Author Topic: Keyboard identification from image  (Read 8152 times)
Offline morgan.b
« on: Sat, 04 December 2010, 04:48:12 »
Hello!
I have been lurking around here on the forums for a while, and suddenly I feel this urge to find and try old keyboards! I found a bunch of cheap keyboards on an auction site. My question is, if I could get some help identifying them? Particularly if anyone of them is extra noteworthy? Here is an image:
« Reply #1 on: Sat, 04 December 2010, 06:46:28 »
Hello there fellow Swedish guy. I am bidding for that auction. I would like to avoid getting into a bidding war with you. If we could split up the lot, then I would be happy with that. I am in Stockholm.
Personally, I am only really interested in getting one of the Victor keyboards.
I don't think that any of these are mechanical, not in any way that you could use anyway, not even for build projects.
I have identified the two Victor keyboards as re-branded Fujitsu Peerless keyboards. If you search for "peerless" on this board, you will find ten people who absolutely hate them and one person who says he loves them. The Peerless tech is a combination of a spring and a rubber dome.
I have bid on this auction because I want to try it out and feel for myself what the big deal is ...
That is the only keyboard that I am really interested in.
The keyboard in-between the two Victor keyboards is an older type of Keytronic rubber dome keyboard.
The grey and black keyboard is for an old computer that was branded Sirius 1 in Europe and Victor 9000 in the USA. The computer was one of the many competitors to the IBM XT back in the early '80s. The computer had the same CPU as the XT and you could run either CP/M or MS-DOS on it ... as long as the program fit within 128 K of memory.
As far as I have been able to tell, the keyboard has foam and foil capacitative switches (linear). The keyboard is most likely not compatible with any modern computer, but is cool in a way because it is programmable.
I know of a Geekhack member from Canada who has expressed interest in getting one of these. He has a PM that I have sent days ago...
I have not been able to identify the white keyboard, but it looks like it has a Windows logo next to the indicator LEDs. I sent a message to the seller yesterday asking what it is, but not received a reply yet.
« Last Edit: Sat, 04 December 2010, 06:54:49 by Findecanor »
Offline Sam
« Reply #2 on: Sat, 04 December 2010, 06:55:07 »
Mr A500 was looking for one of those Victor 9000 keyboards.  If either of you win it and don't need that item, you might want to contact him.
Offline morgan.b
« Reply #3 on: Sat, 04 December 2010, 08:53:46 »
What a funny coincidence. Do not worry, I do not think I will bid on the auction. I think I am mainly out after mechanical keyboards, such as the Model M. Though, if you for some reason find the Victor peerless super awesome. Then maybe you would be willing to spare one for a reasonable sum?
Offline mr_a500
« Reply #4 on: Sun, 05 December 2010, 13:05:20 »
Quote from: Sam;256860
Yes, I was looking for one (the multi-coloured earlier one, actually), but I think shipping from Sweden might be a bit high. I think I've finished with buying keyboards for a while. (...until I get obsessed again... maybe a beam spring...)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #5 on: Sun, 05 December 2010, 14:23:34 »
Apparently Peerless boards aren't that bad... except for a lack of stabilizers on some keys, which can be awkward. Why one would go through all the trouble to make a decent 'board only to fail at the last mile, I don't know. Some people hate them, some people like them, no idea what to make of that.
« Reply #6 on: Mon, 06 December 2010, 02:48:19 »
I have got a response from the seller. The white windows keyboard on the left is a SolidTek / Ackeytech ACK-210. PS/2. Most likely a rubber dome.
« Reply #7 on: Fri, 10 December 2010, 07:30:50 »
Argh! Goddamned sniper!
Offline Martin227
« Reply #8 on: Fri, 10 December 2010, 07:43:57 »
I have won the auction. If anyone would like one of the keyboards post here or PM me. I am in following towns from time to time: Stockholm, Örebro, Gävle, Sundsvall.
<3
« Last Edit: Fri, 10 December 2010, 08:21:43 by Martin227 »
New account: bogboar
Offline itlnstln
« Reply #9 on: Fri, 10 December 2010, 08:28:08 »
Genital warts?
« Reply #10 on: Fri, 10 December 2010, 17:38:20 »
Quote from: Martin227;260629
You mean that you bought these keyboard to resell?
Then Hell No. I wouldn't want any from you!
« Last Edit: Fri, 10 December 2010, 17:42:59 by Findecanor »
Offline vegaman
« Reply #11 on: Sun, 12 December 2010, 22:01:56 »
I'm in a similar position, but just looking at an auction with a single keyboard, anyone have any ideas about it?
Offline theferenc
« Reply #12 on: Sun, 12 December 2010, 22:11:46 »
That looks like one of the POS boards. Most that I've seen that look like that are browns, if that helps.
On a random note, you can program the card reader to act as a login authentication in windows. I used one for a while with my school ID as the factor.
Offline vegaman
« Reply #13 on: Sun, 12 December 2010, 22:18:09 »
Quote from: theferenc;262017
Thanks, looks like it would be a decent buy if I can get it cheap then. Would be fun to play with the card reader too.
Offline theferenc
« Reply #14 on: Sun, 12 December 2010, 22:37:50 »
Digging around a bit more (avoidance of work mode: engaged), it seems they did make a large number of MY switch based POS boards. You might want to ask them to pull a key, just to verify.
Offline vegaman
« Reply #15 on: Sun, 12 December 2010, 22:58:05 »
Thanks, I've asked them to pull a key. Probably best to be sure if I can.
Offline sixty
    • http://deskthority.net
« Reply #16 on: Sun, 12 December 2010, 23:01:40 »
Quote from: vegaman;262009
G81-1900HPU. Cherry MY switches. Keycaps are MX compatible, rest is terrible junk that should be burned with fire.
Offline vegaman
« Reply #17 on: Sun, 12 December 2010, 23:11:12 »
Ah damn. I guess I could potentially harvest it for keycaps to try dying for my G80-1865 that's on the way though.
Offline sixty
« Reply #18 on: Sun, 12 December 2010, 23:13:42 »
Quote from: vegaman;262042
Keycaps on this one are double shot, but they won't die that well. Cherry laser ones work better for dye jobs. Is the board local to you? The keycaps alone are pretty good and somewhat rare, since white sets are long out of production.
Offline vegaman
« Reply #19 on: Sun, 12 December 2010, 23:25:44 »
Not sure how the keys would look on my other board that colour, but since they're doubleshot it should be worth getting it anyway.
Yeah the board is local so I could just pick it up.
Offline 8_INCH_FLOPPY
« Reply #20 on: Mon, 13 December 2010, 01:17:29 »
Quote from: keyb_gr;257668
To put it bluntly, some of them are awesome, and some of them suck.  Someday I'm going to start a database of which particular models suck and which models rule.  Until then, you are just going to have to hope you get lucky.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline keyb_gr
  • Cherrified user
« Reply #21 on: Mon, 13 December 2010, 14:32:03 »
Ah, that explains it then.
Are you feeling lucky?
Fujitsu Peerless - your premium choice for the surprising moments in life!
:P
