Author Topic: The PalmPuk (with MS Paint graphics)  (Read 41359 times)
Offline TheSoulhunter
  • ~ BOOO ~
« on: Thu, 28 May 2026, 21:07:11 »
So, I got an idea I want to share with you...
The PalmPuk
A sliding palm rest that lets you move your hands without lifting them.
It is basically a combination of resting and hovering...
The device consists of two main parts:
317200-0
Upper Part (with cushion pad) -> Where your palms or the base of your hands rest.
Lower Part -> Contains three captive steel balls arranged in a triangle.
The upper part glides smoothly on these balls in two axes...
317202-1
This should create a low-friction "hover" effect...
Your hands stay supported, while the whole assembly slides with your natural hand movements.
It should feel like your hands are floating...
Combining the benefits of a palm-rest with the freedom of hovering.
This probably only works for 60% size boards... and split-ergo ones...
The perfect size of the Puk, the freedom of movement, and the exact design...  have to be worked out.
If someone wants to produce the PalmPuk, feel free to do so (credit and free sample would be nice tho).
What do you think? Input? Criticism? Suggestions?
« Last Edit: Thu, 28 May 2026, 21:37:11 by TheSoulhunter »
A Ghost From The Past
  • ~ BOOO ~
Re: The PalmPuk (with MS Paint graphics)
« Reply #1 on: Thu, 28 May 2026, 21:30:17 »
As tipping might be a concern in the extended positions,
flipping the design upside down might be a good idea...
317204-0
  • ~ BOOO ~
« Reply #2 on: Thu, 28 May 2026, 22:16:16 »
If we use split spherical bearing seats, machining would be easier,
and we could use a soft base-material like Aluminum...
317206-0
Or does someone have a better idea for the seating?
Offline vvp
« Reply #3 on: Sat, 30 May 2026, 09:36:05 »
The bearing ball must be touching directly the table (or some big pad (cushion) put on the table) to provide easy movement. Your design provides easy movement only withing the cushion area which is drawn about the same size as the whole device for one hand. Also the balls must be able to move around in the device if you want to use only rolling friction. Your proposal does not handle this at all.
You can provide easy "friction less" movement with magnets (magnetic levitation), air cushion (you need air pump somewhere), ultrasound levitation or some omnidirectional wheels touching directly to the table.
But if you are lazy to move your hands around then you can also get a keyboard which does not require any palm movement while typing, like e.g. K80CS: https://deskthority.net/viewtopic.php?p=250605#p250605
  • ~ BOOO ~
« Reply #4 on: Sun, 31 May 2026, 09:57:47 »
In the second design, the ball is captive in the upper half (blue color, with orange cushion on top) where the hand rests on.
The upper part slides in the lower part which is basically a cup (grey part...).
So, the balls roll on a stationary (non moving) metal base.
This allows the upper part to slide...
The size difference between upper and lower part dictate the freedom of movement.
The balls are held in the bearing surfaces (pink) that sit in the upper part (blue/cyan).
You can simply lift the upper part (which holds the balls) out of the lower part (grey).
This allows cleaning or lubricating the inside of the lower part.
In the first version it's the same, just reversed...
Balls are held captive in the lower part, and the upper part rides on them.
But, as mentioned, this would make the upper part tilt in extended position (moving to the outside).
The goal is to be able to slide your palm about 1 Inch in all directions...
On a 60% board, resting your palms on a palm rest, fingers on home row, about 1 inch is all it takes to reach any key.
The Puk is not meant to slide your hands across the table (going Alphas to Numpad or similar) but just for typing in the Alpha-Area.
Hope this makes it more clear...
Maybe I should make a animation or something?
« Last Edit: Sun, 31 May 2026, 10:04:25 by TheSoulhunter »
  • ~ BOOO ~
« Reply #5 on: Sun, 31 May 2026, 10:35:12 »
Com'on, It's no about laziness, but ergonomics...
Hovering your hands over something for 6, 8, 10 hours a day, can be straining and lead to problems.
That said... Nice project! Still got the original ErgoDox (from the GB here) sitting in my collection.
Also plan to test one of these Cyborg keypads soon...
Still, this is about a palm rest. One that lets your palms slide in all directions slightly.
Because stretching your fingers is usually not enough to reach all of Num-row (from Home-row).
The Puk would also work for split-ergo boards like the one you made. It's just a different form of palm-rest.
