Author Topic: [Sponsored] Redragon Antonium K745 HE review, hall effect keyboard  (Read 1970 times)
Offline Moogle Stiltzkin
Disclosure: I would like to thank Redragon for providing this keyboard for review. While this model was supplied for evaluation purposes, all thoughts, critiques, and opinions in this article remain entirely my own, honest take.
Redragon's K745 HE brings cheap Hall Effect tech to full-sized keyboards
Pro-grade gaming keyboards are getting way cheaper. Redragon just dropped the Antonium K745 HE, bringing magnetic switches and an 8K polling rate to a full-sized, 108-key layout. This means you get features like Rapid Trigger and custom actuation—the exact stuff Valorant and Apex pros use—without the premium price tag. Plus, it has five layers of internal foam to keep it from sounding hollow. Here is our full breakdown
Unboxing
Package Included
1 x Antonium K745 Magnetic Keyboard
2 x Extra Caps
1 x Type C Cable
1 x User Manual
1 x Keycap Switch Puller
1 x Redragon Sticker
Close up pics
night shot
Design and build quality
Switches
The Redragon K745HE natively uses Redragon's custom full-POM UltraMag magnetic switches.
The inclusion of other options like Gem Mag Pro, Amber Mag Pro, King Magnetic, and Ultra Mag Pro+ in the software dropdown serves a specific structural purpose for magnetic keyboards. Notably, the keyboard defaults to the Ultra Mag Pro+ profile out of the box within the software companion.
Redragon utilizes a unified driver platform for its family of Hall Effect (HE) magnetic keyboards. Instead of coding separate applications for each individual model, Redragon creates a shared software ecosystem that accommodates multiple magnetic switches in their hardware lineup.
Magnetic switch calibration
Unlike traditional mechanical keyboards that only register a binary on/off contact, magnetic switches depend on Hall Effect sensors reading precise magnetic field strengths. Different magnetic switches (like the Gem Mag Pro or King Magnetic) feature varying magnet sizes, magnetic strengths, and physical travel distances.
Providing a drop-down menu allows you to select the correct profile if you choose to swap out the stock switches. Selecting the incorrect switch type in the software causes the driver to misread the magnetic distance, which directly ruins precision features like Rapid Trigger or custom actuation points.
In short, it's crucial that you use the web app to calibrate your switches at least once, and especially if you switch it to another magnetic switch.
    Initial Calibration is Crucial: Out of the box, slight manufacturing variations or environmental factors can cause keys to have deadzones, stick, or fail to register. Running a baseline calibration ensures features like Rapid Trigger and custom actuation points work flawlessly.
    Mandatory for Switch Swapping: Different magnetic switch brands (or even different batches) have unique magnetic strengths, pole alignments, and total travel distances. If you hot-swap the stock switches out for another brand without recalibrating through the Redragon Web App or driver software, the keyboard will read the magnet's distance incorrectly. This leads to severe ghosting or dead keys.
Quick Verification Steps
    Connect your keyboard via its wired USB mode.
    Open the official web companion app or Redragon driver software.
    Locate the Calibration tool, click start, and fully bottom-out every single key to let the sensors register the maximum and minimum magnetic thresholds.
Inside the Ultra Mag Pro+ configuration
The Ultra Mag Pro+ profile handles the precise translations for these specific factory switches. The profile maps out data for custom hardware featuring a full-POM construction and an advanced enclosed base. Polyoxymethylene (POM) is a self-lubricating plastic that yields a buttery-smooth, low-friction glide and a deep, crisp acoustic sound profile.
Additionally, the physical architecture relies on an anti-wobble dual-module floating structure. This design minimizes horizontal stem movement, keeping the magnet perfectly aligned directly over the Hall Effect sensor on the PCB for reliable, uncorrupted signal mapping.
The complete specifications for this switch configuration profile include:
Physical design and construction
      Material composition: Constructed with full POM material and a closed-bottom design, optimizing it for a self-lubricating, deep acoustic profile.
      Dual-module structure: Utilizes a floating structural layout that actively minimizes horizontal key wobble to guarantee stable, linear keystrokes.
      Axis feedback: Configured strictly as a linear axis feel, providing smooth resistance without a tactile bump feedback.
Keycaps
The Redragon K745HE features keycaps molded from premium PBT plastic, ensuring long-term durability and resistance to the unsightly oil and shine common to cheaper ABS alternatives. Even under heavy daily usage, this material choice guarantees the keyboard maintains its crisp, out-of-the-box appearance.
