Author Topic: Filco Keys on other Keyboards?  (Read 2186 times)
Offline nodq
« on: Mon, 22 November 2010, 03:56:53 »
Hi,
how does it work with custom Keys? Can i order such Filco Keys here: http://elitekeyboards.com/products.php?sub=access,keycaps&pid=redwasd
and put them on my Steelseries 7G? Or other Keys maybe. Or does that not work?
Sorry if i made a Thread again, don't know what to search for. :)
greetings
Offline Azuremen
« Reply #1 on: Mon, 22 November 2010, 04:19:38 »
My SteelSeries 6Gv2 has the same profile as the Filco boards, which is the same as the Rosewill RK-9000.
I've got a Filco red ESC on it at the moment but tested the WASD keys I have as well and they seemed to match just fine.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline nodq
« Reply #2 on: Mon, 22 November 2010, 04:29:47 »
Quote from: Azuremen;250470
Ah cool oki, i will order some then. Btw. a Red ESC Key is as expensive as a 4 Key Set WASD? :D Thats kinda weird actually.
http://elitekeyboards.com/products.php?sub=access,keycaps&pid=hh_redesc
Whats so special about the ESC Key? :D I find it funny.
Offline Azuremen
« Reply #3 on: Mon, 22 November 2010, 05:30:03 »
You get both a blank and a labeled one.
And that is the Red Esc key for the HHKB, which uses Topre switches. If you order that, it won't work on your SteelSeries...
Flickr
Offline nodq
« Reply #4 on: Mon, 22 November 2010, 05:52:24 »
Quote from: Azuremen;250482
Yup just saw it myself 2 minutes ago. :) ordered the right ones now. Thanks.