« Last Edit: Sun, 31 May 2026, 10:38:16 by TheSoulhunter »
Offline vvp
« Reply #6 on: Mon, 01 June 2026, 02:19:56 »
If that is the goal then the lower part must be bigger by 1 inch in all directions compared to the upper part. The pictures do not indicate that at all.
Also the picture indicates that the ball sits in the upper bearing depression:
1) if the depression is simple spherical cutout then you will get sliding friction there and it is likely to be too much for smooth motion (even if it is made from a low friction material like e.g. teflon)
2) if the depression is a groove (shown from the direction of the groove ... therefore seen on the picture as a simple spherical cutout) then it will allow easy movement only in one direction (the direction of the groove)
If you want to have a friction less feeling with balls then the balls must be able to move as well. E.g. to move the pad to the right by one inch the ball must be able to move to the right by half an inch! This is true for any direction.
You do not have any indication in your pictures that you allow for this.
Look .e.g. at this exploded view of a linear bearing:
Notice that the bearing balls are there in "squished" loops. The balls mus be in loops since one side of the loop provides the return path for the moving balls. The other side of the loop actually is the working area. This is the area where balls provide friction less movement between the carriage a the rail. They provide the friction less movement by rolling between the rail and the carriage surface. But because of this rolling they are also moving along the loop. Therefore they need the return path. The balls are exiting the working area of the loop ... returning through the return path  and entering the working area on the other side.
Balls move through the working area without friction since they are rolling. This is also the area where the balls are under load (possibly high forces between carriage and rail). The balls are not moving without friction in the return path. But the friction is very low there since there is no load on the balls.
Your design does not address the moving ball problem at all. That is the reason I pointed out other options (magnetic levitation, ...).
« Reply #7 on: Mon, 01 June 2026, 05:24:46 »
Interesting, I have previously seen sliding palm rests of plastic/foam with teflon pads underneath. A premium variant of that concept would be something.
I have also had a pair of "ErgoRest": rests on mechanical arms clamped to the desk's edge, that allowed some movement. However, if you stretched the linkages too far, they instead provided resistant to sideways movement, so I found them to be more of a nuisance than help.
I think I had found them at a thrift store, and gave them away to a board member.
  • ~ BOOO ~
« Reply #8 on: Tue, 02 June 2026, 20:47:14 »
The gap left and right between upper and lower part was supposed to suggest that.
But you are right, I should have drawn the gap in grey like this ...
317359-0
In the 1st and 2nd version I did it right...
No idea why I turned the area blue in the third one ^^;
The cutout in my drawing is cylindrical, and supposed to hold split spherical bearing seats...
This way the ball wont ride on the base material, and we wont need super precise spherical cutouts.
From what I remember, these split seats also allow adjustment of the friction as they are set in a thread.
But it was a long ago I used these the last time, so I could be wrong here. Wouldn't that allow for smooth motion?
« Last Edit: Tue, 02 June 2026, 21:24:02 by TheSoulhunter »
  • ~ BOOO ~
« Reply #9 on: Tue, 02 June 2026, 21:07:12 »
I have also had a pair of "ErgoRest": rests on mechanical arms clamped to the desk's edge...
You mean these? :D
317361-0 317365-1
I used them for about a decade...
Finally the pivot-joints got too wobbly and I got rid of them.
I really liked them for use in the "wide stance" (mouse + left side pad, ie. while gaming).
« Last Edit: Tue, 02 June 2026, 21:09:02 by TheSoulhunter »
  • ~ BOOO ~
« Reply #10 on: Tue, 02 June 2026, 21:21:51 »
Wouldn't a static magnetic field that repels PartA from PartB also force it to stay off-center?
I can imagine static magnets working for one axis, but how would it work on two?
Please elaborate the magnet arrangement... ^^:
Offline vvp
« Reply #11 on: Wed, 03 June 2026, 05:15:04 »
Probably not. There will be friction between the seat and the ball. I doubt this is better than just two simple planar surfaces from some low friction material (e.g. teflon). No need to complicate it with balls when you are not using them to eliminate friction on the load bearing surfaces.
My guess is that the balls only make the forces more concentrated to a smaller area leading to more wear.  Better to keep pressure (forces per unit area) smaller overall by two simple planar surfaces from a low friction material.
