Author Topic: Cherry G80-3000 double space  (Read 1873 times)
Offline whininggit
« on: Wed, 01 December 2010, 13:31:11 »
I have been noticing that double spaces are often occuring when I type on my modded Cherry G80-3000. The problem is, I don't know if it's the keyboard or if it's me. I know that it never occurs with the Logitech rubber dome at work, but that might just be because the keys on that require more of a mash than the Cherry MX browns.
To put the resistance theory to the test, I swapped in a tactile grey MX top and spring, but still have the problem.
I remember it having this problem to some extent when it was originally an MX Blue + Green keyboard, so it's not a result of the switch top swaps. Recently though, I have been noticing it more often but don't know if that's because I'm being more observant or because it is happening more often. None of the other keys do it - just the space bar.
If I try to reproduce the problem, such as by typing a a a a a a a a a a a a, I can do that many, many times and never see the repetition.
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline zmurf
    • Cherry G803000LQC With Latest Generation Trackpoint
« Reply #1 on: Wed, 01 December 2010, 14:13:59 »
have never had any problem with this on my G80-3000 with original clears... so either its you or your mod. Or you just have a faulty keyboard.
« Last Edit: Wed, 01 December 2010, 14:19:03 by zmurf »
At last! A mechanical keyboard with Trackpoint of my own! Now with Hyper-Scroll! And also Ergo-Clear switches. Ohh... look... custom keys! :D
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Fri, 03 December 2010, 10:20:18 »
Might be a bent contact or somesuch (one of the few parts that weren't swapped out). Soldering iron time.
