMOUSE seemed to be white ALPS.  Probably best to ask the seller.
Offline Lenny_Nero
« Reply #8 on: Mon, 15 November 2010, 05:41:42 »
This looks like my DTK SPK-102a which has blue ALPS.
But after looking at mine, it might not, as mine does not have the pen grove above the F keys, apart from that reading the blurb its the same sounding.
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087,  Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline ricercar
  • mostly abides
« Reply #9 on: Mon, 15 November 2010, 11:32:41 »
Quote from: Daniel Beaver;246882
Someone described them as crunchy, and I have to agree. Nice crunchy.
« Reply #10 on: Mon, 15 November 2010, 20:44:11 »
Yeah, In know that from a factual point of view they are identical to white alps.
But we all know blue switches are better.
« Reply #11 on: Mon, 15 November 2010, 21:19:33 »
Well, if it does have blue alps, I'd definitely snatch it up.  Just be sure you know what you're getting if when you're spending that kind of money.  For the record, blue is my favorite type of alps for typing.  It beats the crap out of white alps.
HAPPY HUNTING
Offline didjamatic
« Reply #12 on: Mon, 15 November 2010, 21:22:40 »
They can have different springs and leafs at a minimum.
These are both from pre-1990.  Blue were from an early Leading Edge DC-2014 and White were from 1989 Northgate 102 Metal Gold Label.  The tactile bump feels very different between the two, but both of these are the creme de la creme of complicated ALPS.  Some later ones were heavier than these which both come in at 62g.  But the blues feel faster and generally slightly better to me and most agree.  Fukkas are also very smooth and close to Blues and early good whites but louder.
EDIT:  What's interesting is I noticed Ripsters Blues above have a leaf like my White one does, but have a spring like my blue ones.  I'm positive I didn't mix them up, I was very careful.  I should have pulled some later complicated whites for comparison.
« Last Edit: Mon, 15 November 2010, 21:43:15 by didjamatic »
« Reply #13 on: Wed, 17 November 2010, 01:05:05 »
Allz ie noa iz dat ie 'av ae nu een bocks NORTHGATE OMNIKEY weeth wite alps aend eets not neurly az good as my wel-uzed blu alps bored.
That was a test to see if we have any spelling nazis.  If they read that post, they likely suffered a stroke and died.  You can thank me later.
HAPPY HUNTING
Offline grilkip
« Reply #14 on: Wed, 17 November 2010, 06:22:27 »
Relisted, same pricing.
ANSI FTW
