Author Topic: [GB] GMK CYL TA Neo | June 19 - July 17  (Read 135324 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« on: Fri, 19 June 2026, 23:46:37 »
GMK CYL TA Neo
June 19th to July 17th
jomes' discord
Timeline
Running from June 19th to July 17th
Fulfilling Q4 2026
Kitting
Base kit $145
Extensions $30
Deutsche mods $42
R5 kit $30
BAE kit $8
International kit (Will be offered at GMK directly after groupbuy)
Colors
Colors will be matched to original TA colors (not GMK TA90).
We'll send the caps over to GMK for a new color match.
Vendors
US - Divinikey
EU - Oblotzky
UK - ProtoTypist
SG - Ktechs
CA - Minokeys
OCE - Cafege
CN - Zfrontier
KR - Geonworks
TH - Aiglatson Studio
Renders
818
818
RF-8X by Keyhub
RF-8X by Keyhub
880X
KIVX
Wooting Alumaze
Offline masje
    • masjewerke
Re: [GB] GMK CYL TA Neo | June 19 - July 17
« Reply #1 on: Sat, 20 June 2026, 02:11:09 »
Reserved
« Reply #2 on: Sat, 20 June 2026, 15:09:41 »
Approved :thumb:
Offline CoolPenguin1
« Reply #3 on: Sat, 20 June 2026, 16:51:16 »
rush rush rush
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #4 on: Sat, 20 June 2026, 17:13:12 »
LET'S GOOOOO
Offline Jampot_298
« Reply #5 on: Sat, 20 June 2026, 18:42:17 »
This is sick. Buy buy buy!
Offline SwearWolf
« Reply #6 on: Sun, 21 June 2026, 17:30:31 »
Hyped on this one!  :thumb:
Offline mr_foggy
  • neue = nope
« Reply #7 on: Mon, 22 June 2026, 15:15:32 »
why did you choose to not match the colors with TA90 as announced in the IC?
« Reply #8 on: Mon, 22 June 2026, 22:27:57 »
I think the colors section was poorly worded.
Masje is colormatching to a TA G81-3011HAD, not the 2015 set. TA90 was also colormatched to a G81-3011HAD so the colors should be very similar.
Worth noting that TA90, while much better than the 2015 set, was a tiny bit off with it's grey (can see if you zoom in on the first pic here https://geekhack.org/index.php?topic=96387.msg2685960#msg2685960) so there is still some room for improvement.
Offline mcmcmc
« Reply #9 on: Tue, 23 June 2026, 07:33:10 »
lets goooo
Offline tactilesbad
« Reply #10 on: Wed, 24 June 2026, 03:35:45 »
excellent. thank you very much for your reply. I'm officially in!
Offline incrediblejr
« Reply #11 on: Tue, 07 July 2026, 05:26:29 »
Definitely in. GLWGB Jomes!
« Reply #12 on: Sat, 18 July 2026, 00:16:11 »
GB extended to July 24 as per protoTypist, I assume this is for all vendors.
