Author Topic: [IC] KKB Cobalt - US/UK/FR/DE base kits! | GB live!  (Read 133452 times)
Offline The Switch Journal
« on: Mon, 08 June 2026, 15:09:08 »
>>>> Group-Buy Thread <<<<
Hello everyone! I would like to introduce to you this little project I've been working on for the past 6 months.
(renders by MiKeyDigit)
>>>> Interest Check Form <<<<
Please if possible fill out this form and leave your feedback, it helps a lot.
Discord server
● Intro ●
Hi everyone! Here is KKB Cobalt, my first keycap project. I have set out to release a set of keycaps because of the frustration I had seeing so many beautiful sets releasing (more specifically made of quality ABS) - but none in my local layout which I love, so I ended up asking myself "why not giving it a try?" and here we are. Of course, it doesn't mean that I'm not gonna support other layouts!
For the design I wanted to do something sober but with a slight flair, being inspired by GMK Blanc sur Noir I really wanted to see how the tulips would look on a deep blue set of keycaps, and boy I wasn't disappointed. Of course I got the ok from BsN's designer so no worries.
● Kitting ●
Base kits
Child kits
Alert Row / Extension kits
RAL Colors
● Vendors ●
EU/FR: DeltaKeyCo
EU/DE: Monacokeys
US: Divinikey
UK: Proto[Typist]
AU: KeebzNCables
CN: Zfrontier
KR: Geon
SEA: Ktechs.store
Global: Unikeys
CN (in-stock only): Keykobo
● Details ●
Manufactured by Keykobo
ABS double-shot keycaps
Novelties (including “NoFR/DE NoBUY”) as well as tulip keys are going to be UV printed
Price: expected under 100€ VAT included for FR and DE base kits, under $90 USD for US + UK base kit (expect the usual KKB prices)
MOQ: 350 total between the 3 base kits (combined)
GB date: Expected 28th August 2026 - 06th October 2026
Novelties made by EricSky - Thank you for everything you’ve done for me my friend.
● Collabs ●
Custom cable: Khor will be doing a cable following the set's color scheme.
If anyone is interested into making any kind of collab like an artisan, a deskmat, anything, here are my contact infos:
Email: theswitchjournal@gmail.com
Discord: @aurorepoke
● Additional renders ●
● IRL sample pics ●
« Last Edit: Fri, 28 August 2026, 10:42:49 by The Switch Journal »
Re: [IC] KKB Cobalt - US/UK/FR/DE base kits!
« Reply #1 on: Mon, 08 June 2026, 15:10:07 »
[July 28th 2026] - Updated kitting (added F13 into Base kits) | Exact expected GB dates added.
[June 29th 2026] - New vendor for China (Zfrontier).
[June 12th 2026] - Updated kitting (additional 1.5u Super and 1u rAlt added into the Base kits — Stepped Ctrl moved from Base kits to what were previously known as the "Alert" kits, now named "Extension" kits — Shine-through Caps-Locks, Num Locks, and Scroll Lock, added into the Extension kits — Regional keys NoFR/DE NoBUY in reversed colors added into the FR/DE Extension kits — White 6.25u and 7u added into the previously known "40s and Split" kit, now known as the "40s and Spacebars" kit — Q, E, and M keys without sub-legends were added into the DE Base kit — 1.75u Shift was added into the Novelties kit — Fixed render mistakes on the FR Base kit (1.75u shift icon aligned on the top instead of center as well as pgup and pgdn using GMK's icon instead of KKB's). | A new vendor joins the project: Ktechs.store based in Singapore | added Khor's custom cable into the collabs | Narrowed down the expected GB date.
« Last Edit: Tue, 28 July 2026, 16:37:01 by The Switch Journal »
« Reply #2 on: Tue, 09 June 2026, 16:24:10 »
Approval bump :thumb:
Offline Celty
« Reply #3 on: Tue, 09 June 2026, 16:38:35 »
That's obviously a big yes!
« Reply #4 on: Tue, 09 June 2026, 17:36:32 »
Yes
Offline rob2kx
« Reply #5 on: Tue, 09 June 2026, 18:14:05 »
That blue *chef's kiss*
Love that it doesn't just use the basic accent layout too.
Offline newzealot
« Reply #6 on: Tue, 09 June 2026, 20:45:05 »
The Novelties bottom row 2.25U and 2.75U are for shift keys or spacebars?
Could you swap their places, as normally the 2.25U is on the left and 2.75u is on the right.
Or if you could do a render with them, it would be even better (Alice if they are spacebars)
Offline IBMweMissU
« Reply #7 on: Wed, 10 June 2026, 01:34:01 »
Love the colors, how about adding shine through CapsLock, NumLock? KKB sets usually offer them
« Reply #8 on: Wed, 10 June 2026, 01:44:54 »
Love the set and the compatibility ! So hyped to see the GB, vendors are amazing !
Offline d3smo
« Reply #9 on: Wed, 10 June 2026, 01:59:10 »
ISO/FR double Shot ABS ? You say the words it's an instant YES  :thumb:
Offline Bagri
« Reply #10 on: Wed, 10 June 2026, 02:56:50 »
GLWIC  :thumb:
Keyboard photos - https://www.instagram.com/bagri_shoot
Working on the NP-R -  https://bit.ly/NP-R
Designer of the Alt grrrrr kit - https://bit.ly/altgrrrrr
Offline Plaketdebeur
« Reply #11 on: Wed, 10 June 2026, 04:04:34 »
Nice project, GLWIC
« Reply #12 on: Wed, 10 June 2026, 05:07:56 »
They are for the shifts, and sure I can do that!
