Author Topic: [IC] GMK CYL Rareabic  (Read 75322 times)
Offline godsson
« on: Mon, 28 September 2026, 13:27:25 »
GMK CYL Rareabic
Introducing GMK CYL Rareabic, a set inspired by one of the rarest beige sets around: GMK Classic Retro Arabic. Instead of trying to hunt this guy down, I decided to create a modernized version of it with novelties, accents, and extensions.
This set uses stock colors: L9, U9, RO2, and CR. Beige is life!
Kits
Base
Extension
Renders
Aein & Dia by NoNumbers
F1-8X by Geon Works
Fossil by Carolina Mech
Nyx65 by GODSSON Designs
Vendors
TBD
Shoutouts
Thank you to NoNumbers, Arslock, and Foraz for the renders and support!
Links
IC Form
Discord
GSD Store
Instagram
YouTube Typing Tests
YouTube Stream VODs
Twitch
« Last Edit: Mon, 28 September 2026, 22:06:50 by godsson »
Offline godsson
Re: [IC]GMK CYL Rareabic
« Reply #1 on: Mon, 28 September 2026, 13:37:57 »
Reserved for updates.
Offline doodwalla2000
Re: [IC] GMK CYL Rareabic
« Reply #2 on: Wed, 30 September 2026, 22:16:59 »
I'm really diggin this set, looks great and one i'd definitely be in on.  How we feel about squeezing in F13 in base and 00 in extension?
Looks great wishing success for this to move forward.
Offline SKYP.Lab
« Reply #3 on: Sun, 04 October 2026, 03:22:42 »
Beige is life indeed :)
Nice to see a modern take on Classic Retro Arabic instead of everyone chasing the original. The mix of L9, U9, RO2 and CR gives it a warm look.
One small wish from a design point of view: I'd love to see a few accent keys in a warm dark grey or off-black. Beige is a light colour and the red is quite saturated, so together they can get a little tiring on the eyes over time. A handful of warm dark keys, or another low saturation colour, would add some weight and tie the whole set together. Pairing it with a neutral case would help in the same way and make the overall board easier on the eyes.
Looking forward to seeing the full kit renders for the extension kit.
« Reply #4 on: Sun, 04 October 2026, 08:34:35 »
Please consider adding double 00 and F13
Offline getupbuzz
« Reply #5 on: Wed, 07 October 2026, 08:49:25 »
Most people already own beige keycaps—and probably quite a few beige sets—so wouldn’t it be more economical and practical to offer just an alpha kit and an extension kit?
Offline mngxx
« Reply #6 on: Wed, 07 October 2026, 17:51:11 »
Hi! Please consider R1 pipe in the L9 base color.
Offline konstantin
  • Formerly constexpr
« Reply #7 on: Fri, 09 October 2026, 10:50:07 »
Lovely set, I'm definitely in. I type in Arabic frequently, and I'd love to see support for the (in my opinion far more intuitive) Mac Arabic layout, which has د ذ ط ظ together on the bottom row, ة on the same row as ه, and handles the various forms of hamza on the shifted layer a bit differently. The rest of the layout is the same for the most part, which means not that many extra keys would need to be added.*
Speaking of haa and taa marbuta, I wish you would use the more common isolated form of haa, the one that looks like a circle (ہ) rather than a squiggle (ﮪ), for the keycap legend. That way it'd match the glyph used for taa marbuta (ة).
Since you already have 4-key terminal ISO support in the base kit, you could take the opportunity to incorporate support for 102-key Arabic layouts as well. You'd just need to print dhaal/shadda (ذ ૻ) sublegends on the R3 \| key, and a tatweel (ـ) sublegend on the R4 <> key.
* They could either fit in Extension, or they could form a separate Mac child kit together with the 1.5u Super + 1u Alt keys currently present in Extension.
Edit:
+1
« Last Edit: Fri, 09 October 2026, 11:04:41 by konstantin »
Offline incrediblejr
« Reply #8 on: Sat, 10 October 2026, 02:48:34 »
+1
+2 (I think the current is just rendered in wrong color, should be alpha color for split backspace)
Speaking of backspace, please use "Backspace" and not "<- Back". This goes for both 1.5u R2 and 1.75u R3 (i.e. skip <-).
« Reply #9 on: Fri, 16 October 2026, 11:34:09 »
nice