« Last Edit: Wed, 03 June 2026, 05:16:39 by vvp »
Offline vvp
« Reply #12 on: Wed, 03 June 2026, 05:26:23 »
I do not know how to do it exactly. I know only that it can be done for sure since maglevs and linear motors exist. It is possible this cannot be done well only passively (only as an a suitable arrangement of permanent magnets). Active control with linear motors may be needed.
Maybe there is an expert on magnetic levitation here who can chime in  ;D
Offline vvp
« Reply #13 on: Wed, 03 June 2026, 06:02:52 »
If I would be doing this then
I would probably start with simple smooth planar surfaces from a low friction material.
If it would not be enough I would probably add an air pump which would create an air cushion between the surfaces (one of the surfaces would have a grid of small holes and air would be pumped between the surfaces). Check whether it is acceptable despite possible noise, air flow disturbing hands.
If this would not be good enough then I may play with magnets whether some suitable arrangement can be created. Maybe an simulation to search through all the possible magnetic field arrangements.
  • ~ BOOO ~
« Reply #14 on: Wed, 03 June 2026, 09:11:32 »
Okay, I guess that's something I could make myself for a test, without ordering any parts like the split-seats.
I got Teflon skates, and round stock material in Aluminum, V2A Stainless, and Mild-Steel.
Gonna report back with some pictures and impressions.
Thanks for your input! :)
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« Reply #15 on: Sat, 11 July 2026, 00:53:27 »
That’s a brilliant concept! Honestly, the "hovering while supported" feel is a game-changer for split boards.
I actually bought a very similar sliding wrist rest a while ago. It’s also split and has a silicone pad that tilts and supports your wrist at any angle, and it even has RGB built-in.
  • ~ BOOO ~
« Reply #16 on: Sat, 11 July 2026, 06:53:17 »
Thanks for ya kind words...
Is your wrist-rest this thing by any chance?
317702-0
Are you willing to share your experience?
Is the range of motion good enough?
Is the addition of tilting helpful?
« Last Edit: Sat, 11 July 2026, 07:01:54 by TheSoulhunter »
  • ~ BOOO ~
« Reply #17 on: Sat, 11 July 2026, 07:01:14 »
While looking for the mentioned wrist-rest...
I even found rests that seem to ride on actual ball-bearings:
317704-0 317706-1
But these would have to ride on the desk, which is something I want to prevent.
The "tray" (lower part of my Puk) is not only to confine position, but also to prevent wear/marks on the desk-surface.
I am currently experimenting with Puks that use Teflon/Dynema feet (before committing to serious machining and balls).
Offline vvp
« Reply #18 on: Sat, 11 July 2026, 10:10:28 »
That product actually seems to support  a wrist (instead of the palm near the wrist) on the picture.
Does anybody use such a thing? No problems with it?
I mean it looks to me a bad idea since veins are near the skin there and will be more restricted by pressure from the support. Supporting a palm (near wrist) is not an issue since it has evolved to withstand pressure there. Our body has a natural "padding" there.
  • ~ BOOO ~
« Reply #19 on: Sat, 11 July 2026, 18:20:17 »
The photographer, as well as the model, might not know how the products works...
317721-0 317723-1
I see no reason why you couldn't position your hand one or two inches further back on that thing.
Offline vvp
« Reply #20 on: Sun, 12 July 2026, 07:22:49 »
Well, those images are quite a new level of cringey  :eek:
Offline PandaKB
    • PandaKB
« Reply #21 on: Mon, 13 July 2026, 03:09:54 »
Spot on, that's exactly the one!
The movement is actually great—the bottom uses regular mouse feet, so sliding it around is incredibly smooth, and your palm sits comfortably on that top silicone layer.
The tilt feature is definitely a massive plus. When you're typing, your hands naturally shift and tilt slightly. Because the center support tilts along with your movement, it provides really solid, dynamic support. My overall take? It's definitely worth a try!
  • ~ BOOO ~
« Reply #22 on: Mon, 13 July 2026, 07:52:59 »
Thanks for your response...
I gonna order one for testing!
Offline PandaKB
    • PandaKB
« Reply #23 on: Tue, 14 July 2026, 20:38:08 »
I’d highly recommend going with the black version. I bought the white one before, and it had some tiny black specks and impurities on the surface—probably from dust or debris getting into the mold during production. I actually had to exchange it a few times just to finally get a white one that was basically flawless.
