Author Topic: For those paranoid about the "fall" of PS/2  (Read 5045 times)
Offline Phaedrus2129
« on: Fri, 10 December 2010, 20:36:31 »
http://www.newegg.com/Product/Product.aspx?Item=N82E16815150153&cm_re=PS%2f2_card-_-15-150-153-_-Product
Get over it.
Now, if you're worried about the death of PCI... Well we just have to hope they make a PCIe version.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Soarer
« Reply #1 on: Fri, 10 December 2010, 21:18:43 »
Probably consists of a USB chip, and a buggy PS/2 to USB adapter chip. Not ideal :-/
Offline AndrewZorn
« Reply #2 on: Fri, 10 December 2010, 21:49:26 »
Quote from: Phaedrus2129;261083
Get over it.
is all you needed to say.
Offline ch_123
« Reply #3 on: Sat, 11 December 2010, 02:57:21 »
That's basically a USB adapter that you have to open your PC to install. Probably isn't as good as the Belkin an' all.
Offline grilkip
« Reply #4 on: Sat, 11 December 2010, 14:59:53 »
The only reason I use PS/2 is to be able to start my PC by hitting the space bar, which in the case of my mobo can only be done through the PS/2 port.
Filco tenkeyless (browns) - IBM Model M - Cherry G80-3000LSCEU (blues) Das Prof. S (blues)
ANSI FTW
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #5 on: Sat, 11 December 2010, 16:23:54 »
If it does convert to USB, doesn't that mean that going beyond 6-key rollover, the only thing a conventional PS/2 to USB adapter won't give you, is still not attained?
Offline Konrad
« Reply #6 on: Sat, 11 December 2010, 18:18:58 »
PS/2 is still "standard" in all the major Super I/O chips (Winbond, and all those who follow it) ... I foresee the last vestige of floppy support dying before PS/2 gets cut.  Maybe I'll be able to finally use my A: and B: drives for something useful (like removable ATA flash or somethin') without BIOS conflicts.
Offline Soarer
« Reply #7 on: Sat, 11 December 2010, 19:02:41 »
I'm not paranoid, it really is out to get me... 8-|
Offline kriminal
« Reply #8 on: Sat, 11 December 2010, 19:13:44 »
i dont really care if ps\2 dies...
but pls stop placing floppy interfaces on my mobo plz..
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline Konrad
« Reply #9 on: Sat, 11 December 2010, 19:27:23 »
You could always program your own keyboard controller firmware.
Or just do what the Microsoft prototyping guys do and program a virtual COM port through USB interface, compatibility with the "legacy" limits of IBM's 8042 chip and scan code sets be damned. Mind you, this approach would only operate after your OS drivers are loaded up, so you'd still need a standard keyboard for POST and BIOS stuff.  And oh yeah, it'd eat up a little bandwidth from one of your USB hubs.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #10 on: Sat, 11 December 2010, 21:41:09 »
Until the true NKRO usb driver arrives on my hard disk (that works with PS/2 to USB adapters), PS/2 better be on my mobo.
That, and USB adapters are too flaky (converting from PS/2). There are really good ones (e.g. Blue Cube). But it's still not as compatible as a true PS/2 port.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline Konrad
« Reply #11 on: Sat, 11 December 2010, 22:12:09 »
In the case of USB the limits are indeed software based.  If HID were rewritten (assuming the keyboard itself packs a decent controller) then 6KRO would be a thing of the past.  HID can't be that hard to figure out, can it?
Offline Konrad
« Reply #12 on: Sun, 12 December 2010, 01:30:32 »
Default scan code sets?  The PS/2-USB adapter is either just a dumb connector (passive) or has logic to convert between sets ... I suppose an ideal one would have switches (manual or autodetect) between (all 9 active, 1 passive) possible combinations.  Maybe the Germans just like to be difficult.
Offline grilkip
« Reply #13 on: Sun, 12 December 2010, 01:32:15 »
Quote from: Konrad;261609
That's a given.
ANSI FTW
Offline Konrad
« Reply #14 on: Sun, 12 December 2010, 11:24:46 »
No, Kishy ... what I was trying to say is that the 6KRO limitation is built into HID. A better HID could allow USB keyboards to easily exceed this limit. Even "Slow Speed" (1.5Mbps) USB can easily accomodate enough data for full keyboard NKRO.
But the keyboard itself must be electrically/logically capable of supporting >6KRO. The reason I mentioned this is simple: many keyboards today do not meet this specification. The best NKRO HID in the world won't help if the keyboard itself has only 2KRO.
Offline Konrad
« Reply #15 on: Sun, 12 December 2010, 12:44:15 »
What do you mean: "meets the HID spec"?
Offline Soarer
« Reply #16 on: Sun, 12 December 2010, 14:34:25 »
Complies with:
Device Class Definition for Human Interface Devices (HID)
Firmware Specification—6/27/01
Version 1.11
In particular "Appendix F: Legacy Keyboard Implementation", which describes the Boot Mode that BIOS uses.
The trick is for a keyboard to use the good stuff for NKRO (that almost all OS's HID class drivers since about 2001 can do), without becoming non-compliant with the constraints of boot mode - even for BIOS that implement boot mode incorrectly.
« Last Edit: Sun, 12 December 2010, 14:49:24 by Soarer »
Offline Soarer
« Reply #17 on: Sun, 12 December 2010, 14:48:18 »
The future wasn't built to last.
woody
  •  Guest
« Reply #18 on: Mon, 13 December 2010, 06:05:53 »
Quote from: ripster;261799
I keep telling my son the future is in Biology, not Programming.
Neither progaming.
Biology and chemistry, like it was before.
woody
  •  Guest
« Reply #19 on: Mon, 13 December 2010, 16:30:26 »
Quote from: ripster;262516
Kinda like getting rid of the Parallel port.
Luckily, chipsets support it and quite many motherboards have it on a header. Even more luckily, my last MB even has integrated connector on it. And a serial port. And an S/PDIF output. I was lucky on this round.
Offline Konrad
« Reply #20 on: Mon, 13 December 2010, 16:35:51 »
I don't see how luck is involved if you're selective about which mobo you purchase, lol.
woody
  •  Guest
« Reply #21 on: Mon, 13 December 2010, 16:45:40 »
Quote from: Konrad;262525
Luck that somebody decided to produce such MB, luck that somebody here decided to import, luck that they actually had it in stock. Trust me, that was some luck. My previous MB had parallel port on header only.
I bet you don't know much about our market, but I'll hint you it's not big and we don't have Newegg.
woody
  •  Guest
« Reply #22 on: Mon, 13 December 2010, 16:48:54 »
Quote from: ripster;262528
I find serial ports are no longer high on my priority list.
To each his own. Computers are tools, and I need some specific properties of my tools.
