Author Topic: Show us your current Ergo daily driver!  (Read 16761 times)
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« on: Sun, 19 July 2026, 21:42:55 »
Hey everyone,
Is it just me, or has the ergo section been a bit too quiet lately? Let’s change that and get some life back into this place!
I'd love to see what everyone is currently typing on. To kick things off, here is my trust old Corne. Feel like you can't really call yourself an ergo nerd until you’ve owned at least one of these at some point, right?
317807-0
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Show us your current Ergo daily driver!
« Reply #1 on: Sun, 19 July 2026, 23:07:57 »
That's a pretty sweet setup. Also, I like that tube clock / display (are they actual Nixie tubes?)
I'd imagine the ergo kb world is mostly sheltered in dedicated Discord servers & reddit, and I'm not by any means an ergo nerd/connoisseur. But perhaps this thread will kick off things in the right direction and have traction =)
My partner uses a QK Alice Duo, which is more on the recent side of staggered splits, and that's been the mainstay on her desk for some time now.
Offline PandaKB
    • PandaKB
« Reply #2 on: Mon, 20 July 2026, 02:36:54 »
Yeah, you're totally right. Most of the ergo talk has moved over to Reddit and Discord nowadays, which is why it's nice to stir up some life here.
As for the clock, they aren't actual Nixie tubes! They are actually just smart LED lights styled to look like them, though I still love the retro vibe.
The QK Alice Duo is an awesome board! The case design and finish on that thing are so clean and refined.
« Reply #3 on: Mon, 20 July 2026, 04:25:57 »
I don't even use split keyboards but I did join Reddit years ago only for /r/ErgoMechKeyboards. There's a lot more talk about ergonomic keyboards there than here for sure.
« Last Edit: Mon, 20 July 2026, 09:05:06 by Findecanor »
Offline vvp
« Reply #4 on: Mon, 20 July 2026, 08:20:11 »
my (somewhat dirty) daily driver
317810-0
Offline PandaKB
    • PandaKB
« Reply #5 on: Mon, 20 July 2026, 21:27:47 »
Haha, same here! Joining Reddit specifically for /r/ErgoMechKeyboards is practically a rite of passage for keyboard enthusiasts.
Offline PandaKB
    • PandaKB
« Reply #6 on: Mon, 20 July 2026, 21:32:02 »
Haha that is definitely one of a kind! Is that an actual Ethernet cable connecting the two halves? And are those extra keys down by the palm rests?
There's something awesome about wired splits—no pairing issues, no latency, just straight-up rock-solid reliability.
Offline vvp
« Reply #7 on: Tue, 21 July 2026, 07:48:08 »
It is standard non-crossed ethernet cable; i.e. the one used between a computer and a switch/hub. But only 6 wires (from the 8 present in the cable) are used. The ISO link layer does not use Ethernet protocol.
Yes, there is a "palm key" next to the each rest. They are pressed by a palm part which is just next to the thumb root. I use the key as a function shift.
I'm pretty happy  with the keyboard.
There are some views of it from the sides here.
« Last Edit: Tue, 21 July 2026, 07:51:22 by vvp »
Offline fortissim2
« Reply #8 on: Tue, 21 July 2026, 17:11:20 »
It's alright :p
Offline PandaKB
    • PandaKB
« Reply #9 on: Wed, 22 July 2026, 03:21:45 »
That is so OG and hardcore—love the clever use of the ethernet cable and palm keys!
Offline PandaKB
    • PandaKB
« Reply #10 on: Wed, 22 July 2026, 03:29:38 »
It's alright :p
Looks nice! Seeing that stacked acrylic case reminds me of a friend who had a stacked acrylic Corne. He's out of the hobby now, though.
317825-0
Offline fortissim2
« Reply #11 on: Fri, 24 July 2026, 14:48:34 »
It's alright :p
Ohhhhhhhhh he's one-upped me, my life's over.
Also wanted to share my recent Reviung41 build. Got the PCB + switches + caps for free, repaired a few ripped traces, and I laser cut a few missing pieces. So I basically spent less than $20 for this :p
I can't get the underglow LEDs to work with the current version of ZMK. Which is frustrating because when with the previous owner's keymap they worked fine!! I don't know if the BlueMicro840 v1 is no longer supported or if I'm just tech illiterate.
Offline PandaKB
    • PandaKB
« Reply #12 on: Sat, 25 July 2026, 03:13:21 »
It's alright :p
You could try asking GPT to help modify the firmware. It actually works pretty well for this kind of thing.
Offline fortissim2
« Reply #13 on: Tue, 28 July 2026, 14:21:59 »
Yah it's all good now! Funnily enough the ZMK Discord help forum explicitly says to not use gen AI, I was just missing a few lines of code.
Offline PandaKB
    • PandaKB
« Reply #14 on: Tue, 28 July 2026, 21:21:34 »
Nice 😂 Turns out the final boss was just a few missing lines of code.
Offline fortissim2
« Reply #15 on: Wed, 29 July 2026, 22:16:38 »
Immediately got bored and decided to start a new handwired build.
This only has 5 columns / 36 keys, so I have to get used to right-thumb Shift. Eventually I'd like to use a 34-key Ferris Sweep as my daily driver when travelling back and forth for studies (also incentivizes me to not play games on my gaming laptop, I just use it for the GPU power when rendering stuffs)
I designed the unibody case in a day and waited ~2 weeks for my acrylic lasercuts and this 3D print.
Offline luqtas
    • happort
« Reply #16 on: Mon, 14 September 2026, 10:53:29 »
my keyboard with a slant angle (correct scientific term) of 30°, the number is after the most muscle neutral angulation according to the human anatomy arm (you can find these on papers of medicine and even research of ergonomic devices in the naval industry)
the "numpad" at the right is actually a 9 key mouse! also with a 30° of slant. weights ~ 100 grams
« Last Edit: Mon, 14 September 2026, 11:02:19 by luqtas »