Visually, the most striking aspect of this set is the implementation of rounded keycaps instead of the industry-standard square profile. While this spherical contour feels slightly unusual during the initial typing session, the adjustment period is incredibly brief; the layout quickly feels entirely natural under the fingers. Over time, this distinct aesthetic grows on the user. The spherical design delivers a unique, premium flair rarely seen in this market segment, making the keyboard look remarkably interesting and modern.
The typography on the legends is equally distinct, offering a highly legible font that successfully steers clear of boring, generic gaming typefaces. Almost the entire layout looks fantastic, with only a minor subjective critique regarding a few specific stencils. Notably, the split-legend font used on the "O" and "0" (zero) keys features a distinct gap right down the middle. This design choice causes the characters to resemble two separate parentheses facing each other rather than a cohesive letter or number. While this specific look may catch some users off guard and might not suit everyone's personal preference, it remains highly tolerable. Ultimately, font styling is entirely subjective, but it remains a minor detail that does not detract from an otherwise excellent, premium-feeling keycap set.
Chassis
While the official website specifications remain somewhat vague on the exact material, the exterior chassis appears to be constructed from a dense, high-grade ABS plastic. It avoids the cheap, hollow feel common to budget enclosures, instead offering a rigid and structurally sound base that resists flexing.
This specific variant of the keyboard showcases the stunning Jade Cloud colorway, which features a beautiful two-tone aesthetic consisting of clean white and soft jade green/mint keys. The keycaps are finished with crisp, black-colored fonts that offer excellent contrast when unlit. Once the RGB backlighting is activated, the light shines cleanly through the translucent legends rather than illuminating the entire keycap housing. This creates a highly legible, premium, and visually striking design that looks fantastic in any desktop setup.
The Redragon Antonium K745 HE features a 5-layer sound-dampening acoustic stack integrated into a structural chassis design. This layout is engineered to absorb rigid vibrations and eliminate the "pingy", hollow case echoes common in older budget boards.
This modern gasket layout completely outclasses old-school tray mounts by delivering a much softer feel and superior acoustic dampening. Traditional tray mounts screw the plate directly into stiff plastic standoffs, creating harsh, rigid 'hard spots' around the keys and transferring hollow vibrations straight into the case. By contrast, this gasket design isolates the entire internal assembly with flexible rubber dampeners, giving you a uniform, cushioned bottom-out and a remarkably clean sound profile.
Core I/O and Connectivity Features
The Redragon Antonium K745 HE features a minimalist wired-only design, utilizing a single detachable USB-C port at the back to support an 8,000Hz hyper-polling rate for 0.125ms latency. This streamlined approach includes a dual module floating structure for input stability and a web-based driver for broad compatibility, bypassing the need for dedicated hardware switches or wireless modes.
Accessibility of the Teardown
I did not test opening the keyboard myself because doing so voids the warranty. You should not normally open the chassis unless you have a compelling reason to do so. However, I found a teardown guide for the Antonium K745 Pro. This model is very similar to the K745 HE, with a few key differences: the K745 HE features magnetic Hall Effect switches and lacks the lithium battery used for wireless connectivity. Despite these internal changes, the process for opening the chassis to access the internal components is likely identical.
The video is a tear-down for the Antonium K745 Pro, whereas the picture below is of the K745 HE.
RGB Backlighting and Lighting Effects
The RGB backlighting on the Redragon K745HE is truly spectacular, offering impressive vibrancy and highly engaging customization options. At peak performance, the maximum brightness level is brilliant and punchy, though it can easily be dimmed down or shut off entirely for users who prefer a more understated, stealthy look.
Where the illumination truly shines is in its diverse selection of dynamic profiles. Standard lighting presets are excellent, but integrating the specialized music plugin elevates the visual experience to an entirely new level, allowing the keys to pulse and react seamlessly to your audio. Among the available options, "Blossom Prosperity" stands out as a personal favorite for static or casual use, while the highly energetic "Clouds Rising, Snow Flying" profile delivers an exceptional audio-reactive music effect.
The layout includes a unique feature: an integrated RGB light bar that lines the chassis perimeter. While this perimeter strip cannot be adjusted through the companion desktop software, it is fully customizable directly on the hardware. By pressing FN + Pause, you can cycle through various side-lighting effects or turn off the light bar entirely if it becomes distracting. This dedicated hardware control ensures the overall lighting system remains fantastic, delivering a highly immersive visual flair that beautifully accentuates the transparent keycap legends.
Sound and Feel: The On-Desk Experience
The Redragon Antonium K745 HE is engineered to deliver a premium sensory experience optimized for competitive gaming. Because it utilizes advanced magnetic switches, the overall profile focuses on ultra-smooth, linear speed paired with structural stability.
