Author Topic: [GB] GMK Orange Alert - 8/14/26 to 9/14/26 | GB Successful  (Read 145771 times)
Offline baucts
« on: Tue, 11 August 2026, 18:46:03 »
GMK Orange Alert
Aug 14th - Sept 14th
Est Shipping 4-5 months
About
alert-like set but orange. thats about it. i like orange.
Colors
same orange as gmk orenji which will reduce cost
Kits
Vendors
USA: Divinikey
EU: CoffeeKeys
UK: ProtoTypist
CA: Unikeys
CN: KBDFans
SEA: Ktechs
JP: Yushakobo
OCE: Keebz N Cables
Prices
Keyboard Renders
^finn60xt by baucts
^marcy80 by baucts
^txuu by ?
^titan65 by phase studio
^m60a by r*m*w*rks
IRL Color Samples Library
Colors under different lighting
Updates During IC Phase
5/27/26: ty everyone who filled the ic, here are the updates so far:
- moved alert row to base kit and adjusted kitting
- added concave homing to kit; now concave and bar homing
- removed dot from numpad 5; changed to bar homing
- removed accent row child kit and replaced with alertless child kit and adjusted kitting
5/27/26: part 2, added question regarding katakana alert row to ic form
5/30/26: kitting changes for base and extensions, int kit:
  - base:
    - changed print to prt sc
    - changed 1.5 r2 backspace  to text only
    - added dark pip to base kit
    - added dot back to numpad 5
  - extensions:
    - added 2x 1u alt
    - added stepped control
  - questions added to ic to keep row 5 or change to row 4
  - for the cherry logos, currently it is evenly split for keeping modern, keeping vintage, and keeping both so no changes to them for now
  - working on an int kit, will reference gmk violet alert for kitting
  - considering using orange from gmk orenji or gmk kaiju if i will reduce the cost
6/2/26: color change, added nordeuk, alert and alertless in alpha kits
  - change original orange (ral 2008) to gmk orenji orange (pantone 1505 c). this will reduce the cost since the pantone has been made already so no need for sampling ;D
  - added nordeuk kit based on gmk violet alert, alertless and alert row as this is an alert set
  - fixed katakaka renders and added alert row because again, this is an alert set
  - "this is an alert set"
6/12/26: improved 40s support, corrected renders
  - added r3 1.75u enter
  - added r2 1u backspace
  - may remove r2 esc keys depending on price
  - removed pause key in alertless kit (idk why it was in there)
  - corrected a key on the int kit render
  - improved renders a bit in general
6/14/26: messed up the renders for the last updates, fixed now (wrong keys in extensions, wrong legend for backspace key in base)
6/14/26: orange color samples and removed r5
  - color samples for pantone 1505 c came in and im very happy with it, it will be the color used for the gb
  - added color sample library with cool, neutral, and warm colors. compared with u9 and l9. also with gmk stock oranges
  - changed to r4 from r5, r4 was the popular choice
7/5/2026: we got vendors. and kitting is mostly done. added a dedicated r5 kit proposal (not confirmed so dont get your hopes up)
7/23/2026: numpad vote, still debating on r5 kit
  - added vote to see if numpad should be in base. current base kit msrp with numpad is ~$155 usd (subject to change)
  - r5 kit is ~$70 usd, price chould push some out despite initially saying they are in for the kit
7/24/26: updated renders
8/4/26: kits finalized and prices
  - kits are finalized
  - prices for usa finalized, prices from vendors outside the usa may vary
  - tkl base and numpad kit
  - made renders match final product more (fixed legends)
my discord server
my instagram
thanks to valkurize for looking over the set and giving some advice on prepping the ic. ty to captain sterling for hearing me out on potentially working with omnitype to run the set if there is enough interest. thanks to dvorcol for helping me understanding kitting better. thank you rayhhdailo for insight on how to source better prices. thank you 40s discord for letting me know which keys i should add for more 40s support
« Last Edit: Fri, 02 October 2026, 20:22:13 by baucts »
Offline baucts
Re: [GB] GMK Orange Alert - 8/14/26 to 9/14/26
« Reply #1 on: Tue, 11 August 2026, 18:53:12 »
10/2/16: ty all for joining, we will be entering manufacturing soon! join one of the vendors or my discord server to keep up with updates
« Last Edit: Fri, 02 October 2026, 20:21:19 by baucts »
« Reply #2 on: Wed, 12 August 2026, 10:51:54 »
We just need Yellow after this for the full Spectrum
Offline KR15T0F3R
« Reply #3 on: Thu, 13 August 2026, 06:01:55 »
Awesome set! Really looking forward to this!
Quick question, since I can see the set in upcoming GB on most sites, but non have the NorDEUK set. Will it not be available? Truly hope so, otherwise I cant use it. Thanks man!
Offline dangboy
  • yes
« Reply #4 on: Thu, 13 August 2026, 10:55:09 »
YES FINALLY FRICK
Offline baucts
« Reply #5 on: Thu, 13 August 2026, 12:03:59 »
nordeuk will be available on gmk's website after the groupbuy. that way i dont have to worry about it reaching moq to be produced.
Offline Teizoku
« Reply #6 on: Fri, 21 August 2026, 03:17:48 »
You should be able to set up the in-stock notification for the international kit on the GMK webstore already. That way you won't miss the release :)
Online dvorcol
  • Discord: dvorcol_5071
« Reply #7 on: Sat, 22 August 2026, 00:33:51 »
Offline victoriarose101
Re: [GB] GMK Orange Alert - 8/14/26 to 9/14/26 | Order Graphs, Geon Added
« Reply #8 on: Sun, 30 August 2026, 09:03:49 »
hope this keycap set does well!
Online dvorcol
« Reply #9 on: Tue, 01 September 2026, 21:00:37 »
Offline baucts
Re: [GB] GMK Orange Alert - 8/14/26 to 9/14/26 | 1 Week Left
« Reply #10 on: Fri, 11 September 2026, 12:38:44 »
Online dvorcol
Re: [GB] GMK Orange Alert - 8/14/26 to 9/14/26 | GB Over
« Reply #11 on: Wed, 30 September 2026, 18:17:17 »
« Last Edit: Fri, 02 October 2026, 22:49:23 by dvorcol »
Offline baucts
« Reply #12 on: Fri, 02 October 2026, 20:19:59 »
ty all for joining, all kits will be made  :D
