Author Topic: [IC] Eclipse TKL  (Read 84925 times)
Offline shiva1796
    • https://www.nyxkeys.com/
[IC] Eclipse TKL
« on: Tue, 02 June 2026, 21:03:22 »
Introducing Eclipse [GB is now Open]
At the moment of Ragnarök, the mythic wolves finally seize the sun and moon. Eclipse is that moment. NyxKeys' first tenkeyless draws from one of the most powerful images in Norse mythology, the relentless chase of Sköll and Háti, wolves who pursue the sun and moon across the sky until the end of all things. Eclipse is that collision made metal.
Hey everyone,
We're excited to share Eclipse, our upcoming TKL keyboard project. Eclipse is inspired by Norse mythology, built for people who want a premium typing experience without compromise.
Overview
Eclipse comes in two editions:
Standard Edition – CNC-milled aluminum comes with a stainless steel weight for base config,with a choice of colorways, weight materials and accent options plus more premium finishes, built for a refined, high-end finish.
Ragnarök Edition – A premium variant featuring a brass bottom and 3 exclusive Cerakote finishes that will be revealed during the group buy. Limited and special only 20 units will be made.
Technical Highlights
✓ Front Height – 17mm front height, 22.9mm EKH
✓ F12 Layout – Comes in both WK and WKL configs.
✓ Mount Options – Top mount and gasket mount both supported
✓ Acoustic Dampeners – Removable dampeners included for top mount. These sit between the case to reduce metal-to-metal contact and let you tune the sound to your preference.
✓ PCB Compatibility – H87 and UDB PCBs supported
✓ Switch Support – MX, Hall Effect, and EC flavors via compatible H87 PCBs, Alps is in the works and will be purchaseable later.
✓ Solid Build – Default configuration weight of 5 lbs, stainless steel weight included
✓ Swappable Accent – Accent piece is swappable for customization
✓ QMK + VIA Support – Fully programmable
Exploded View
Eclipse features a removable acoustic dampener designed for top mount use. It sits between the switch plate and top case, cutting down on metal-to-metal contact and giving you an easy way to tune how the board sounds and feels without any permanent changes.
Colorways
Eclipse launches with a strong lineup of colorways. Standard colorways are included at base price, with premium Cerakote options available at an additional cost.
Standard Colorways
Daedelus Raw with GMK Salamander
Nyx Black with GMK Black Snail
Hades Burgundy with GMK Ishtar
Gaia Brown with GMK Sloth
Artemis Green with GMK Brtitish Racing Green
Dionysus Purple with GMK Frost Witch
Niddhog Blue with GMK Hyper Fuse
Some of the weight options, more in works.
Raw Stainless
Black Stainless
Black Brass
Brass Patina
Premium Cerakote Colorways
Black Ice
Poison Ivy
Bone Dust
Nocturne
Photos of Black Ice Variant
Photos of Aluminum Patina variant
Ragnarök Edition
The Ragnarök Edition is for those who want something truly unique. It features a brass bottom for added weight and a distinct look, paired with exclusive finishes that won't be available on the Standard Edition. These colorways will be revealed when the GB goes live.
Fenrir
Ginnungagap
Sound Tests
Alu Plate with HMX Aperol
https://www.youtube.com/shorts/LBUnpT_Y6vI
Alu Plate with Keygeek M3
https://www.youtube.com/watch?v=Zxi0EMkExes
Alu Plate with MX2a Browns
https://www.youtube.com/shorts/Si4Suad-lrY
Alu Plate with HMX Cthulhu
https://www.youtube.com/shorts/5salVwN2mAo
More review videos and content is on its way!
Base Unit – Starts at $430 USD, includes a stainless steel weight
Premium Cerakote Colorways – +$125
Ragnarök Edition – Pricing starts at $900 USD only 20 units.
Development Progress
Design – Finalized
Prototypes R2 – on their way to Reviewers
PCB – H87 and UDB
Firmware – QMK + VIA
Vendors
Canada/US - NyxKeys
UK/EU - Thocc Exchange
Italy/EU - Coffee Keys
Oceania - Keebz N Cables
SEA - Pantheon Keys
Join the Community
Eclipse is still in development and we want your input. Our Discord is the best place to stay in the loop and have your voice heard.
Discord: Join NyxKeys Discord
Website: NyxKeys Official Website
"Eclipse is our take on what a TKL should be: purpose-built, Norse-inspired, and made to last."
More updates coming soon ⚡️
« Last Edit: Thu, 23 July 2026, 13:52:24 by shiva1796 »
Offline shiva1796
Re: [IC] Eclipse TKL
« Reply #1 on: Tue, 02 June 2026, 21:04:15 »
June 3rd 2026
- Added Vendors
« Last Edit: Wed, 03 June 2026, 21:22:05 by shiva1796 »
Offline victoriarose101
« Reply #2 on: Tue, 02 June 2026, 21:07:30 »
HOLY MOLY SHIVUSSY! THIS IS AMAZING!
Offline rogueserenity
« Reply #3 on: Tue, 02 June 2026, 21:09:48 »
I'm all in on this board!
Offline 1platy
« Reply #4 on: Tue, 02 June 2026, 21:11:29 »
WHERE DO I SIGN UP (again)
Offline F.Helmet
« Reply #5 on: Tue, 02 June 2026, 21:20:11 »
WTB Eclipse TKL
« Reply #6 on: Wed, 03 June 2026, 01:37:13 »
Will there be vendors?
Offline shiva1796
« Reply #7 on: Wed, 03 June 2026, 08:10:15 »
Yes! we're working on finalizing them this month
Offline navidthekeebguy
« Reply #8 on: Mon, 08 June 2026, 09:47:08 »
Streamed the proto few weeks ago and it was stellar. When are you getting the new proto's with gaskets? Excited to hear he other mount.
Offline Fede_Feo
« Reply #9 on: Tue, 09 June 2026, 05:29:26 »
Nice design Shiva :) good luck with the IC
Offline shiva1796
« Reply #10 on: Tue, 09 June 2026, 19:05:52 »
Thankyou! your stream was great. We should be getting the gaskets and R2 protos in by the end of this month!
Offline shiva1796
« Reply #11 on: Tue, 09 June 2026, 19:06:15 »
Thankyou Fede!
Offline LotGlen
« Reply #12 on: Thu, 18 June 2026, 13:44:47 »
This board is insane. I don't understand. How can you have EVERY SINGLE VARIANT BE SO AWESOME?!.
Count me in for this one for sure. You guys keep on bringing the heat and dialling further and further in. I adore the design of this. Keep it coming, guys!
Offline EdgeOfInfinity
« Reply #13 on: Wed, 01 July 2026, 19:02:22 »
good luck with the project, but hasn't this named already been used for a board?
Offline shiva1796
« Reply #14 on: Thu, 09 July 2026, 22:15:37 »
Thankyou for the kind words they mean a lot! <3
Offline shiva1796
« Reply #15 on: Thu, 09 July 2026, 22:19:33 »
Thankyou! yes unfortunately we found out a bit late that an FRL tkl called Eclipse exists too, we tried diffrentiating the 2 by calling ours Myrkvi(Eclipse) Eclipse is the romanized name. So functionally it's "Myrkvi (Eclipse)" rather than a straight Eclipse-vs-Eclipse naming clash. Appreciate the heads up though!
Offline shiva1796
« Reply #16 on: Thu, 23 July 2026, 13:52:00 »
GB is now open.
Offline BossKeebs
« Reply #17 on: Tue, 28 July 2026, 12:06:26 »
I like the finish and the design. How did you do that?