What Does It Sound Like?
    Deep, Muted Bottom-Out: The K745 HE features full-POM UltraMag magnetic switches. These deliver a lower-pitched, deeper acoustic profile (thock) rather than a sharp, high-pitched click or clack, largely thanks to the dampening layers absorbing harsh frequencies.
    Solid and Resonance-Free: Hollow case echo is heavily suppressed. The board utilizes a 5-layer noise-dampening system inside the case, trapping ambient vibrations so you only hear the clean slap of the POM stems without any annoying metallic pinging.
How Does It Feel?
    Frictionless, Float-Like Glide: Travel on a purely magnetic axis with zero internal leaf springs to scrape or resist. Paired with self-lubricating POM switch stems, every keypress delivers an exceptionally consistent, ultra-slick, and completely scratch-free actuation.
    Stabilized Gasket Structure: Engineered with a premium gasket-mounted design, the keyboard absorbs harsh bottom-out impacts for a softer typing feel and dampened acoustics. Underneath, it utilizes a specialized dual-module floating structure. This design ensures that despite the cushioned housing, the keybed maintains the absolute stability needed for ultra-precise Rapid Trigger adjustments down to 0.1mm.
    Hyper-Responsive & Light: Because you can adjust the actuation points via software, the keys can feel hair-trigger light. A mere graze of the finger can register a keystroke, resulting in an effortless typing experience that requires minimal finger force but demands a bit of accuracy to avoid accidental typos.
Web-Based Software Interface
A massive quality-of-life feature for this model is that it does not require downloading or installing bloated desktop software. Instead, Redragon utilizes a highly responsive web application accessible directly through Google Chrome at https://demo.hubx.pro/keyboard/. The lone exception to this driverless ecosystem is if you choose to install the optional music plugin, which is required to unlock the audio-reactive RGB backlighting effects.
The web-based configuration utility offers a comprehensive suite of customization options, giving users complete control over macro mapping, custom key profiles, and individual per-key actuation adjustments. For a complete visual walkthrough showing every single menu, setting, and feature available inside the interface, you can check out the comprehensive software demo video linked below:
Manual
Dual Platform Driver Support
Redragon expanded driver accessibility for the K745HE by moving from a single-platform model to a flexible, dual-platform ecosystem.
Exploring Advanced Antonium K745 HE Web App Settings
1. Adjusting Actuation Points & Advanced Trigger Modes
Traditional switches register a press at a fixed depth. The K745 HE lets you choose exactly how deep you have to press a key to trigger it, while unlocking specific behavioral profiles like MPT, MT, TGL, and END.
Alternatively, if you don't want to manually set it up, and you simply want to set it up quickly, you can use the presets.
    Multi-Point Trigger (MPT): This mode lets you assign multiple distinct actuation and reset thresholds to a single key strike, giving you granular control over exactly when an action starts and stops during the travel distance.
    Mod-Tap (MT): Dual-function mapping. A quick tap triggers a normal keypress (e.g., Space), while holding the key down activates a modifier function (e.g., Shift or Ctrl).
    Release Trigger (END): Inverts the traditional trigger logic. Instead of firing an action when you press the key down, the command executes the exact moment you fully release the key.
2. Ultra-Fast Rapid Trigger
Rapid Trigger resets the key the exact micro-second your finger begins to lift, rather than waiting for the switch to clear a fixed reset point. This allows for incredibly fast repeated tapping and instant stopping in tactical shooters.
3. Multi-Action (DKS / Dynamic Keystroke)
While Multi-Point Trigger (MPT) maps actions strictly to downward depth, Dynamic Keystroke (DKS) unlocks the true power of magnetic sensors by tracking the entire travel loop. It allows you to map up to 4 independent actions to a single key strike based on four exact points: the initial press down, the bottom-out, the initial release lift, and the final finger lift.
Here is a video demo
4. Customizing the Team Wipe Engine (SOCD / Snap Tap)
The K745 HE features a built-in hardware engine designed to handle overlapping inputs—similar to Snap Tap or SOCD (Simultaneous Opposing Cardinal Directions). If you press "A" and "D" at the same time, the keyboard decides which one takes priority rather than cancelling both out.
Here is a demo for how jiggle strafing works.
5. Activating 8K Hyper-Polling
By default, most keyboards send signals to your PC 1,000 times per second (1K Hz). The K745 HE supports up to 8,000Hz hyper-polling, reducing input latency down to a mere 0.125ms.
