Author Topic: Worn out switch or something else?  (Read 1770 times)
Offline turbocharged
« on: Fri, 10 December 2010, 10:33:02 »
After using my TG3 BL82 this week, I have noticed a quirk and don't know what could be causing it. Sometimes whenever I press the "8" or "0" keys it will act like I pressed them two or the times and return a "888" or "00." I feel like this has happened at least once with a letter before too, but I couldn't replicate it...the 8's and 0's happen fairly often.
Could this be a couple of worn out switches?
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
Offline runeazn
« Reply #1 on: Fri, 10 December 2010, 11:14:49 »
thats a bit too bad :/
anything stuck or it is solder time :(
Kami Ducky 1087 of Heaven
« Reply #2 on: Fri, 10 December 2010, 11:53:10 »
I wish I had known about it when I had it torn down doing my review. I desoldered two switches then to replace broken switch stems, wouldn't have been much more of a hassle to do 2 or 3 more while I was in there.
Though, having to desolder the two pins for the switch and the two pins for the LED on every switch would have probably got a bit old.
[SIGPIC][/SIGPIC]
