Author Topic: Overkill  (Read 2298 times)
Offline Phaedrus2129
Overkill
« on: Fri, 10 December 2010, 19:31:16 »
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Lanx
Overkill
« Reply #1 on: Fri, 10 December 2010, 19:35:21 »
caps aren't even molded =/
prolly one of those programmable things operators use, program a key and place a piece of paper under the keycap.
Offline twn2
Overkill
« Reply #2 on: Fri, 10 December 2010, 19:56:21 »
How do you know that it is an MX brown?
Overkill
« Reply #3 on: Fri, 10 December 2010, 20:19:48 »
Quote from: twn2;261063
It isn't, it's a rubber dome. I'm saying it'd be great if it did have MX browns.
Offline Arc'xer
Overkill
« Reply #4 on: Fri, 10 December 2010, 20:22:45 »
http://www.piengineering.com/xkeys.php
If I'm not mistaken they mostly use cherry mx brown.