These articles explain polling rates in detail, as well as what to watch out for in dual 8K setups (mice + keyboard) to avoid performance issues:
    https://redragonshop.com/blogs/community/mo...-rate-explained
    https://attackshark.com/blogs/knowledges/us...ice-setup-guide
Macro Settings
The Macro Configuration menu on the Redragon K745HE web driver serves as a powerful tool designed to streamline execution and maximize player efficiency. At its core, this feature allows users to automate complex keystroke sequences, mouse actions, and precise timing intervals, condensing multi-step commands into a single button press. By mapping these custom-recorded scripts to specific keys, players can eliminate the physical travel time and inevitable human error associated with executing intricate inputs manually.
Visual Feedback Inspection
After configuring your keyboard, you can use the visual monitor to test your actuation and release settings in real time. Combining the tactile feel of pressing the keys with this live visual data gives you a much clearer sense of whether your current profile is ideal or needs further calibration.
Base Functions
This section includes several utility settings, with the polling rate being the most critical. Since you chose a Hall Effect keyboard, you should maximize its performance by selecting the 8,000 Hz polling rate. If your computer experiences performance drops, simply lower the rate to 4,000 Hz or 2,000 Hz. For context, standard mechanical keyboards typically operate at a 1,000 Hz polling rate.
As for the Windows key lock, using the physical keyboard shortcut is often much faster than toggling it through the web app. Simply press FN + Win to lock the key before gaming, and press it again to unlock it when you are finished.
Device Info
This menu allows you to update your firmware, check your current software version, or perform a factory reset. However, using the physical shortcut keys directly on the keyboard is often a faster and more reliable way to factory reset the device.
Profile Management
Once you finish customizing your configuration, you can use this section to back up your current profiles or import previously saved ones.
Some useful tips for the Antonium K745 HE keyboard
Change lighting for the thin horizontal rgb strip
If you want to change it's effect or turn it on/off do this
Change Effects / Cycle Modes: Press FN + Pause/Break simultaneously. Each press will cycle through the different RGB animations and solid colors designed for the strip.
Turn Off Completely: Keep pressing FN + Pause/Break. The final mode in the cycle turns the light strip completely off.
Restore factory settings
Press and hold [FN] + [ESC] for 3 seconds.
You don't normally do this, but if you want a clean slate and not sure what you changed, or if you had an issue and want to try fix it, factory resetting is your go to option. If you have any stable profiles you painstakingly set, I highly recommend you back those up under the profile management in the web app.
Performance
Here is some PC gameplay footage from Apex Legends.
I didn't play my absolute best, but we managed to get 2nd place in ranked, so that definitely counts for something! At 16:20 demonstrated some jiggle strafing, definitely felt smoother thx to team wipe engine aka SOCD.
We won one ranked diamond
Conclusion
This was my first time reviewing a Redragon product. I expected a budget-friendly and highly competitive device, and that is exactly what it is. However, as detailed in my earlier assessment, the exceptional build quality genuinely surprised me.
It definitely gives you an edge during gameplay, especially in fast-paced, key-sensitive genres like first-person shooters. As you saw, I even managed to win an Apex Legends ranked diamond match. Even though my own play was awful—a total personal skill issue—the keyboard was responsive enough to help me dig in and pull off the win.
If you want a step up to a more premium Hall Effect keyboard with a similarly modern gasket design, Redragon offers the PENUMBRA K687 HE Rapid Trigger Gaming Keyboard. Like the Antonium, it is wired, features an 8000Hz polling rate, and uses Hall Effect switches. However, unlike the Antonium K745 HE, the Penumbra features a 75% layout with 81 keys and a CNC aluminum frame. The entire chassis is crafted from solid CNC aluminum with an advanced frosted finish, keeping the keyboard stable, elegant, and premium. It also adds a control knob, blank top keycaps, and side-printed translucent legends for the RGB lighting to shine through. The main selling point here is the aluminum build, targeting users who want a premium weight and are willing to pay extra for it.
However, that does not take away from the Antonium K745 HE. Some users may actually prefer the Antonium's color scheme, rounded keycaps, and overall font aesthetics over the Penumbra. It also costs less, making it a highly affordable entry point into high-quality Hall Effect performance.
Do I recommend the Antonium K745 HE? Yes, definitely, especially if you are a gamer and looking for a competitive edge. I did not find any major issues with it.
« Last Edit: Thu, 30 July 2026, 17:20:09 by Moogle Stiltzkin »
Royal Kludge discount code:
Lowyat15
15 USD discount.
Re: [Sponsored] Redragon Antonium K745 HE review, hall effect keyboard
« Reply #1 on: Thu, 30 July 2026, 17:32:44 »
If anyone has questions they want to ask about the keyboard, let me know.
Lowyat15
15 USD discount.
