Author Topic: Which aluminum case shape would you pick, A or B?  (Read 769 times)
Offline PandaKB
  • Ergo Evangelist. Your wrists can thank me
    • PandaKB
« on: Mon, 30 November 2026, 07:03:31 »
Hi, I’m Tao from PandaKB. We’re working on a split keyboard based on the Sofle layout, tentatively called Sofle Mod. We started with A. After we shared the designs on Discord, a friend said they preferred B, so I figured I’d ask here before settling on the case shape.
- A — Curved top edge. One continuous arc gives the case a rounder outline.
- B — Angled top edge. The edge follows the PCB outline and the stagger of the keys.
The left half has an 8-color, low-power Sharp Memory LCD and a 5-way switch. The right half has a trackpad and a rotary encoder. The board also has adjustable tenting and RGB lighting. We’re planning a CNC-machined aluminum bottom case, a sound-dampening foam kit, a carbon fiber switch plate, and an acrylic top cover.
I’ve attached renders of both designs and photos of the 3D-printed prototype. Which would you pick, A or B? A one-letter vote is fine. If you feel like sharing why, I’d love to hear it.
318856-0
318848-5
318850-6
318852-7
318854-8
318856-9
« Last Edit: Mon, 30 November 2026, 07:18:48 by PandaKB »
Offline cryoverkiltmilk
    • My Tumblr
Re: Which aluminum case shape would you pick, A or B?
« Reply #1 on: Mon, 30 November 2026, 10:27:55 »
Always prefer cases to follow the PCB shape.