I'm a bit afraid that it would push the price over 100€ for us in EU, an alternative might be to replace the R3 controls with the shine-through caps lock if that's something you guys would prefer?
I'll look into it and see what I can do, maybe I'm worried for nothing and I can just add them.
Offline inviz
« Reply #13 on: Wed, 10 June 2026, 11:11:55 »
Give it to me!
Offline pixelpusher
« Reply #14 on: Wed, 10 June 2026, 11:53:53 »
I like the color, but I'm confused.  I wouldn't consider that to be Cobalt blue.  It looks like the deep navy used in GMK Rudy to me.  When I hear cobalt I think of a brighter, more vibrant color.  Maybe this is a deep cobalt?  Also confusing because there is a GMK Cobalt but this has nothing to do with it.
« Last Edit: Wed, 10 June 2026, 13:01:02 by pixelpusher »
« Reply #15 on: Wed, 10 June 2026, 12:08:00 »
I like the color, but I'm just confused.  I wouldn't consider that to be Cobalt blue.  It looks like the deep navy used in GMK Rudy to me.  When I hear cobalt I think of a brighter, more vibrant color.  Maybe this is a deep cobalt?  Also confusing because there is a GMK Cobalt but this has nothing to do with it.
That's how RAL named the color I'm using, so I just went with it, thought a gem theme would be nice so "cobalt" fitted pretty well into it :D
If you google "cobalt blue" you can find a bit of every tone of blue tbh.
Rudy's blue uses RAL 5003, which is indeed pretty close to the RAL 5013 I'm using, just a smidge lighter/less saturated (well, depending on how the designer color-matched it there could be a bigger difference, unfortunately I don't have it to compare).
« Last Edit: Wed, 10 June 2026, 12:20:30 by The Switch Journal »
Offline newzealot
« Reply #16 on: Thu, 11 June 2026, 03:12:37 »
Great, since they are for the shifts, could you add another 1.75U right shift novelty?
2.75U is for full size and TKL, so another 1.75U will fit most smaller keyboards (just like in your US base kit)
« Reply #17 on: Thu, 11 June 2026, 10:02:50 »
Sure, will do!
Will update the renders once I figure out how to include the shine-through caps-lock keys in a way that doesn't push the set over the target price
Offline azhdar
  • Praise the AZERTY god
« Reply #18 on: Thu, 11 June 2026, 16:21:24 »
very nice
Azerty Propagandiste
« Reply #19 on: Fri, 12 June 2026, 10:06:56 »
I updated the kitting following the suggestions from you guys as best as I could!
If this makes you change your mind regarding a particular kit, you're free to change your vote in the IC form.
Offline IBMweMissU
Re: [IC] KKB Cobalt - US/UK/FR/DE base kits! | Updated kitting & more
« Reply #20 on: Fri, 12 June 2026, 14:13:55 »
changed  ;D, thank you for the updates already
Offline newzealot
« Reply #21 on: Sun, 14 June 2026, 01:22:09 »
Oh wow, thanks! You are really very responsive!
I just realised that I had previously watched your review on Jerrzi Misty Purple switches before (or is it Misty Lavender?). Will probably get them together with this set!
« Reply #22 on: Sun, 14 June 2026, 09:17:50 »
I've seen both names being used for this switch.
And thank you (and everyone else) for the support <3
Offline NightFox99
« Reply #23 on: Fri, 19 June 2026, 14:00:46 »
FR + Tulip ? I'm in.
Offline kustom3
  • bonjour
« Reply #24 on: Sat, 20 June 2026, 11:22:13 »
Bon chance
Offline INFILTRATION
Re: [IC] KKB Cobalt - US/UK/FR/DE base kits! | New vendor!
« Reply #25 on: Sat, 11 July 2026, 14:55:50 »
the first bluecaps set that i am actually in love it, therefore, this will be the first blue set i will own.. hurry up with the GB already bro!  :thumb:
« Reply #26 on: Sat, 11 July 2026, 18:13:53 »
Thanks for the support!
The exact dates for the GB will be revealed soon, I'm just waiting for the vendors to get back to me to confirm it's good for them :)
Re: [IC] KKB Cobalt - US/UK/FR/DE base kits! | Updated kitting & GB date!
« Reply #27 on: Tue, 28 July 2026, 16:42:09 »
I added an F13 into the kitting as per requested by a few people, and took the occasion to update the renders with the beautiful logo Stellaidoscope made for me :D
At this point the kitting is final, I'm riding the line as much as I can while keeping the set at the targeted price. Thank you all so much for the feedback!
Also I've confirmed with vendors, the GB should be running from the 28th of August to the 06th of October, so unless something unexpected happens, only one month left before the start!
Re: [IC] KKB Cobalt - US/UK/FR/DE base kits! | GB starts 28th of August!
« Reply #28 on: Sat, 22 August 2026, 23:42:12 »
Less than a week now  :D
Also I made a Discord server (linked it to the top post) in case you prefer that to follow the news / ask questions
Offline Guuuf
  • Discord: Guuuf
« Reply #29 on: Sun, 23 August 2026, 16:30:49 »
That would be my first KKB set, so I’m definitely in!
Born 330 ppm, anonymer Schokoladiker, keyboard enthusiast, age150ramnv8nfx2w740jcqrcewzr88d5xymvqv9asjeamvv0pnad3xqyg8qpt[color]
« Reply #30 on: Fri, 28 August 2026, 10:42:31 »
Group-buy is up!
I've linked the GB thread at the very top of the main post, locking this topic now :thumb:
