Author Topic: [IC] MW Datenshi  (Read 69481 times)
Offline Minisofu
  • Aspiring Keycap Designer
[IC] MW Datenshi
« on: Thu, 30 July 2026, 01:21:23 »
Hello! My name is Minisofu and this is the IC for MW Datenshi!
Interested? IC FORM HERE
Inspiration
This is another set that was inspired by "TUYU" and this time, by one of their songs named "Being low as dirt, taking what’s important from me".
The main color palette of this set is from the ending of the music video where the angel had become a fallen angel. The main colors are dark gray, red and a off-white with a purple hue
Colours
Disclaimer: Colors chosen may not be accurate or be slightly off, thus please be aware that the colors may come out differently when produced
Keycap Specifications
Profile
Cherry Profile
Production Method and Material
Dyesub PBT
(Unfortunately, I cannot go for doubleshot this time around because MWKEYS are afraid i will not be able to hit the MOQ of the set, so I am sticking to dyesub)
Kitting
Deskmat Renders
Board Renders
Boards: Bakaneko 60, AkkoAlice, F1-8X WK
Samples
Vendor List
EU - CoffeeKeys
SG - ktechs
CA - Unikeys
TBD
Pricing
TBD
Manufacturer
MWKEYS
Contact Me @
Discord : @minisofu | Discord Server
Instagram : @sofucaps
Signature
Help support my set by adding a signature onto your profile! Thank you once again for your support!
Code: [Select]
[url=https://geekhack.org/index.php?topic=126968.0][img]https://i.imgur.com/ppgcj2r.png[/img][/url]
update log:
1. unfortunately, one of the deskmat designs had to be scrapped due to controversial reasons. apologies for this unfortunate turn of events, i will try to avoid anything controversial in my future designs
2. i have reworked and rehashed the old deskmat design and got approval. sorry once again for this mistake
3. updates to entire kitting, added / removed multiple keys into all the kits, refer to comments for the changes made. thank you @konstantin for the feedback :>
4. Samples just arrived for base + novelties, take a look!
« Last Edit: Fri, 18 September 2026, 01:09:23 by Minisofu »
Offline konstantin
  • Formerly constexpr
Re: [IC] MW Datenshi
« Reply #1 on: Thu, 30 July 2026, 13:07:18 »
Some kitting suggestions:
Base kit
  • I recommend moving the R1 1u PgDn and End keys from base to the numpad kit (example) since those two keys are only useful for layouts with numpads, e.g. 1800/CP/96-key.
  • I also recommend removing the second R4 1u Ctrl key from base since there are no non-40% layouts that use two of them.
  • In place of those keys, I recommend adding two R4 1.5u Super keys to base, to support Mac layouts and various HHKB-style boards.
Spacebar kit
  • I'm pretty sure most people prefer alpha-colored spacekeys, so I suggest changing the dark gray keys in this kit to white (to match the spacekeys included in base).
  • You can keep the 2u, 2.25u, 2.75u spaces gray as an alternative if you really want to, but I don't think you need to.
40s kit
  • There are a lot of duplicate keys in this kit which should be removed. For example: R2 1u Delete, R2 1.75u Backspace, R3 1.25u Tab, R4 1u/1.75u Shift, accent arrow keys, R4 1u/1.25u/1.5u Ctrl/Alt/Shift etc. are all already included in the base kit and thus unnecessary in this child kit.
  • Offering only accent-colored spacekeys for 40% boards is weird. Consider changing at least some of them to white.
Offline shansoft
« Reply #2 on: Thu, 30 July 2026, 19:20:15 »
I would totally get this gray color sets if there are options to do gray / white tone instead of red. Reminds me of honeywell sets but better color.
Offline Minisofu
« Reply #3 on: Thu, 30 July 2026, 22:29:10 »
Base kit
Spacebar kit
40s kit
Appreciate the feedback and suggestion lots! ill get to work making those changes! im not too used to this yet so i appreciate every feedback i can get.
Offline Minisofu
« Reply #4 on: Thu, 30 July 2026, 22:32:25 »
are there any suggestions you would like to add? im down to see what i can add in maybe an alt alphas kitting or something else?
Offline snowballs8
« Reply #5 on: Sun, 02 August 2026, 23:17:32 »
Base kit
Spacebar kit
40s kit
drift boss
The color palette looks amazing. The dark gray, red, and purple tones fit the fallen angel theme perfectly.
Offline jigumina
    • Personal site
« Reply #6 on: Mon, 03 August 2026, 11:38:39 »
Another TUYU themed set!! MW Endpoint was great, I hope this one is successful too! ♡ GLWIC!
Offline konstantin
« Reply #7 on: Thu, 06 August 2026, 12:41:12 »
Fair point :)
Offline Minisofu
« Reply #8 on: Thu, 17 September 2026, 03:00:22 »
samples just arrived! they look way better than i could have imagined honestly .
