Author Topic: [GB] GMK MTNU Dasher  (Read 260 times)
Offline nilslorand
« on: Sat, 31 October 2026, 05:52:05 »
GMK MTNU Dasher Pre-Order Thread
Pre-Order is live between November 4th and December 6th at the following Vendors
UK: protoTypist (Lead Vendor)
EU: Oblotzky
NA: NovelKeys
Korea: GeonWorks
OCE: KeebzNCables
CN: TypistClub
Based on the Data General Dasher Keyboard and of course the keyboard from the Series “Severance”, MTNU Dasher is my personal take on this Blue Retro Keycap Set.
Original IC Thread on the GMK Discord Server | Keebtalk IC Post | Original IC Reddit Post | GeekHack IC Post
Since I'm using imgur for the images, you may have to check the keebtalk post for updated images and reddit for the highest quality ones if you're in the UK (sorry!).
Kits
Base
Full Base Kit with 4-key 40s included. Note that the 3U spacebars have 3 stems instead of the usual 5 in order to guarantee DynaCap compatibility.
Novelties
Some novelties inspired directly by the show, others less directly. Has been trimmed down quite a lot from the initial IC for cost reasons
International
I use QWERTZ (German layout) myself and I would never design keycaps I couldn't really use myself, so this set is a given.
Colors
White: GMK MTNU XW1
Light Blue: Signature Plastics ABS BBJ
Dark Blue: Signature Plastics ABS BO
The SA Dasher Keycaps used the listed ABS colors, for the white I figured it's easiest to just stick with GMK stock colors. The entire set will be PBT though, don't worry!
Some of the Board Renders
Also, massive thanks to Jae from protoTypist without whom this would not have been possible! :D
« Last Edit: Tue, 03 November 2026, 04:12:23 by nilslorand »
Re: [GB] GMK MTNU Dasher
« Reply #1 on: Tue, 03 November 2026, 21:34:11 »
Approved :thumb:
