Author Topic: Ricercar SPOS $80 Shipped GOGOGOGO  (Read 2319 times)
Offline elbowglue
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Phaedrus2129
« Reply #1 on: Fri, 10 December 2010, 19:10:33 »
The second one is the same as the one in the first, just bundled with all the cash register ****.
I wouldn't be so quick to assume without at least a label shot. The real deal is labeled as both "G86-62410EUAGSA" and "G80-62410EUADSA" and has "Cherry MX" on it.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Soarer
« Reply #2 on: Fri, 10 December 2010, 19:21:47 »
Looks like the right one to me. The rubber dome version has wider, squarer tops to the keys.
Offline elbowglue
« Reply #3 on: Fri, 10 December 2010, 20:22:52 »
Quote from: Phaedrus2129;261045
Real vs fake Ricercar spos
This is MX brown.  The solenod, space between the relegendable keycaps gives it away. Trust me.
Offline keyboardlover
« Reply #4 on: Fri, 10 December 2010, 20:26:02 »
Looks like it could use a good cleaning...do these have 2 key rollover?
Offline elbowglue
« Reply #5 on: Fri, 10 December 2010, 21:12:51 »
2KRO is correct.  PCB mounted cherry browns.
Offline AndrewZorn
« Reply #6 on: Fri, 10 December 2010, 21:50:52 »
Mine is still in the plastic wrap, got it for $10 when we 'discovered' them.
It might just be time to let someone else enjoy it.  I like Cherry Brown, but can't really get myself to like the keyboard layout/2KRO.
Offline elbowglue
« Reply #7 on: Sun, 12 December 2010, 11:25:53 »
Ya'll snooze ya'll loose.  Turns out last night my dog chewed through the USB cable on my current ricercar SPOS, so I made the seller an offer outside of ebay for a slight discount, now this KB is mine. Bwahah.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #8 on: Sun, 12 December 2010, 11:29:19 »
Did you splice the cable back together?
Offline elbowglue
« Reply #9 on: Sun, 12 December 2010, 13:30:37 »
I'm going to when I get some free time.  (hope it works ok).  Dog chewed it right near the solenoid so I'm gonna have to use a different USB cable.
Offline elbowglue
« Reply #10 on: Mon, 13 December 2010, 15:28:11 »
Fixed the cable.  It's not pretty but it was pretty straightforward.  Works fine without the solenoid btw.  (except my neigbors are probably getting AM radio intereference now!)
Been looking at the ricercar spos PCB.  I think I'm gonna cut off the right 2 columns.  The PCB is double printed (front and back) which makes it pretty hard to see where the tracings go, especially since a lot dive under the switches.  I may have to desloder some switches before I can even understand the PCB tracing..
Should not be hard to cut the daughterboard too there should be only 2 or 3 connections to resolder there if I cut the right most 2 columns off.
Actually looking at the daughterboard I think I can cut it without any re-soldering at all.
In the true spirit of the ricercar spos, I will spread all relevent information all across geekhack in a totally incoherent format, so no newbie will ever understand the whole thing.
« Last Edit: Mon, 13 December 2010, 15:34:21 by elbowglue »
Offline elbowglue
« Reply #11 on: Mon, 13 December 2010, 15:57:56 »
Update - I just cut the daughterboard at the point at which you would cut the right 2 columns off.  It still works.  No soldering involved on the daughterboard.
Offline elbowglue
« Reply #12 on: Mon, 13 December 2010, 17:40:36 »
RIP serial number 253 ricercar spos.  It's dead Jim.
Offline elbowglue
« Reply #13 on: Mon, 13 December 2010, 18:49:06 »
Double sided PCB bested me in my somnolent state.  Daughterboard is easily cuttable without causing any problem whatsoever..  I'm not sure if something happened with the way I patched the USB cable together or if I cut drilled the wrong spot on the PCB.  Anyways I killed the board.
Offline didjamatic
« Reply #14 on: Mon, 13 December 2010, 18:49:44 »
Teensy time?
