Author Topic: [GB]超新星Supernova - 60% 17/8/2026 to 17/9/2026  (Read 81574 times)
Offline SENSY LAB
  • Where science meets sense.
« on: Wed, 12 August 2026, 08:27:43 »
Supernova
SENSY
This GB will be launched from 8/17/2026 to 9/17/2026.
Vendors
America - Divinikey
Australia - Toro Studio
Canada - Unikeys
Europe - MonacoKeys
Korea - Geon Works
Singapore - iLumkb
United Kingdom - Proto Typist
Vietnam - MOKB
International - Zfrontier
Hello world, this is SENSY.
We launched the IC for our new‑release Supernova 60% two months ago, which drew plenty of discussion and favourable feedback from enthusiasts.
Ahead of the ZFX and Wuque exhibitions in Guangdong, we have finished all prototype tests for the keyboard. The unit was displayed at the shows and has now been sent out for reviewer sampling.
Therefore, we are releasing the final GB information here.
Adjustment Details
The colour has been revised based on actual prototype‑testing and IC feedback. The AEVUM has been switched from anodizing to coating, and the AQUA is removed and replaced with RELIQUIAE.
We optimized the configuration of weights and badges based on the actual supply chain situation. We have removed options that severely delayed progress, including polished SS badges and weights, as well as the underperforming blasted SS stepped weights. Multiple newly-developed patina weights and new-process badgess are now available as alternatives.
Added 4mm PC and PEEK plate material options.
Physical Display
For this round, we use mass‑production‑grade units for reviewer samples. The GB will launch worldwide simultaneously. Review units for international content creators are being dispatched in batches. We will post real‑time updates in the thread once shipments go out. Stay tuned.
Basic Information
Size
60%(296.3x119x36.5mm)
Weight(Unassembled)
PC Top Case ≈ 1.47-1.54kg
Alu Top Case ≈ 1.58-1.65kg
Typing Angle
9°
Front Height
FH=17.5mm/EKH=22.5mm(bumper excluded)
Front side profile
7.90mm(with chamfer)
Material & Craftsmanship
Cases: Aluminum Anodized / Aluminum Coating / PC Sandblasting
Weights: SS milled PVD / SS Patina / Brass Patina
Middle Frames: PEI Raw
Badges: Ice Titanium / Glowwaves Carbon / Turboglow / Westinghouse Micarta
Plates: Aluminum 1.5mm / PC 4mm / ABS 4mm / PEI 4mm / PEEK 4mm
Kit Includes
Cases & Weight x 1
PEI Middle Frame x 1
Badge x 1
PCB x 1
Motherboard & FPC x 1
70a blocks x 5
90a blocks x 5
98a blocks x 5
Rubber feet x 4
Bag & Boxes x 1
T6&T8 Screwdrivers x 1
PCB Support
Wired, Vial‑compatible.
The soldered and hotswap MX‑compatible PCBs share identical layout support.
We would also like to thank Metakeebs for providing the EC PCB solution for this project.
SonoShell Structure
We still adopt the Top Mount with blocks and a five‑point positioning setup with three upper anchor points and two lower ones. This is our favourite point layout for compact‑size keyboards so far.
Three hardness grades of blocks will be offered for users to pick their preferred typing feel.
Based on real‑world usage feedback, blocks will no longer be compatible with the PC top‑case.
The overall framework inherits the proven structure used for the Smoke, which remains the signature highlight of our Legacy series.
After multiple rounds of prototype tests, we settled on PEI for the middle frame. It outperforms metal frames on vibration dampening and strikes a well‑balanced compromise of performance, appearance and cost compared with other plastic frames.
The PEI mid frame, top case and internal stack form the standalone SonoShell acoustic cavity. Its merits have been fully explained during the interest‑check phase. The isolated chamber enables fine‑tuned, fuller‑bodied sound tuning and avoids short‑circuit risks brought by internal padding materials.
Colors
Here is an explanation of the colour‑selection rules for this release:
There are nine fixed colour combinations for the top and bottom cases. A PC top case is available as an optional accessory for every shell colourway.
The PC top case is incompatible with the buffer blocks.
Each colourway comes with two weight finishes, milled and patina. The milled tone and patina effect are fixed for each variant.
AER
Top Case: Aluminum Anodized Silver / PC
Bottom Case: Aluminum Anodized Orange
Weight: SS Milled PVD Silver / SS Patina Black&White
AEVUM
Top Case: Aluminum Coating Pink / PC
Bottom Case: Aluminum Coating White
COMĒTA
Top Case: Aluminum Anodized Turquoise / PC
Bottom Case: Aluminum Anodized Grey
Weight: SS Milled PVD Blue / SS Patina Cyan
ETHER
Top Case: Aluminum Anodized Rose Red / PC
Bottom Case: Aluminum Anodized Black
Weight: SS Milled PVD Black / SS Patina Black
IGNIS
Top Case: Aluminum Anodized Black / PC
Bottom Case: Aluminum Anodized Red
NATURA
Top Case: Aluminum Anodized Ching / PC
Bottom Case: Aluminum Anodized Green
Weight: SS Milled PVD Gold / Brass Patina Cyan
ORBIS
Top Case: Aluminum Coating L9 / PC
Bottom Case: Aluminum Coating U9
Weight: SS Milled PVD Silver / Brass Patina Marble
RELIQUIAE
Top Case: Aluminum Anodized Blue / PC
Bottom Case: Aluminum Anodized Light Blue
Weight: SS Milled PVD Blue / Brass Patina Cyan
TERRA
Top Case: Aluminum Anodized Champagne Gold / PC
Bottom Case: Aluminum Anodized Brown
Weight: SS Milled PVD Gold / Brass Patina Brwon
Accessories
Layouts
HHKB
WKL
WK
Badges
Part of the badges feature luminous effects, and comparison pictures of the glow‑in‑the‑dark effect are available.
Ice Titanium Blue
Ice Titanium Gold
Ice Titanium Rose Red
Ice Titanium Turquoise
Blue GlowWaves Carbon
Fire GlowWaves Carbon
Fireball GlowWaves Carbona
Neon Green GlowWaves Carbona
Ocean GlowWaves Carbona
White GlowWaves Carbona
Electric Pink TurboGlow
Plates
Alu 1.5mm
PC 4mm
ABS 4mm
PEI 4mm
PEEK 4mm
Price
The starting price will fall within $400. Specific prices will be set and announced by each vendor.
GB Time
Fulfillment Timeline
3 months after GB conclusion (roughly by the end of 2026)
How to follow news of the Supernova
You can Follow our Website, Instagram and Discord for updates.We will also update further information in this post in a timely manner.
« Last Edit: Wed, 12 August 2026, 21:37:54 by SENSY LAB »
